[petsc-users] How to interface with PETSc from another application?
Klaus Burkart
k_burkart at yahoo.com
Wed Oct 4 09:23:23 CDT 2017
What's the concept to interface with PETSc from another application to solve a linear system with PETSc?
The standard procedure of the job:
1: The application provides a matrix which needs to be converted and be loaded into PETSc
2: The application provides the rhs vector (containing pointers!) which needs to be loaded into PETSc
3: The linear system is to be solved using PETSc
4: The application provides the result vector x, the PETSc result needs to be copied back to the application into vector x (also expecting pointers)
The problem - maybe a completely wrong approach when it comes to using PETSc:
With other linear algebra libraries, I included the library functionality in the code of a new solver accessing the functionality usually via header files and created a plugin which can be called from the application when running a simulation.
Even so the mixed code including PETSc code can be compiled, the bit of the plugin, interfacing with the application is broken as soon as I include more than a PETSc declaration in the mixed code.
How to interface with PETSc from a software application? (I am using c++ and Ubuntu)
Klaus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171004/46939907/attachment.html>
