[petsc-users] Configure problem
Mark Adams mfadams at lbl.gov
Tue Oct 3 15:39:50 CDT 2017
On Tue, Oct 3, 2017 at 4:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> checking size of bool... 0./configure: line 12435: printf %s\n: command
> not found
> ./configure: line 12436: printf %s\n: command not found
> configure: WARNING: The C++ compiler g++ cannot compile a program
> containing the <string> header - this may indicate a problem with the C++
> installation.  Consider configuing with --disable-cxx
> configure: WARNING: Structures containing long doubles may be aligned
> differently from structures with floats or longs.  MPICH does not handle
> this case automatically and you should avoid assumed extents for structures
> containing float types.
> configure: error: unable to determine matching C type for C++ bool
> For some reason MPICH configure is failing.
> balay at asterix /home/balay/petsc (maint=)
> $ which printf
> /usr/bin/printf
> $ rpm -qf /usr/bin/printf
> coreutils-8.27-16.fc27.x86_64
> Your machine does not have this basic coreuitls package installed?
We are probably missing a module,
> Satish
> On Tue, 3 Oct 2017, Dylan P. Brennan wrote:
> > Hello,
> > I’m having problems configuring, any ideas?
> > Dylan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171003/1eec63f0/attachment.html>
