[petsc-users] Loading a PETsc matrix with matrix data in CSR format?
Tue Oct 3 08:42:42 CDT 2017
On Tue, Oct 3, 2017 at 7:40 AM, Klaus Burkart <k_burkart at yahoo.com> wrote:
> Hello,
> I am still struggling to load my matrix in a PETSc matrix.
> I tried the following code which is part of a c++ function which converts
> the original matrix to CSR fromat and should load a PETSc matrix.
>     Mat M;
>     MatSetFromOptions(M);
>     // fill PETSc matrix
>     MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, n, n, rows, cols, vals, M)
It should be &M at the end, according to the function definition.
   Matt
> but I get the following error message when compiling the code:
>  error: cannot convert ‘Mat {aka _p_Mat*}’ to ‘_p_Mat**’ for argument ‘7’
> to ‘PetscErrorCode MatCreateSeqAIJWithArrays(MPI_Comm, PetscInt,
> PetscInt, PetscInt*, PetscInt*, PetscScalar*, _p_Mat**)’
> M)
> What's wrong with this?
> Klaus
> Barry Smith <bsmith at mcs.anl.gov> schrieb am 16:38 Sonntag, 17.September
> 2017:
> 1)  MatSetValues() has absolutely nothing to do with the format used
> internally by PETSc to store the matrix. MatSetValues() is used to convey
> blocks of values into the matrix.
>   2) If you want to load a matrix onto multiple processes from a file
> NEVER write your own parallel ASCII matrix reader. Instead in either C,
> C++, Python, or Matlab write a routine that reads in the matrix
> SEQUENTIALLY and then saves it with MatView() and a binary viewer. You can
> then load the matrix easily and efficiently in PETSc in parallel with
> MatLoad
>   3) If you have matrix already in CSR format you can use
> MatCreateSeqAIJWithArrays()
>   Barry
> > On Sep 17, 2017, at 9:25 AM, Klaus Burkart <k_burkart at yahoo.com> wrote:
> > The matrix import function looks like this:
> > void csr2pet
> >    const Foam::lduMatrix & matrix,
> >    petsc_declaration<Type> & petsc_matrix  // How to declare the PETsc
> matrix to be filled?
> >    int n = matrix.diag().size(); // small case n = 40800
> >    int nnz = matrix.lower().size() + matrix.upper().size() +
> matrix.diag().size(); // small case nnz = 203800
> >    // allocate memory for CSR sparse matrix using calloc
> >    ScalarType * vals = (ScalarType *)calloc(nnz, sizeof(ScalarType));
> >    uint * cols = (uint *)calloc(nnz, sizeof(uint));
> >    uint * rows = (uint *)calloc(n, sizeof(uint));
> >    // call function to convert original LDU matrix to CSR format
> >    exPet::ldu2csr(matrix,rows,cols,vals);
> >    // fill PETsc matrix
> >    MatSetValues(petsc_matrix, ?, ?, ?, ?, ?, INSERT_VALUES);
> >    // free and release the matrix memory
> >    free(rows); free(cols); free(vals);  // calloc()
> > Questions:
> > 1: How to declare the petsc_matrix to be filled by the function with the
> content of the original matrix?
> > 2: MatSetValues(petsc_matrix, ?, ?, ?, ?, ?, INSERT_VALUES); is used to
> actually fill the petsc_matrix and I was of the opinion that PETsc uses the
> CSR format but I can't work out how CSR format is described by:
> >    v        - a logically two-dimensional array of values
> >    m, idxm    - the number of rows and their global indices
> >    n, idxn    - the number of columns and their global indices
> > My original matrix is converted to CSR format, i.e. three arrays cols
> (column_indices), rows (row_start_indices) and vals (values).
> > How can I load my matrix into a PETsc matrix for parallel processing?
> > Klaus
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171003/3665aba9/attachment.html>
