[petsc-users] Issue of mg_coarse_ksp not converge
Wenbo Zhao zhaowenbo.npic at gmail.com
Mon Oct 2 10:23:25 CDT 2017
I get more output
zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_smooth
mpirun -n 1 ./step-41 \
   -st_ksp_type gmres -st_ksp_view -st_ksp_monitor  \
   -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
   -mata AMAT.dat -matb BMAT.dat \
   -st_gamg_est_ksp_view -st_gamg_est_ksp_monitor \
   -eps_nev 1 -eps_ncv 10  -eps_monitor -log_view > log_smooth 2>&1
makefile:43: recipe for target 'runkr_smooth' failed
make: *** [runkr_smooth] Error 91
zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_nonsmooth
   -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
   -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_nonsmooth 2>&1
On Mon, Oct 2, 2017 at 11:15 PM, Mark Adams <mfadams at lbl.gov> wrote:
> non-smoothed aggregation is converging very fast. smoothed fails in the
> eigen estimator.
> Run this again with -st_gamg_est_ksp_view and -st_gamg_est_ksp_monitor,
> and see if you get more output (I'm not 100% sure about these args).
> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
> wrote:
>> Matt,
>> Test 1 nonsmooth
>> Test 2 smooth
>> Thanks,
>> Wenbo
>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>> wrote:
>>>> Mark,
>>>> Thanks for your reply.
>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor and we
>>>>> can start to debug it.
>>>>> Test 1 with nonsmooth and preonly is OK
>>>> runkr_nonsmooth
>>>>    -st_ksp_view  -mata AMAT.dat -matb BMAT.dat \
>>>>    -st_mg_coarse_ksp_type preonly   -st_mg_coarse_ksp_monitor  \
>>>> Test 2 smooth and preonly is not OK
>>>> Test 3 nonsmooth and gmres is not OK
>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_gmres
>>>>    -st_mg_coarse_ksp_type gmres  -st_mg_coarse_ksp_monitor
>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>> DO NOT DO THIS. Please send the output where you do NOTHING to the
>>> coarse solver.
>>>   Thanks,
>>>      Matt
>>>>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_gmres 2>&1
>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>> make: *** [runkr_gmres] Error 91
>>>> log-files is attached.
>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>> (diffusion). Where does the asymmetry come from?
>>>> It is a two-group diffusion equations, where group denotes neutron
>>>> enegry discretisation.
>>>> Matrix B consists of neutron diffusion/leakage term, removal term and
>>>> minus neutron scatter source term between different energies, when matrix A
>>>> denotes neutron fission source.
>>>> Diffusion term(Laplace operator) is elliptic and symmetric. Removal
>>>> term is diagonal only. However scatter term is asymmetry since scatter term
>>>> from high energy to low energy is far greater than the term from low to
>>>> high.
>>>> Wenbo
>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>>> wrote:
>>>>>> Matt,
>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>> to test those options.
>>>>>> Wenbo
>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com
>>>>>>> > wrote:
>>>>>>>> Matt
>>>>>>>> Because I am not clear about what will happen using 'preonly' for
>>>>>>>> large scale problem.
>>>>>>> The size of the problem has nothing to do with 'preonly'. All it
>>>>>>> means is to apply a preconditioner without a Krylov solver.
>>>>>>>> It seems to use a direct solver from below,
>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>> KSP/KSPPREONLY.html
>>>>>>> However, I still cannot understand why you would change the default?
>>>>>>>   Matt
>>>>>>>> Thanks!
>>>>>>>> Wenbo
>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>>>> Matt,
>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>> But I am not clear about the 'preonly' option. Which solver is
>>>>>>>>>> used in preonly? I wonder if 'preonly' is suitable for large scale problem
>>>>>>>>>> such as 400,000,000 unknowns.
>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>> I mean, why are you setting this at all. Just do not set the
>>>>>>>>> coarse solver. The default should work fine.
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>> Thanks.
>>>>>>>>>> Wenbo
>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve two-group
>>>>>>>>>>>> neutron diffusion equations with finite difference method. The grid is
>>>>>>>>>>>> 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where B is
>>>>>>>>>>>> diagonally dominant matrix but not symmetry.
>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>  ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>  ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only non-smooths
>>>>>>>>>>>> and preonly is OK.
>>>>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>>>>    Thanks,
>>>>>>>>>>>     Matt
>>>>>>>>>>>> Test 1
>>>>>>>>>>>>    -st_ksp_type gmres  \
>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>> Test 2
>>>>>>>>>>>> 2>&1
>>>>>>>>>>>> Test 3
>>>>>>>>>>>> 2>&1
>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and BMAT.dat.
>>>>>>>>>>>> Is it correct? Or something wrong with my code or commad-line?
>>>>>>>>>>>> Thanks!
>>>>>>>>>>>> Wenbo
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/3871340a/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/3871340a/attachment-0001.tgz>
