[petsc-users] Issue of mg_coarse_ksp not converge
Mark Adams mfadams at lbl.gov
Mon Oct 2 10:21:08 CDT 2017
Yea, it fails in the eigen estimator, but the Cheby eigen estimator works
in the solve that works:
        eigenvalue estimates used:  min = 0.100004, max = 1.10004
        eigenvalues estimate via gmres min 0.0118548, max 1.00004
Why would it just give "KSPSolve has not converged". It is not supposed to
converge ...
On Mon, Oct 2, 2017 at 11:11 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
> wrote:
>> Matt,
> Thanks Wenbo.
>> Test 1 nonsmooth
>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_nonsmooth
>> mpirun -n 1 ./step-41 \
>>    -st_ksp_type gmres  -st_ksp_view -st_ksp_monitor  \
>>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>>    -mata AMAT.dat -matb BMAT.dat \
>>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_nonsmooth 2>&1
>> Test 2 smooth
>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_smooth
>>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>>    -eps_nev 1 -eps_ncv 10  -eps_monitor -log_view > log_smooth 2>&1
>> makefile:43: recipe for target 'runkr_smooth' failed
>> make: *** [runkr_smooth] Error 91
> Mark, the solve is not failing, its the construction of the interpolator I
> think. Check out this stack
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR:
> [0]PETSC ERROR: KSPSolve has not converged
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.8.0, unknown
> [0]PETSC ERROR: ./step-41 on a arch-linux2-c-debug named ubuntu by
> zhaowenbo Mon Oct  2 08:00:58 2017
> [0]PETSC ERROR: Configure options --with-mpi=1 --with-shared-libraries=1
> --with-64-bit-indices=1 --with-debugging=1
> [0]PETSC ERROR: #1 KSPSolve() line 855 in /home/zhaowenbo/research/
> petsc/petsc_git/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #2 PCGAMGOptProlongator_AGG() line 1186 in
> /home/zhaowenbo/research/petsc/petsc_git/src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: #3 PCSetUp_GAMG() line 528 in /home/zhaowenbo/research/
> petsc/petsc_git/src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: #4 PCSetUp() line 924 in /home/zhaowenbo/research/
> petsc/petsc_git/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #5 KSPSetUp() line 378 in /home/zhaowenbo/research/
> [0]PETSC ERROR: #6 STSetUp_Shift() line 129 in /home/zhaowenbo/research/
> slepc/slepc_git/src/sys/classes/st/impls/shift/shift.c
> [0]PETSC ERROR: #7 STSetUp() line 281 in /home/zhaowenbo/research/
> slepc/slepc_git/src/sys/classes/st/interface/stsolve.c
> [0]PETSC ERROR: #8 EPSSetUp() line 273 in /home/zhaowenbo/research/
> slepc/slepc_git/src/eps/interface/epssetup.c
> [0]PETSC ERROR: #9 solve_diffusion_3d() line 1029 in src/diffu.c
> [0]PETSC ERROR: #10 main() line 25 in src/main.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -eps_monitor
> [0]PETSC ERROR: -eps_ncv 10
> [0]PETSC ERROR: -eps_nev 1
> [0]PETSC ERROR: -log_view
> [0]PETSC ERROR: -mata AMAT.dat
> [0]PETSC ERROR: -matb BMAT.dat
> [0]PETSC ERROR: -st_ksp_monitor
> [0]PETSC ERROR: -st_ksp_type gmres
> [0]PETSC ERROR: -st_ksp_view
> [0]PETSC ERROR: -st_pc_gamg_agg_nsmooths 1
> [0]PETSC ERROR: -st_pc_gamg_type agg
> [0]PETSC ERROR: -st_pc_type gamg
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 91.
>   Thanks,
>      Matt
>> Thanks,
>> Wenbo
>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>> wrote:
>>>> Mark,
>>>> Thanks for your reply.
>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor and we
>>>>> can start to debug it.
>>>>> Test 1 with nonsmooth and preonly is OK
>>>> runkr_nonsmooth
>>>>    -st_ksp_view  -mata AMAT.dat -matb BMAT.dat \
>>>>    -st_mg_coarse_ksp_type preonly   -st_mg_coarse_ksp_monitor  \
>>>> Test 2 smooth and preonly is not OK
>>>> Test 3 nonsmooth and gmres is not OK
>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_gmres
>>>>    -st_mg_coarse_ksp_type gmres  -st_mg_coarse_ksp_monitor
>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>> DO NOT DO THIS. Please send the output where you do NOTHING to the
>>> coarse solver.
>>>   Thanks,
>>>      Matt
>>>>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_gmres 2>&1
>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>> make: *** [runkr_gmres] Error 91
>>>> log-files is attached.
>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>> (diffusion). Where does the asymmetry come from?
>>>> It is a two-group diffusion equations, where group denotes neutron
>>>> enegry discretisation.
>>>> Matrix B consists of neutron diffusion/leakage term, removal term and
>>>> minus neutron scatter source term between different energies, when matrix A
>>>> denotes neutron fission source.
>>>> Diffusion term(Laplace operator) is elliptic and symmetric. Removal
>>>> term is diagonal only. However scatter term is asymmetry since scatter term
>>>> from high energy to low energy is far greater than the term from low to
>>>> high.
>>>> Wenbo
>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>>> wrote:
>>>>>> Matt,
>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>> to test those options.
>>>>>> Wenbo
>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com
>>>>>>> > wrote:
>>>>>>>> Matt
>>>>>>>> Because I am not clear about what will happen using 'preonly' for
>>>>>>>> large scale problem.
>>>>>>> The size of the problem has nothing to do with 'preonly'. All it
>>>>>>> means is to apply a preconditioner without a Krylov solver.
>>>>>>>> It seems to use a direct solver from below,
>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>> KSP/KSPPREONLY.html
>>>>>>> However, I still cannot understand why you would change the default?
>>>>>>>   Matt
>>>>>>>> Thanks!
>>>>>>>> Wenbo
>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>>>> Matt,
>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>> But I am not clear about the 'preonly' option. Which solver is
>>>>>>>>>> used in preonly? I wonder if 'preonly' is suitable for large scale problem
>>>>>>>>>> such as 400,000,000 unknowns.
>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>> I mean, why are you setting this at all. Just do not set the
>>>>>>>>> coarse solver. The default should work fine.
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>> Thanks.
>>>>>>>>>> Wenbo
>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve two-group
>>>>>>>>>>>> neutron diffusion equations with finite difference method. The grid is
>>>>>>>>>>>> 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where B is
>>>>>>>>>>>> diagonally dominant matrix but not symmetry.
>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>  ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>  ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only non-smooths
>>>>>>>>>>>> and preonly is OK.
>>>>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>>>>    Thanks,
>>>>>>>>>>>     Matt
>>>>>>>>>>>> Test 1
>>>>>>>>>>>>    -st_ksp_type gmres  \
>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>> Test 2
>>>>>>>>>>>> 2>&1
>>>>>>>>>>>> Test 3
>>>>>>>>>>>> 2>&1
>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and BMAT.dat.
>>>>>>>>>>>> Is it correct? Or something wrong with my code or commad-line?
>>>>>>>>>>>> Thanks!
>>>>>>>>>>>> Wenbo
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/e8c871a6/attachment-0001.html>
