[petsc-users] Issue of mg_coarse_ksp not converge
Mon Oct 2 09:48:48 CDT 2017
On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
wrote:
> Mark,
> Thanks for your reply.
> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Please send the output with -st_ksp_view and -st_ksp_monitor and we can
>> start to debug it.
>> Test 1 with nonsmooth and preonly is OK
> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_nonsmooth
> mpirun -n 1 ./step-41 \
>    -st_ksp_type gmres  -st_ksp_view -st_ksp_monitor  \
>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>    -st_ksp_view  -mata AMAT.dat -matb BMAT.dat \
>    -st_mg_coarse_ksp_type preonly   -st_mg_coarse_ksp_monitor  \
>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_nonsmooth 2>&1
> Test 2 smooth and preonly is not OK
> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_smooth
>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>    -eps_nev 1 -eps_ncv 10  -eps_monitor -log_view > log_smooth 2>&1
> makefile:43: recipe for target 'runkr_smooth' failed
> make: *** [runkr_smooth] Error 91
> Test 3 nonsmooth and gmres is not OK
> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_gmres
>    -st_mg_coarse_ksp_type gmres  -st_mg_coarse_ksp_monitor
> -st_mg_coarse_ksp_rtol 1.0e-6 \
DO NOT DO THIS. Please send the output where you do NOTHING to the coarse
solver.
     Matt
>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_gmres 2>&1
> makefile:59: recipe for target 'runkr_gmres' failed
> make: *** [runkr_gmres] Error 91
> log-files is attached.
> You mentioned that B is not symmetric. I assume it is elliptic
>> (diffusion). Where does the asymmetry come from?
> It is a two-group diffusion equations, where group denotes neutron enegry
> discretisation.
> Matrix B consists of neutron diffusion/leakage term, removal term and
> minus neutron scatter source term between different energies, when matrix A
> denotes neutron fission source.
> Diffusion term(Laplace operator) is elliptic and symmetric. Removal term
> is diagonal only. However scatter term is asymmetry since scatter term from
> high energy to low energy is far greater than the term from low to high.
> Wenbo
>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>> wrote:
>>> Matt,
>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>> to test those options.
>>> Wenbo
>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>> wrote:
>>>>> Matt
>>>>> Because I am not clear about what will happen using 'preonly' for
>>>>> large scale problem.
>>>> The size of the problem has nothing to do with 'preonly'. All it means
>>>> is to apply a preconditioner without a Krylov solver.
>>>>> It seems to use a direct solver from below,
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>> KSP/KSPPREONLY.html
>>>> However, I still cannot understand why you would change the default?
>>>>   Matt
>>>>> Thanks!
>>>>> Wenbo
>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>>>> wrote:
>>>>>>> Matt,
>>>>>>> It DOES make no sense for this problem.
>>>>>>> But I am not clear about the 'preonly' option. Which solver is used
>>>>>>> in preonly? I wonder if 'preonly' is suitable for large scale problem such
>>>>>>> as 400,000,000 unknowns.
>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>> I mean, why are you setting this at all. Just do not set the coarse
>>>>>> solver. The default should work fine.
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> Could you give me some suggestions?
>>>>>>> Thanks.
>>>>>>> Wenbo
>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve two-group
>>>>>>>>> neutron diffusion equations with finite difference method. The grid is
>>>>>>>>> 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where B is
>>>>>>>>> diagonally dominant matrix but not symmetry.
>>>>>>>>> EPS is set as below,
>>>>>>>>>  ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>  ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only non-smooths and
>>>>>>>>> preonly is OK.
>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>    Thanks,
>>>>>>>>     Matt
>>>>>>>>> Test 1
>>>>>>>>>    -st_ksp_type gmres  \
>>>>>>>>> 0 \
>>>>>>>>> 2>&1
>>>>>>>>> Test 2
>>>>>>>>> 1 \
>>>>>>>>> Test 3
>>>>>>>>> 0 \
>>>>>>>>> Log files were attched.
>>>>>>>>> The matrix file were also attched as AMAT.dat and BMAT.dat.
>>>>>>>>> Is it correct? Or something wrong with my code or commad-line?
>>>>>>>>> Thanks!
>>>>>>>>> Wenbo
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/122891dc/attachment.html>
