[petsc-users] Issue of mg_coarse_ksp not converge
Sun Oct 1 11:34:34 CDT 2017
On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com> wrote:
> Hi,
> I met some questions when I use PETSC/SLEPC to solve two-group neutron
> diffusion equations with finite difference method. The grid is 3*3*3, when
> DOF on each points is 2. So the matrix size is 54*54.
> It is generalized eigenvalue problem Ax=\lamda Bx, where B is diagonally
> dominant matrix but not symmetry.
> EPS is set as below,
>  ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>  ierr = EPSSetWhichEigenpairs(eps,EPS_LARGEST_REAL);CHKERRQ(ierr);¬
> Krylovschur is used as eps sovler. GAMG is used as PC.
> I tried agg_nsmooths and mg_coarse_ksp_type. Only non-smooths and preonly
> is OK.
Why are you setting the coarse solver. This makes no sense.
    Matt
> Test 1
> $ make NCORE=1 runkr_nonsmooth
> mpirun -n 1 ./step-41 \
>    -st_ksp_type gmres  \
>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>    -st_ksp_view  -mata AMAT.dat -matb BMAT.dat \
>    -st_mg_coarse_ksp_type preonly   -st_mg_coarse_ksp_monitor  \
>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_nonsmooth 2>&1
> Test 2
> $ make NCORE=1 runkr_smooth
>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>    -eps_nev 1 -eps_ncv 10  -eps_monitor -log_view > log_smooth 2>&1
> makefile:43: recipe for target 'runkr_smooth' failed
> make: *** [runkr_smooth] Error 91
> Test 3
> $ make NCORE=1 runkr_gmres
>    -st_mg_coarse_ksp_type gmres  -st_mg_coarse_ksp_monitor
> -st_mg_coarse_ksp_rtol 1.0e-6 \
>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_gmres 2>&1
> makefile:59: recipe for target 'runkr_gmres' failed
> make: *** [runkr_gmres] Error 91
> Log files were attched.
> The matrix file were also attched as AMAT.dat and BMAT.dat.
> Is it correct? Or something wrong with my code or commad-line?
> Thanks!
> Wenbo
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171001/5290a013/attachment.html>
