[petsc-users] preallocation after DMCreateMatrix?
Matteo Semplice
matteo.semplice at unito.it
Wed Nov 29 06:36:39 CST 2017
On 29/11/2017 12:46, Matthew Knepley wrote:
> On Wed, Nov 29, 2017 at 2:26 AM, Matteo Semplice
> <matteo.semplice at unito.it <mailto:matteo.semplice at unito.it>> wrote:
> On 25/11/2017 02:05, Matthew Knepley wrote:
>> On Fri, Nov 24, 2017 at 4:21 PM, Matteo Semplice
>> Hi.
>> The manual for DMCreateMatrix says "Notes: This properly
>> preallocates the number of nonzeros in the sparse matrix so
>> you do not need to do it yourself", so I got the impression
>> that one does not need to call the preallocation routine for
>> the matrix and indeed in most examples listed in the manual
>> page for DMCreateMatrix this is not done or (KSP tutorial
>> ex4) it is called declaring 0 entries per row.
>> However, if read in a mesh in a DMPlex ore create a DMDA and
>> then call DMCreateMatrix, the resulting matrix errors out
>> when I call MatSetValues. I have currently followed the
>> suggestion of the error message and call MatSetOption(A,
>> MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE), but I'd like to
>> fix this properly.
>> It sounds like your nonzero pattern does not obey the topology.
>> What nonzero pattern are you trying to input?
> Hi.
> The problem with the DMDA was a bug in our code. Sorry for the
> noise.
> On the other hand, with the DMPLex, I still experience problems.
> It's a FV code and I reduced it to the case of the simple case of
> a laplacian operator: I need non-diagonal entries at (i,j) if cell
> i and cell j have a common face.
> Here below is my code that reads in a grid of 4 cells (unit square
> divided by the diagonals), create a section with 1 dof per cell,
> creates a matrix and assembles it.
> ierr = DMPlexCreateFromFile(PETSC_COMM_WORLD, "square1.msh",
> PETSC_TRUE, &dm);CHKERRQ(ierr);
> Can you show me the mesh?
> ierr = DMViewFromOptions(dm, NULL, "-dm_view");CHKERRQ(ierr);
> and then run with -dm_view ::ascii_info_detail
> ierr = DMPlexSetAdjacencyUseCone(dm, PETSC_TRUE); CHKERRQ(ierr);
> ierr = DMPlexSetAdjacencyUseClosure(dm, PETSC_FALSE); CHKERRQ(ierr);
> This looks like the right FVM adjacency, but your matrix is diagonal
> it appears below. TS ex11
> has an identical call, but produces the correct matrix, which is why I
> want to look at your mesh.
I have put the DMViewFromOptions call after the SetAdjacency calls and
this is the output:
matteo at signalkuppe:~/software/petscMplex$ ./mplexMatrix -dm_view
::ascii_info_detail
DM Object: 1 MPI processes
type: plex
Mesh 'DM_0x557496ad8380_0':
orientation is missing
cap --> base:
[0] Max sizes cone: 3 support: 4
[0]: 4 ----> 9
[0]: 4 ----> 11
[0]: 4 ----> 12
[0]: 5 ----> 10
[0]: 5 ----> 11
[0]: 5 ----> 15
[0]: 6 ----> 14
[0]: 6 ----> 15
[0]: 6 ----> 16
[0]: 7 ----> 12
[0]: 7 ----> 13
[0]: 7 ----> 16
[0]: 8 ----> 9
[0]: 8 ----> 10
[0]: 8 ----> 13
[0]: 8 ----> 14
[0]: 9 ----> 0
[0]: 9 ----> 1
[0]: 10 ----> 0
[0]: 10 ----> 2
[0]: 11 ----> 0
[0]: 12 ----> 1
[0]: 13 ----> 1
[0]: 13 ----> 3
[0]: 14 ----> 2
[0]: 14 ----> 3
[0]: 15 ----> 2
[0]: 16 ----> 3
base <-- cap:
[0]: 0 <---- 9 (0)
[0]: 0 <---- 10 (0)
[0]: 0 <---- 11 (0)
[0]: 1 <---- 12 (0)
[0]: 1 <---- 13 (0)
[0]: 1 <---- 9 (-2)
[0]: 2 <---- 10 (-2)
[0]: 2 <---- 14 (0)
[0]: 2 <---- 15 (0)
[0]: 3 <---- 14 (-2)
[0]: 3 <---- 13 (-2)
[0]: 3 <---- 16 (0)
[0]: 9 <---- 4 (0)
[0]: 9 <---- 8 (0)
[0]: 10 <---- 8 (0)
[0]: 10 <---- 5 (0)
[0]: 11 <---- 5 (0)
[0]: 11 <---- 4 (0)
[0]: 12 <---- 4 (0)
[0]: 12 <---- 7 (0)
[0]: 13 <---- 7 (0)
[0]: 13 <---- 8 (0)
[0]: 14 <---- 8 (0)
[0]: 14 <---- 6 (0)
[0]: 15 <---- 6 (0)
[0]: 15 <---- 5 (0)
[0]: 16 <---- 7 (0)
[0]: 16 <---- 6 (0)
coordinates with 1 fields
field 0 with 2 components
Process 0:
( 4) dim 2 offset 0 0. 0.
( 5) dim 2 offset 2 0. 1.
( 6) dim 2 offset 4 1. 1.
( 7) dim 2 offset 6 1. 0.
( 8) dim 2 offset 8 0.5 0.5
For the records, the mesh is loaded from the (gmsh generated) file
==== square1.msh =====
$MeshFormat
2.2 0 8
$EndMeshFormat
$Nodes
5
1 0 0 0
2 0 1 0
3 1 1 0
4 1 0 0
5 0.5 0.5 0
$EndNodes
$Elements
12
1 15 2 0 1 1
2 15 2 0 2 2
3 15 2 0 3 3
4 15 2 0 4 4
5 1 2 0 1 4 3
6 1 2 0 2 3 2
7 1 2 0 3 2 1
8 1 2 0 4 1 4
9 2 2 0 6 1 5 2
10 2 2 0 6 1 4 5
11 2 2 0 6 2 5 3
12 2 2 0 6 3 5 4
$EndElements
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171129/c60c54c5/attachment.html>
