[petsc-users] preallocation after DMCreateMatrix?
Matteo Semplice matteo.semplice at unito.it
Wed Nov 29 02:26:35 CST 2017
On 25/11/2017 02:05, Matthew Knepley wrote:
> On Fri, Nov 24, 2017 at 4:21 PM, Matteo Semplice
> <matteo.semplice at unito.it <mailto:matteo.semplice at unito.it>> wrote:
>     Hi.
>     The manual for DMCreateMatrix says "Notes: This properly
>     preallocates the number of nonzeros in the sparse matrix so you do
>     not need to do it yourself", so I got the impression that one does
>     not need to call the preallocation routine for the matrix and
>     indeed in most examples listed in the manual page for
>     DMCreateMatrix this is not done or (KSP tutorial ex4) it is called
>     declaring 0 entries per row.
>     However, if read in a mesh in a DMPlex ore create a DMDA and then
>     call DMCreateMatrix, the resulting matrix errors out when I call
>     MatSetValues. I have currently followed the suggestion of the
>     error message and call MatSetOption(A,
>     MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE), but I'd like to fix
>     this properly.
> It sounds like your nonzero pattern does not obey the topology. What
> nonzero pattern are you trying to input?
Hi.
     The problem with the DMDA was a bug in our code. Sorry for the noise.
On the other hand, with the DMPLex, I still experience problems. It's a
FV code and I reduced it to the case of the simple case of a laplacian
operator: I need non-diagonal entries at (i,j) if cell i and cell j have
a common face.
Here below is my code that reads in a grid of 4 cells (unit square
divided by the diagonals), create a section with 1 dof per cell, creates
a matrix and assembles it.
   ierr = DMPlexCreateFromFile(PETSC_COMM_WORLD, "square1.msh",
PETSC_TRUE, &dm);CHKERRQ(ierr);
   ierr = DMPlexSetAdjacencyUseCone(dm, PETSC_TRUE); CHKERRQ(ierr);
   ierr = DMPlexSetAdjacencyUseClosure(dm, PETSC_FALSE); CHKERRQ(ierr);
   ierr = DMPlexComputeGeometryFVM(dm, &ctx.cellgeom, &ctx.facegeom);
CHKERRQ(ierr);
   PetscInt nFields = 1, numComp[1];
   ierr = DMGetDimension(dm, &ctx.dim);CHKERRQ(ierr);
   /* u has 1 dof on each cell */
   numComp[0] = 1;
   PetscInt *numDofs;
   ierr = PetscCalloc1(nFields*(ctx.dim+1), &numDofs); CHKERRQ(ierr);
   numDofs[0*(ctx.dim+1)+ctx.dim] = 1;
   /* Create a PetscSection with this data layout */
   PetscSection   section;
   DMPlexCreateSection(dm, ctx.dim, nFields, numComp, numDofs, 0, NULL,
NULL, NULL, NULL, &section);
   ierr = PetscFree(numDofs); CHKERRQ(ierr);
   PetscSectionSetFieldName(section, 0, "u");
   /* Tell the DM to use this data layout */
   DMSetDefaultSection(dm, section);
   PetscSectionDestroy(&section);
   /* Print out the list of cells */
   printCells(dm,ctx);
   //Assemble the system
   Mat A;
   PetscPrintf(PETSC_COMM_WORLD,"Creating matrix\n");
   ierr = DMCreateMatrix(dm,&A);CHKERRQ(ierr);
   ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE);CHKERRQ(ierr);
   //ierr = MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR,
PETSC_FALSE);CHKERRQ(ierr);
   PetscPrintf(PETSC_COMM_WORLD,"Assembling matrix\n");
   ierr = assembleMatrix(dm,ctx,A);CHKERRQ(ierr);
An error is generated when the assembleMatrix function tried to insert
an element at position (0,1) of the matrix. When running with the
-mat_view option I get the following output.
matteo:~/software/petscMplex$ ./mplexMatrix -mat_view
0] Le celle sono i nodi da 0 a 3 nel DMPlex
0]  cell 0 has centroid (0.166667, 0.500000) and volume 0.250000
0]       has 3 faces: 9 10 11
0]  cell 1 has centroid (0.500000, 0.166667) and volume 0.250000
0]       has 3 faces: 12 13 9
0]  cell 2 has centroid (0.500000, 0.833333) and volume 0.250000
0]       has 3 faces: 10 14 15
0]  cell 3 has centroid (0.833333, 0.500000) and volume 0.250000
0]       has 3 faces: 14 13 16
Creating matrix
Mat Object: 1 MPI processes
   type: seqaij
row 0: (0, 0.)
row 1: (1, 0.)
row 2: (2, 0.)
row 3: (3, 0.)
Assembling matrix
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: New nonzero at (0,1) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
off this check
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
[0]PETSC ERROR: ./mplexMatrix on a x86_64-linux-gnu-real named
signalkuppe by matteo Wed Nov 29 09:10:12 2017
[0]PETSC ERROR: Configure options --build=x86_64-linux-gnu --prefix=/usr
--includedir=${prefix}/include --mandir=${prefix}/share/man
--infodir=${prefix}/share/info --sysconfdir=/etc --localstatedir=/var
--with-silent-rules=0 --libdir=${prefix}/lib/x86_64-linux-gnu
--libexecdir=${prefix}/lib/x86_64-linux-gnu --with-maintainer-mode=0
--with-dependency-tracking=0 --with-debugging=0
--shared-library-extension=_real --with-clanguage=C++
--with-shared-libraries --with-pic=1 --useThreads=0
--with-fortran-interfaces=1
--with-mpi-dir=/usr/lib/x86_64-linux-gnu/openmpi --with-blas-lib=-lblas
--with-lapack-lib=-llapack --with-blacs=1
--with-blacs-lib="-lblacsCinit-openmpi -lblacs-openmpi"
--with-scalapack=1 --with-scalapack-lib=-lscalapack-openmpi
--with-mumps=1 --with-mumps-include="[]" --with-mumps-lib="-ldmumps
-lzmumps -lsmumps -lcmumps -lmumps_common -lpord" --with-suitesparse=1
--with-suitesparse-include=/usr/include/suitesparse
--with-suitesparse-lib="-lumfpack -lamd -lcholmod -lklu"
--with-spooles=1 --with-spooles-include=/usr/include/spooles
--with-spooles-lib=-lspooles --with-ptscotch=1
--with-ptscotch-include=/usr/include/scotch
--with-ptscotch-lib="-lptesmumps -lptscotch -lptscotcherr" --with-fftw=1
--with-fftw-include="[]" --with-fftw-lib="-lfftw3 -lfftw3_mpi"
--with-superlu=1 --with-superlu-include=/usr/include/superlu
--with-superlu-lib=-lsuperlu --with-hdf5=1
--with-hdf5-dir=/usr/lib/x86_64-linux-gnu/hdf5/openmpi
--CXX_LINKER_FLAGS=-Wl,--no-as-needed --with-hypre=1
--with-hypre-include=/usr/include/hypre --with-hypre-lib="-lHYPRE_IJ_mv
-lHYPRE_parcsr_ls -lHYPRE_sstruct_ls -lHYPRE_sstruct_mv
-lHYPRE_struct_ls -lHYPRE_struct_mv -lHYPRE_utilities"
--prefix=/usr/lib/petscdir/3.7.5/x86_64-linux-gnu-real
PETSC_DIR=/build/petsc-XG7COe/petsc-3.7.5+dfsg1
--PETSC_ARCH=x86_64-linux-gnu-real CFLAGS="-g -O2
-fdebug-prefix-map=/build/petsc-XG7COe/petsc-3.7.5+dfsg1=.
-fstack-protector-strong -Wformat -Werror=format-security -fPIC"
CXXFLAGS="-g -O2
FCFLAGS="-g -O2
-fstack-protector-strong -fPIC" FFLAGS="-g -O2
-fstack-protector-strong -fPIC" CPPFLAGS="-Wdate-time
-D_FORTIFY_SOURCE=2" LDFLAGS="-Wl,-z,relro -fPIC" MAKEFLAGS=w
[0]PETSC ERROR: #1 MatSetValues_SeqAIJ() line 485 in
/build/petsc-XG7COe/petsc-3.7.5+dfsg1/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: #2 MatSetValues() line 1190 in
/build/petsc-XG7COe/petsc-3.7.5+dfsg1/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 assembleMatrix() line 150 in
/home/matteo/software/petscMplex/mplexMatrix.cpp
[0]PETSC ERROR: #4 main() line 202 in
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -mat_view
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 63.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I guess that the matrix is created with only diagonal entries... ?
(The same happens with 3.8.0 from debian experimental)
     Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171129/829bf89a/attachment.html>
