[petsc-users] Petcs preconditioners
    Edoardo alinovi
    edoardo.alinovi at gmail.com
    Mon Nov 27 04:54:40 CST 2017
Dear users,
Since this mailing list has already solved  one of my problem, I would like
to take advantage of your knowlege one more time (thank you so much!).
I am a new user (Fortran) and, as you can imagine, I have a lot of
questions.
Actually, some of them are about preconditioners. In particular I would
like to ask:
- I'm dealing with matrices that change the value of the coeffs in time,
but maintain the same zero pattern. Is it possible to create a ksp (linear
solver + preconditioner) object before the time loop and pass it to the
solver subroutine, avoiding the construction/destruction every iteration?
In this case, is the preconditioner updated each iteration?
- Is the ILU suitable for parallel matrix format (MPIAIJ)? Is there in
petsc the  DILU (diagonal ILU) preconditioner?
-  I would like to use a multigrid preconditioner. Is it better to use GAMG
or boomerAMG in your opinion? In the manual there are a lot of options that
create a mess in my head... Would you so kind to post a standard example of
settings for GAMG/boomerAMG?
Every hint will be very appreciated.
Thank you very much and sorry for the newby questions,
Edoardo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171127/4b983be7/attachment.html>
