[petsc-users] preallocation after DMCreateMatrix?
Matteo Semplice
matteo.semplice at unito.it
Fri Nov 24 15:21:55 CST 2017
Hi.
The manual for DMCreateMatrix says "Notes: This properly preallocates
the number of nonzeros in the sparse matrix so you do not need to do it
yourself", so I got the impression that one does not need to call the
preallocation routine for the matrix and indeed in most examples listed
in the manual page for DMCreateMatrix this is not done or (KSP tutorial
ex4) it is called declaring 0 entries per row.
However, if read in a mesh in a DMPlex ore create a DMDA and then call
DMCreateMatrix, the resulting matrix errors out when I call
MatSetValues. I have currently followed the suggestion of the error
message and call MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR,
PETSC_FALSE), but I'd like to fix this properly.
How should I interpret that note in the manual?
Matteo
