[petsc-users] crash with PCASM in parallel
Daniel Stone
daniel.stone at opengosim.com
Fri Nov 24 10:03:56 CST 2017
Hello,
I'm getting a memory exception crash every time I try to run the ASM
preconditioner in parallel, can anyone help?
I'm using a debugger so I can give most of the stack:
PCApply_ASM (asm.c:line 485)
KSPSolve (itfunc.c:line 599)
KSPSetUp (itfunc.c:line 379)
PCSetUp (precon.c: 924)
PCSetUp_ILU (ilu.c:line 162)
MatDestroy (matrix.c:line 1168)
MatDestroy_MPIBAIJ_MatGetSubMatrices (baijov.c:line 609)
The problem line is then in MatDestroy_MPIBAIJ_MatGetSubMatrices,
in the file baijov.c, line 609:
if (!submatj->id) {
At this point submatj has no value, address 0x0, and so the attempt to
access submatj->id
causes the memory error. We can see in the lines just above 609 where
submatj is supposed to
come from, it should basically be an attribute of C->data, where C is the
input matrix.
Does anyone have any ideas where to start with getting this to work? I can
provide a lot more information
from the debugger if need.
Many thanks in advance,
Daniel Stone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171124/e9bd1543/attachment.html>
