[petsc-users] TAO: Finite Difference vs Continuous Adjoint gradient issues
Zhang, Hong hongzhang at anl.gov
Wed Nov 22 10:20:48 CST 2017
Hi Julian,
If I remember correctly, you have a code that worked fine with discrete adjoint (TSAdjoint). Was it for the same example? If so, how are the differences in the validation output between continuous adjoint and discrete adjoint?
Hong (Mr.)
> On Nov 22, 2017, at 3:48 AM, Julian Andrej <juan at tf.uni-kiel.de> wrote:
> Hello,
> we prepared a small example which computes the gradient via the continuous adjoint method of a heating problem with a cost functional.
> We implemented the text book example and tested the gradient via a Taylor Remainder (which works fine). Now we wanted to solve the
> optimization problem with TAO and checked the gradient vs. the finite difference gradient and run into problems.
> Testing hand-coded gradient (hc) against finite difference gradient (fd), if the ratio ||fd - hc|| / ||hc|| is
> 0 (1.e-8), the hand-coded gradient is probably correct.
> Run with -tao_test_display to show difference
> between hand-coded and finite difference gradient.
> ||fd|| 0.000147076, ||hc|| = 0.00988136, angle cosine = (fd'hc)/||fd||||hc|| = 0.99768
> 2-norm ||fd-hc||/max(||hc||,||fd||) = 0.985151, difference ||fd-hc|| = 0.00973464
> max-norm ||fd-hc||/max(||hc||,||fd||) = 0.985149, difference ||fd-hc|| = 0.00243363
> ||fd|| 0.000382547, ||hc|| = 0.0257001, angle cosine = (fd'hc)/||fd||||hc|| = 0.997609
> 2-norm ||fd-hc||/max(||hc||,||fd||) = 0.985151, difference ||fd-hc|| = 0.0253185
> max-norm ||fd-hc||/max(||hc||,||fd||) = 0.985117, difference ||fd-hc|| = 0.00624562
> ||fd|| 8.84429e-05, ||hc|| = 0.00594196, angle cosine = (fd'hc)/||fd||||hc|| = 0.997338
> 2-norm ||fd-hc||/max(||hc||,||fd||) = 0.985156, difference ||fd-hc|| = 0.00585376
> max-norm ||fd-hc||/max(||hc||,||fd||) = 0.985006, difference ||fd-hc|| = 0.00137836
> Despite these differences we achieve convergence with our hand coded gradient, but have to use -tao_ls_type unit.
> $ python heat_adj.py -tao_type blmvm -tao_view -tao_monitor -tao_gatol 1e-7 -tao_ls_type unit
> iter =   0, Function value: 0.000316722,  Residual: 0.00126285
> iter =   1, Function value: 3.82272e-05,  Residual: 0.000438094
> iter =   2, Function value: 1.26011e-07,  Residual: 8.4194e-08
> Tao Object: 1 MPI processes
>  type: blmvm
>      Gradient steps: 0
>  TaoLineSearch Object: 1 MPI processes
>    type: unit
>  Active Set subset type: subvec
>  convergence tolerances: gatol=1e-07,   steptol=0.,   gttol=0.
>  Residual in Function/Gradient:=8.4194e-08
>  Objective value=1.26011e-07
>  total number of iterations=2,                          (max: 2000)
>  total number of function/gradient evaluations=3,      (max: 4000)
>  Solution converged:    ||g(X)|| <= gatol
> $ python heat_adj.py -tao_type blmvm -tao_view -tao_monitor -tao_fd_gradient
> iter =   0, Function value: 0.000316722,  Residual: 4.87343e-06
> iter =   1, Function value: 0.000195676,  Residual: 3.83011e-06
> iter =   2, Function value: 1.26394e-07,  Residual: 1.60262e-09
>  type: blmvm
>      Gradient steps: 0
>    type: more-thuente
>  convergence tolerances: gatol=1e-08,   steptol=0.,   gttol=0.
>  Residual in Function/Gradient:=1.60262e-09
>  Objective value=1.26394e-07
>  total number of function/gradient evaluations=3474,      (max: 4000)
> We think, that the finite difference gradient should be in line with our hand coded gradient for such a simple example.
> We appreciate any hints on debugging this issue. It is implemented in python (firedrake) and i can provide the code if this is needed.
> Regards
> Julian
