[petsc-users] Compilation error with ifort: invalid return statement in main
Smith, Barry F. bsmith at mcs.anl.gov
Sun Nov 19 09:48:55 CST 2017
      In some of the Fortran examples we have code like
      call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
      if (ierr .ne. 0) then
         print*,'Unable to initialize PETSc'
         stop
      endif
      Eventually we should update all the examples with this, or something even better.
   Barry
> On Nov 19, 2017, at 6:12 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> El 19 nov 2017, a las 13:08, Matthew Knepley <knepley at gmail.com> escribió:
>> On Sun, Nov 19, 2017 at 4:43 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> El 19 nov 2017, a las 10:16, Praveen C <cpraveen at gmail.com> escribió:
>>> Dear all
>>> In the main program, if I have a line like
>>>  call PetscInitialize('param.in', ierr); CHKERRQ(ierr)
>>> compiling with mpifort gives
>>> main.f95(17): error #6353: A RETURN statement is invalid in the main program.
>>>  call PetscInitialize('param.in', ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
>>> It compiles fine with gfortran. What can I do for the ifort case ?
>>> Thanks
>>> praveen
>> Use CHKERRA(ierr) in the main program and CHKERRQ(ierr) in the subroutines.
>> On the other hand, you should not use CHKERRA(ierr) after PetscInitialize
>> Do you mean after PetscFinalize()? You should not call any PETSc functions after this.
> I mean to check the error code returned by PetscInitialize().
> In C examples it is done this way
>  ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return ierr;
> instead of with CHKERRQ.
>>  Thanks,
>>    Matt
>> because it assumes that MPI has been correctly initialized.
>> Jose
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
