[petsc-users] Auxiliary fields for multigrid
Jed Brown
jed at jedbrown.org
Sun Nov 19 08:20:14 CST 2017
"zakaryah ." <zakaryah at gmail.com> writes:
> Ok, thanks for the suggestions.
> I'd like to check that I understand the approach.
> I create one DMDA for the variables to be solved by the SNES. That DMDA
> will be coarsened and refined by the options I pass to e.g. FAS. In my
> user context struct, I can have a second DMDA for the auxiliary fields. At
> each coarsening or refinement of the solution variable DMDA, I add a hook
> to simultaneously coarsen or refine the auxiliary fields. I suppose I can
> store the results of those operations in a third DMDA in the user context
> struct, because I'll need to access them from the SNES Function and
> Jacobian routines. Does that sound right?
Basically, please look at the example.
