[petsc-users] Compilation error with ifort: invalid return statement in main
Sun Nov 19 06:08:57 CST 2017
On Sun, Nov 19, 2017 at 4:43 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> > El 19 nov 2017, a las 10:16, Praveen C <cpraveen at gmail.com> escribió:
> > Dear all
> > In the main program, if I have a line like
> >   call PetscInitialize('param.in', ierr); CHKERRQ(ierr)
> > compiling with mpifort gives
> > main.f95(17): error #6353: A RETURN statement is invalid in the main
> program.
> >   call PetscInitialize('param.in', ierr); if (ierr .ne. 0) then ; call
> PetscErrorF(ierr); return; endif
> > It compiles fine with gfortran. What can I do for the ifort case ?
> > Thanks
> > praveen
> Use CHKERRA(ierr) in the main program and CHKERRQ(ierr) in the subroutines.
> On the other hand, you should not use CHKERRA(ierr) after PetscInitialize
Do you mean after PetscFinalize()? You should not call any PETSc functions
after this.
    Matt
> because it assumes that MPI has been correctly initialized.
> Jose
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171119/19c03f79/attachment.html>
