[petsc-users] Auxiliary fields for multigrid
Dave May dave.mayhem23 at gmail.com
Fri Nov 17 06:47:54 CST 2017
On Fri, 17 Nov 2017 at 04:26, zakaryah . <zakaryah at gmail.com> wrote:
> I have equations which depend on some external data.  I'm not sure about
> the approach for making this compatible with multigrid - i.e. making sure
> those external fields are properly refined/coarsened.
Multi grid does not strictly require you to restrict your external data.
For example (I) algebraic mg (PCGAMG) only requires only the fine level
operator: (I) you can define coarse level operators with geometric mg using
Galerkin projection. The latter only requires one to specify how to
interpolate your DM fields from fine to coarse (which PLEX and DA provide).
Why not try these out for your problem first?
Are there PETSc examples that do this?
Not that I'm aware off. Most use Galerkin or rediscretize the operator on
the coarser levels.
  Dave
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171117/5ac04ed9/attachment.html>
