[petsc-users] Possible to recover ILU(k) from hypre/pilut?
Matthew Knepley
knepley at gmail.com
Thu Nov 16 06:53:02 CST 2017
On Wed, Nov 15, 2017 at 10:57 PM, Mark Lohry <mlohry at gmail.com> wrote:
> What are the limitations of ILU in parallel you're referring to? Does
> Schwarz+local ILU typically fare better?
Anecdotally, the sweet spot for ILU(k) k > 0 is extremely small. For
smaller problems, sparse direct is so good its
hard to win with ILU(k) since you do at least a few iterates. For larger
problems, ILU(k) runs out of gas or memory
fairly fast, and its better to find a method tailored to the problem.
Matt
> On Nov 15, 2017 10:50 PM, "Smith, Barry F." <bsmith at mcs.anl.gov> wrote:
>> > On Nov 15, 2017, at 9:40 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> >>> On Nov 15, 2017, at 6:38 AM, Mark Lohry <mlohry at gmail.com> wrote:
>> >>> I've found ILU(0) or (1) to be working well for my problem, but the
>> petsc implementation is serial only. Running with -pc_type hypre
>> -pc_hypre_type pilut with default settings has considerably worse
>> convergence. I've tried using -pc_hypre_pilut_factorrowsize (number of
>> actual elements in row) to trick it into doing ILU(0), to no effect.
>> >>> Is there any way to recover classical ILU(k) from pilut?
>> >>> Hypre's docs state pilut is no longer supported, and Euclid should be
>> used for anything moving forward. pc_hypre_boomeramg has options for Euclid
>> smoothers. Any hope of a pc_hypre_type euclid?
>> >> Not unless someone outside the PETSc team decides to put it back in.
>> > PETSc used to have a Euclid interface. My recollection is that Barry
>> > removed it because users were finding too many bugs in Euclid and
>> > upstream wasn't fixing them. A contributed revival of the interface
>> > won't fix the upstream problem.
>> The hypre team now claims they care about Euclid. But given the
>> limitations of ILU in parallel I can't imagine anyone cares all that much.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171116/a81ace12/attachment-0001.html>
