[petsc-users] ISGlobalToLocalMappingApplyBlock
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Wed Nov 15 16:52:10 CST 2017
I actually attached the wrong test program last time- I've attached the
right one here, which is much simpler. It test global indices 0, 1, ... 9.
If I run on 2 processes, the local indices it returns are:
rank 0: 0, 1, 2, 3, 4, 0, 0, 0, -253701943, 0
rank 1: -1, -1, -1, -1, -1, -1, -1, -1, -1, -1
The results I expected are:
rank 0: 0, 1, 2, 3, 4, -1, -1, -1, -1, -1
rank 1: -1, -1, -1, -1, -1, 0, 1, 2, 3, 4
So the results for global indices 0, 1,... 4 are what I expected, on
both ranks. But the results for global indices 5, 6, ... 9 are not.
I tried increasing the blocksize to 3 or 4, and the results were exactly
the same.
It only gives the results I expected if I change the blocksize to 1.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171116/ce50cc97/attachment.bin>
