[petsc-users] ISGlobalToLocalMappingApplyBlock
Adrian Croucher a.croucher at auckland.ac.nz
Tue Nov 14 22:54:55 CST 2017
hi
I'm trying to use ISGlobalToLocalMappingApplyBlock() and am a bit
puzzled about the results it's giving.
I've attached a small test to illustrate. It just sets up a
local-to-global mapping with 10 elements. Running on two processes the
first has global indices 0 - 4 and the the second has 5 - 9. I then try
to find the local index corresponding to global index 8.
If I set the blocksize parameter to 1, it correctly gives the results -1
on rank 0 and 3 on rank 1.
But if I set the blocksize to 2 (or more), the results are -253701943 on
rank 0 and -1 on rank 1. Neither of these are what I expected- I thought
they should be the same as in the blocksize 1 case.
I'm presuming the global indices I pass in to
ISGlobalToLocalMappingApplyBlock() should be global block indices (i.e.
not scaled up by blocksize). If I do scale them up it doesn't give the
answers I expect either.
Or am I wrong to expect this to give the same results regardless of
blocksize?
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171115/1a9bed91/attachment.bin>
