[petsc-users] unsorted local columns in 3.8?
    Mark Adams
    mfadams at lbl.gov
    Fri Nov 10 19:40:17 CST 2017
On Fri, Nov 10, 2017 at 6:09 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Satish :
>> I don't see any changes hzhang/fix-submat_samerowdist in past few
>> days. So how did this error get fixed?
> I've never seen valgrind error for ex56 from nightly tests.
> Mark told me about Valgrind error on his mac,
Valgrind segv'ed on my Mac. (This makes me suspicious because valgrind has
been working OK for my on my Mac, but let move on.) I ran on Linux (CG at
ANL) and it ran fine.
The error that Hong is seeing is in LAPACK. I download LAPACK (on CG, not
my Mac) but Hong does not seem to be downloading LAPACK. So I think that
the lapack that configure is picking up throwing these valgrind warnings.
and I reproduced it on our linux machine with my own configure,
which directs to lapack.
>> please do not merge yet.
> Sure.
> Hong
>> On Fri, 10 Nov 2017, Mark Adams wrote:
>> > I don't see a problem with this. As far as what branch to merge it into,
>> > that is a Barry/Satish/etc decision.
>> > On Fri, Nov 10, 2017 at 5:17 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> > > Mark:
>> > >> I would add:
>> > >>     '--download-fblaslapack=1',
>> > >> This is what I have on my Linux machine (cg at ANL) and it runs
>> clean.
>> > > I do not see any error report from nightly tests for ex56. Should I
>> merge
>> > > this branch to maint?
>> > > Hong
>> > >> On Fri, Nov 10, 2017 at 11:03 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> > >>> I use
>> > >>> Using configure Options: --download-metis --download-mpich
>> > >>> --download-mumps --download-parmetis --download-scalapack
>> > >>> --download-superlu --download-superlu_dist --download-suitesparse
>> > >>> --download-hypre --download-ptscotch --download-chaco
>> --with-ctable=1
>> > >>> --download-cmake --with-cc=gcc --with-cxx=g++ --with-debugging=1
>> > >>> --with-visibility=0 --with-fc=gfortran
>> > >>> Hong
>> > >>> On Fri, Nov 10, 2017 at 9:59 AM, Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > >>>> This must be a configure issue. I don't see these warning:
>> > >>>> #!/usr/bin/python
>> > >>>> if __name__ == '__main__':
>> > >>>>   import sys
>> > >>>>   import os
>> > >>>>   sys.path.insert(0, os.path.abspath('config'))
>> > >>>>   import configure
>> > >>>>   configure_options = [
>> > >>>>     '--with-cc=clang',
>> > >>>>     '--with-cc++=clang++',
>> > >>>>     '--download-mpich=1',
>> > >>>>     '--download-metis=1',
>> > >>>>     '--download-superlu=1',
>> > >>>>     '--download-superlu_dist=1',
>> > >>>>     '--download-parmetis=1',
>> > >>>>     '--download-p4est=1',
>> > >>>>     '--with-debugging=1',
>> > >>>>     '--with-batch=0',
>> > >>>>     'PETSC_ARCH=arch-linux2-c-dbg32',
>> > >>>>     '--with-openmp=0',
>> > >>>>     '--download-p4est=0'
>> > >>>>   configure.petsc_configure(configure_options)
>> > >>>> On Fri, Nov 10, 2017 at 10:56 AM, Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > >>>>> This is comming from blas. How did you configure blas?
>> > >>>>> On Fri, Nov 10, 2017 at 10:38 AM, Hong <hzhang at mcs.anl.gov>
>> wrote:
>> > >>>>>> Using petsc machine, I get
>> > >>>>>> hzhang at petsc /sandbox/hzhang/petsc/src/snes/examples/tutorials
>> > >>>>>> (hzhang/fix-submat_samerowdist)
>> > >>>>>> $ mpiexec -n 2 valgrind ./ex56 -cells 2,2,1 -max_conv_its 3
>> > >>>>>> -petscspace_order 2 -snes_max_it 2 -ksp_max_it 100 -ksp_type cg
>> -ksp_rtol
>> > >>>>>> 1.e-11 -ksp_norm_type unpreconditioned -snes_rtol 1.e-10
>> -pc_type gamg
>> > >>>>>> -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
>> -pc_gamg_coarse_eq_limit 10
>> > >>>>>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>> > >>>>>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0
>> -snes_converged_reason
>> > >>>>>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1
>> -mg_levels_ksp_type
>> > >>>>>> chebyshev -mg_levels_esteig_ksp_type cg
>> -mg_levels_esteig_ksp_max_it 10
>> > >>>>>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type
>> > >>>>>> jacobi -pc_gamg_mat_partitioning_type parmetis -mat_block_size 3
>> -run_type 1
>> > >>>>>> ==28811== Memcheck, a memory error detector
>> > >>>>>> ==28811== Copyright (C) 2002-2013, and GNU GPL'd, by Julian
>> Seward et
>> > >>>>>> al.
>> > >>>>>> ==28811== Using Valgrind-3.10.1 and LibVEX; rerun with -h for
>> > >>>>>> copyright info
>> > >>>>>> ==28811== Command: ./ex56 -cells 2,2,1 -max_conv_its 3
>> -ksp_rtol
>> -pc_type gamg
>> -mg_levels_ksp_type
>> -run_type 1
>> > >>>>>> ==28811== Invalid read of size 16
>> > >>>>>> ==28811==    at 0x8550946: dswap_k_NEHALEM (in
>> > >>>>>> /usr/lib/openblas-base/libblas.so.3)
>> > >>>>>> ==28811==    by 0x7C6797F: dswap_ (in
>> > >>>>>> .so.3)
>> > >>>>>> ==28811==    by 0x75B33B2: dgetri_ (in
>> /usr/lib/lapack/liblapack.so.3
>> > >>>>>> .0)
>> > >>>>>> ==28811==    by 0x5E3CA5C: PetscFESetUp_Basic (dtfe.c:4012)
>> > >>>>>> ==28811==    by 0x5E320C9: PetscFESetUp (dtfe.c:3274)
>> > >>>>>> ==28811==    by 0x5E5786F: PetscFECreateDefault (dtfe.c:6749)
>> > >>>>>> ==28811==    by 0x41056E: main (ex56.c:395)
>> > >>>>>> ==28811==  Address 0xdc650d0 is 52,480 bytes inside a block of
>> size
>> > >>>>>> 52,488 alloc'd
>> > >>>>>> ==28811==    at 0x4C2D110: memalign (in
>> /usr/lib/valgrind/vgpreload_me
>> > >>>>>> mcheck-amd64-linux.so)
>> > >>>>>> ==28811==    by 0x51590F6: PetscMallocAlign (mal.c:39)
>> > >>>>>> ==28811==    by 0x5E3C169: PetscFESetUp_Basic (dtfe.c:3983)
>> > >>>>>> ==28811==
>> > >>>>>> ==28812== Invalid read of size 16
>> > >>>>>> ==28812==    at 0x8550946: dswap_k_NEHALEM (in
>> > >>>>>> ==28812==    by 0x7C6797F: dswap_ (in
>> > >>>>>> .so.3)
>> > >>>>>> ==28812==    by 0x75B33B2: dgetri_ (in
>> > >>>>>> .0)
>> > >>>>>> ==28812==    by 0x5E3CA5C: PetscFESetUp_Basic (dtfe.c:4012)
>> > >>>>>> ==28812==    by 0x5E320C9: PetscFESetUp (dtfe.c:3274)
>> > >>>>>> ==28812==    by 0x5E5786F: PetscFECreateDefault (dtfe.c:6749)
>> > >>>>>> ==28812==    by 0x41056E: main (ex56.c:395)
>> > >>>>>> ==28812==  Address 0xd9c7600 is 52,480 bytes inside a block of
>> size
>> > >>>>>> 52,488 alloc'd
>> > >>>>>> ==28812==    at 0x4C2D110: memalign (in
>> > >>>>>> ==28812==    by 0x51590F6: PetscMallocAlign (mal.c:39)
>> > >>>>>> ==28812==    by 0x5E3C169: PetscFESetUp_Basic (dtfe.c:3983)
>> > >>>>>> ==28812==
>> > >>>>>> ==28811==    at 0x8550A55: dswap_k_NEHALEM (in
>> > >>>>>> .so.3)
>> > >>>>>> ==28811==    by 0x7675179: dsteqr_ (in
>> > >>>>>> .0)
>> > >>>>>> ==28811==    by 0x5DFFA22: PetscDTGaussQuadrature (dt.c:508)
>> > >>>>>> ==28811==    by 0x5E00BD8: PetscDTGaussTensorQuadrature
>> (dt.c:582)
>> > >>>>>> ==28811==    by 0x5E57D7A: PetscFECreateDefault (dtfe.c:6763)
>> > >>>>>> ==28811==  Address 0xd99cbe0 is 64 bytes inside a block of size
>> 72
>> > >>>>>> alloc'd
>> > >>>>>> ==28811==    by 0x5DFF766: PetscDTGaussQuadrature (dt.c:504)
>> (dt.c:582)
>> > >>>>>> ==28811==
>> > >>>>>> ==28812==    at 0x8550A55: dswap_k_NEHALEM (in
>> > >>>>>> .so.3)
>> > >>>>>> ==28812==    by 0x7675179: dsteqr_ (in
>> > >>>>>> .0)
>> > >>>>>> ==28812==    by 0x5DFFA22: PetscDTGaussQuadrature (dt.c:508)
>> > >>>>>> ==28812==    by 0x5E00BD8: PetscDTGaussTensorQuadrature
>> (dt.c:582)
>> > >>>>>> ==28812==    by 0x5E57D7A: PetscFECreateDefault (dtfe.c:6763)
>> > >>>>>> ==28812==  Address 0xdc11f30 is 64 bytes inside a block of size
>> 72
>> > >>>>>> alloc'd
>> > >>>>>> ==28812==    by 0x5DFF766: PetscDTGaussQuadrature (dt.c:504)
>> (dt.c:582)
>> > >>>>>> ==28812==
>> > >>>>>> [0] 27 global equations, 9 vertices
>> > >>>>>> [0] 27 equations in vector, 9 vertices
>> > >>>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
>> iterations 1
>> > >>>>>> [0] 441 global equations, 147 vertices
>> > >>>>>> [0] 441 equations in vector, 147 vertices
>> > >>>>>> hangs here ...
>> > >>>>>> Hong
>> > >>>>>> On Fri, Nov 10, 2017 at 8:57 AM, Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > >>>>>>> This printed a little funny in gmail, snes/ex56 is running
>> clean in
>> > >>>>>>> the first few loops (appended), but the last one is the one
>> with a reduced
>> > >>>>>>> processor set. Still waiting. This is with 32 bit integers. I'm
>> running
>> > >>>>>>> another with 64 bit integers.
>> iterations
>> > >>>>>>> 1
>> iterations
>> > >>>>>>> 1
>> > >>>>>>> [0] 4725 global equations, 1575 vertices
>> > >>>>>>> [0] 4725 equations in vector, 1575 vertices
>> > >>>>>>> On Fri, Nov 10, 2017 at 9:06 AM, Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > >>>>>>>> On Thu, Nov 9, 2017 at 1:56 PM, Hong <hzhang at mcs.anl.gov>
>> wrote:
>> > >>>>>>>>> Mark:
>> > >>>>>>>>>> OK, well, just go with the Linux machine for the regression
>> test.
>> > >>>>>>>>>> I will keep trying to reproduce this on my Mac with an O
>> build.
>> > >>>>>>>>> Valgrind error occurs on linux machines with g-build. I cannot
>> > >>>>>>>>> merge this branch to maint until the bug is fixed.
>> > >>>>>>>> Valgrind is failing on this run on my Mac. Moving to cg, like
>> you I
>> > >>>>>>>> suppose. This takes forever. This is what I have so far. Did
>> you get this
>> > >>>>>>>> far?
>> > >>>>>>>> 07:48 hzhang/fix-submat_samerowdist *=
>> > >>>>>>>> /sandbox/adams/petsc/src/snes/examples/tutorials$ make
>> > >>>>>>>> PETSC_DIR=/sandbox/adams/petsc PETSC_ARCH=arch-linux2-c-dbg32
>> val
>> > >>>>>>>> /sandbox/adams/petsc/arch-linux2-c-dbg32/bin/mpiexec -n 2
>> valgrind
>> > >>>>>>>> ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2
>> -snes_max_it 2
>> > >>>>>>>> -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>> > >>>>>>>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type
>> agg
>> > >>>>>>>> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
>> -mg_levels_ksp_type
>> -mg_levels_pc_type
>> 3 -run_type 1
>> > >>>>>>>> ==12414== Memcheck, a memory error detector
>> > >>>>>>>> ==12414== Copyright (C) 2002-2013, and GNU GPL'd, by Julian
>> Seward
>> > >>>>>>>> et al.
>> > >>>>>>>> ==12414== Using Valgrind-3.10.1 and LibVEX; rerun with -h for
>> > >>>>>>>> copyright info
>> > >>>>>>>> ==12415== Memcheck, a memory error detector
>> > >>>>>>>> ==12415== Copyright (C) 2002-2013, and GNU GPL'd, by Julian
>> Seward
>> > >>>>>>>> et al.
>> > >>>>>>>> ==12415== Using Valgrind-3.10.1 and LibVEX; rerun with -h for
>> > >>>>>>>> copyright info
>> > >>>>>>>> ==12415== Command: ./ex56 -cells 2,2,1 -max_conv_its 3
>> cg -ksp_rtol
>> -pc_type gamg
>> -mg_levels_ksp_type
>> -mg_levels_pc_type
>> 3 -run_type 1
>> > >>>>>>>> ==12415==
>> > >>>>>>>> ==12414== Command: ./ex56 -cells 2,2,1 -max_conv_its 3
>> cg -ksp_rtol
>> -pc_type gamg
>> -mg_levels_ksp_type
>> -mg_levels_pc_type
>> 3 -run_type 1
>> > >>>>>>>> ==12414==
>> > >>>>>>>> iterations 1
>> > >>>>>>>> iterations 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171110/9313623b/attachment-0001.html>
