[petsc-users] unsorted local columns in 3.8?
Mark Adams
mfadams at lbl.gov
Fri Nov 10 08:57:25 CST 2017
This printed a little funny in gmail, snes/ex56 is running clean in the
first few loops (appended), but the last one is the one with a reduced
processor set. Still waiting. This is with 32 bit integers. I'm running
another with 64 bit integers.
[0] 27 global equations, 9 vertices
[0] 27 equations in vector, 9 vertices
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
[0] 441 global equations, 147 vertices
[0] 441 equations in vector, 147 vertices
[0] 4725 global equations, 1575 vertices
[0] 4725 equations in vector, 1575 vertices
On Fri, Nov 10, 2017 at 9:06 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Nov 9, 2017 at 1:56 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> Mark:
>>> OK, well, just go with the Linux machine for the regression test. I will
>>> keep trying to reproduce this on my Mac with an O build.
>> Valgrind error occurs on linux machines with g-build. I cannot merge this
>> branch to maint until the bug is fixed.
> Valgrind is failing on this run on my Mac. Moving to cg, like you I
> suppose. This takes forever. This is what I have so far. Did you get this
> far?
> 07:48 hzhang/fix-submat_samerowdist *= /sandbox/adams/petsc/src/snes/examples/tutorials$
> make PETSC_DIR=/sandbox/adams/petsc PETSC_ARCH=arch-linux2-c-dbg32 val
> /sandbox/adams/petsc/arch-linux2-c-dbg32/bin/mpiexec -n 2 valgrind ./ex56
> -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2 -ksp_max_it
> 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type unpreconditioned
> -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
> -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true
> -pc_gamg_square_graph 1 -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0
> -snes_converged_reason -use_mat_nearnullspace true -mg_levels_ksp_max_it 1
> -mg_levels_ksp_type chebyshev -mg_levels_esteig_ksp_type cg
> -mg_levels_esteig_ksp_max_it 10 -mg_levels_ksp_chebyshev_esteig
> 0,0.05,0,1.05 -mg_levels_pc_type jacobi -pc_gamg_mat_partitioning_type
> parmetis -mat_block_size 3 -run_type 1
> ==12414== Memcheck, a memory error detector
> ==12414== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
> ==12414== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright
> info
> ==12415== Memcheck, a memory error detector
> ==12415== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
> ==12415== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright
> info
> ==12415== Command: ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2
> -snes_max_it 2 -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -snes_converged_reason
> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type jacobi
> -pc_gamg_mat_partitioning_type parmetis -mat_block_size 3 -run_type 1
> ==12415==
> ==12414== Command: ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2
> ==12414==
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171110/87eb28e0/attachment.html>
