[petsc-users] unsorted local columns in 3.8?
    Hong
    hzhang at mcs.anl.gov
    Thu Nov  9 12:56:40 CST 2017
Mark:
> OK, well, just go with the Linux machine for the regression test. I will
> keep trying to reproduce this on my Mac with an O build.
Valgrind error occurs on linux machines with g-build. I cannot merge this
branch to maint until the bug is fixed.
Hong
> On Wed, Nov 8, 2017 at 12:24 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> mpiexec -n 2 valgrind ./ex56 -cells 2,2,1 -max_conv_its 3
>> -petscspace_order 2 -snes_max_it 2 -ksp_max_it 100 -ksp_type cg -ksp_rtol
>> 1.e-11 -ksp_norm_type unpreconditioned -snes_rtol 1.e-10 -pc_type gamg
>> -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -snes_converged_reason
>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
>> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type jacobi
>> -pc_gamg_mat_partitioning_type parmetis -mat_block_size 3 -run_type 1
>> ==30976== Invalid read of size 16
>> ==30976==    at 0x8550946: dswap_k_NEHALEM (in
>> /usr/lib/openblas-base/libblas.so.3)
>> ==30976==    by 0x7C6797F: dswap_ (in /usr/lib/openblas-base/libblas
>> .so.3)
>> ==30976==    by 0x75B33B2: dgetri_ (in /usr/lib/lapack/liblapack.so.3.0)
>> ==30976==    by 0x5E3CA5C: PetscFESetUp_Basic (dtfe.c:4012)
>> ==30976==    by 0x5E320C9: PetscFESetUp (dtfe.c:3274)
>> ==30976==    by 0x5E5786F: PetscFECreateDefault (dtfe.c:6749)
>> ==30976==    by 0x41056E: main (ex56.c:395)
>> ==30976==  Address 0xdc650d0 is 52,480 bytes inside a block of size
>> 52,488 alloc'd
>> ==30976==    at 0x4C2D110: memalign (in /usr/lib/valgrind/vgpreload_me
>> mcheck-amd64-linux.so)
>> ==30976==    by 0x51590F6: PetscMallocAlign (mal.c:39)
>> ==30976==    by 0x5E3C169: PetscFESetUp_Basic (dtfe.c:3983)
>> You can fix it on branch hzhang/fix-submat_samerowdist.
>> Hong
>> On Wed, Nov 8, 2017 at 11:01 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Wed, Nov 8, 2017 at 11:09 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Mark:
>>>>> Hong, is
>>>>> >   0-cells: 12 12 0 0
>>>>> >   1-cells: 20 20 0 0
>>>>> >   2-cells: 11 11 0 0
>>>>> >   3-cells: 2 2 0 0
>>>>> from the old version?
>>>> In O-build on my macPro, I get the above. In g-build, I get
>>>>>   0-cells: 8 8 8 8
>>>>>   1-cells: 12 12 12 12
>>>>>   2-cells: 6 6 6 6
>>>>>   3-cells: 1 1 1 1
>>>> I get this on linux machine.
>>>> Do you know why?
>>> I can not reproduce your O output. I will look at it later.
>>> Valgrind is failing on me right now. I will look into it but can you
>>> valgrind it?
>>>> Hong
>>>>> On Tue, Nov 7, 2017 at 10:13 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Mark:
>>>>>> I removed option '-ex56_dm_view'.
>>>>>> Hong
>>>>>> Humm, this looks a little odd, but it may be OK.  Is this this
>>>>>>> diffing with the old non-repartition data? (more below)
>>>>>>> On Tue, Nov 7, 2017 at 11:45 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>> Mark,
>>>>>>>> The fix is merged to next branch for tests which show diff as
>>>>>>>> ******* Testing: testexamples_PARMETIS *******
>>>>>>>> 5c5
>>>>>>>> <   1 SNES Function norm 1.983e-10
>>>>>>>> >   1 SNES Function norm 1.990e-10
>>>>>>>> 10,13c10,13
>>>>>>>> <   0-cells: 8 8 8 8
>>>>>>>> <   1-cells: 12 12 12 12
>>>>>>>> <   2-cells: 6 6 6 6
>>>>>>>> <   3-cells: 1 1 1 1
>>>>>>> I assume this is the old.
>>>>>>>> >   0-cells: 12 12 0 0
>>>>>>>> >   1-cells: 20 20 0 0
>>>>>>>> >   2-cells: 11 11 0 0
>>>>>>>> >   3-cells: 2 2 0 0
>>>>>>>> 15,18c15,18
>>>>>>> and this is the new.
>>>>>>> This is funny because the processors are not fully populated. This
>>>>>>> can happen on coarse grids and indeed it should happen in a test with good
>>>>>>> coverage.
>>>>>>> I assume these diffs are views from coarse grids? That is, in the
>>>>>>> raw output files do you see fully populated fine grids, with no diffs, and
>>>>>>> then the diffs come on coarse grids.
>>>>>>> Repartitioning the coarse grids can change the coarsening, It is
>>>>>>> possible that repartitioning causes faster coarsening (it does a little)
>>>>>>> and this faster coarsening is tripping the aggregation switch, which gives
>>>>>>> us empty processors.
>>>>>>> Am I understanding this correctly ...
>>>>>>> Thanks,
>>>>>>> Mark
>>>>>>>> <   boundary: 1 strata with value/size (1 (23))
>>>>>>>> <   Face Sets: 4 strata with value/size (1 (1), 2 (1), 4 (1), 6 (1))
>>>>>>>> <   marker: 1 strata with value/size (1 (15))
>>>>>>>> <   depth: 4 strata with value/size (0 (8), 1 (12), 2 (6), 3 (1))
>>>>>>>> >   boundary: 1 strata with value/size (1 (39))
>>>>>>>> >   Face Sets: 5 strata with value/size (1 (2), 2 (2), 4 (2), 5 (1), 6 (1))
>>>>>>>> >   marker: 1 strata with value/size (1 (27))
>>>>>>>> >   depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
>>>>>>>> see http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/07/examples_full_next-tmp.log
>>>>>>>> I guess parmetis produces random partition on different machines (I made output file for ex56_1 on my imac). Please take a look at the differences. If the outputs are correct, I will remove option '-ex56_dm_view'
>>>>>>>> Hong
>>>>>>>> On Sun, Nov 5, 2017 at 9:03 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>> Mark:
>>>>>>>>> Bug is fixed in branch hzhang/fix-submat_samerowdist
>>>>>>>>> https://bitbucket.org/petsc/petsc/branch/hzhang/fix-submat_s
>>>>>>>>> amerowdist
>>>>>>>>> I also add the test runex56. Please test it and let me know if
>>>>>>>>> there is a problem.
>>>>>>>>> Hong
>>>>>>>>> Also, I have been using -petscpartition_type but now I see
>>>>>>>>>> -pc_gamg_mat_partitioning_type. Is -petscpartition_type
>>>>>>>>>> depreciated for GAMG?
>>>>>>>>>> Is this some sort of auto generated portmanteau? I can not find
>>>>>>>>>> pc_gamg_mat_partitioning_type in the source.
>>>>>>>>>> On Thu, Nov 2, 2017 at 6:44 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>> Great, thanks,
>>>>>>>>>>> And could you please add these parameters to a regression test?
>>>>>>>>>>> As I recall we have with-parmetis regression test.
>>>>>>>>>>> On Thu, Nov 2, 2017 at 6:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>>>>> Mark:
>>>>>>>>>>>> I used petsc/src/ksp/ksp/examples/tutorials/ex56.c :-(
>>>>>>>>>>>> Now testing src/snes/examples/tutorials/ex56.c with your
>>>>>>>>>>>> options, I can reproduce the error.
>>>>>>>>>>>> I'll fix it.
>>>>>>>>>>>> Hong
>>>>>>>>>>>> Hong,
>>>>>>>>>>>>> I've tested with master and I get the same error. Maybe the
>>>>>>>>>>>>> partitioning parameters are wrong. -pc_gamg_mat_partitioning_type is new to
>>>>>>>>>>>>> me.
>>>>>>>>>>>>> Can you run this (snes ex56) w/o the error?
>>>>>>>>>>>>> 17:33 *master* *= ~*/Codes/petsc/src/snes/examples/tutorials*$
>>>>>>>>>>>>> make runex
>>>>>>>>>>>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n
>>>>>>>>>>>>> 4 ./ex56  -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2
>>>>>>>>>>>>> -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>>>>>>>>>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
>>>>>>>>>>>>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
>>>>>>>>>>>>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>>>>>>>>>>>>> -mg_levels_pc_type jacobi -pc_gamg_mat_partitioning_type parmetis
>>>>>>>>>>>>> -mat_block_size 3 -matrap 0 -matptap_scalable -ex56_dm_view -run_type 1
>>>>>>>>>>>>> -pc_gamg_repartition true
>>>>>>>>>>>>> [0] 27 global equations, 9 vertices
>>>>>>>>>>>>> [0] 27 equations in vector, 9 vertices
>>>>>>>>>>>>>   0 SNES Function norm 122.396
>>>>>>>>>>>>>     0 KSP Residual norm 122.396
>>>>>>>>>>>>>   <snip>
>>>>>>>>>>>>>   depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3
>>>>>>>>>>>>> (8))
>>>>>>>>>>>>> [0] 4725 global equations, 1575 vertices
>>>>>>>>>>>>> [0] 4725 equations in vector, 1575 vertices
>>>>>>>>>>>>>   0 SNES Function norm 17.9091
>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>>>> type
>>>>>>>>>>>>> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 1:35 PM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Mark :
>>>>>>>>>>>>>> I realize that using maint or master branch, I cannot
>>>>>>>>>>>>>> reproduce the same error.
>>>>>>>>>>>>>> For this example, you must use a parallel partitioner,
>>>>>>>>>>>>>> e.g.,'current' gives me following error:
>>>>>>>>>>>>>> [0]PETSC ERROR: This is the DEFAULT NO-OP partitioner, it
>>>>>>>>>>>>>> currently only supports one domain per processor
>>>>>>>>>>>>>> use -pc_gamg_mat_partitioning_type parmetis or chaco or
>>>>>>>>>>>>>> ptscotch for more than one subdomain per processor
>>>>>>>>>>>>>> Please rebase your branch with maint or master, then see if
>>>>>>>>>>>>>> you still have problem.
>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 11:07 AM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>> Mark,
>>>>>>>>>>>>>>>> I can reproduce this in an old branch, but not in current
>>>>>>>>>>>>>>>> maint and master.
>>>>>>>>>>>>>>>> Which branch are you using to produce this error?
>>>>>>>>>>>>>>> I am using a branch from Matt. Let me try to merge it with
>>>>>>>>>>>>>>> master.
>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov
>>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>>> I am able to reproduce this with snes ex56 with 2
>>>>>>>>>>>>>>>>> processors and adding -pc_gamg_repartition true
>>>>>>>>>>>>>>>>> I'm not sure how to fix it.
>>>>>>>>>>>>>>>>> 10:26 1 knepley/feature-plex-boxmesh-create *=
>>>>>>>>>>>>>>>>> ~/Codes/petsc/src/snes/examples/tutorials$ make
>>>>>>>>>>>>>>>>> PETSC_DIR=/Users/markadams/Codes/petsc
>>>>>>>>>>>>>>>>> PETSC_ARCH=arch-macosx-gnu-g runex
>>>>>>>>>>>>>>>>> -n 2 ./ex56  -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it
>>>>>>>>>>>>>>>>> 2 -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>>>>>>>>>>>>>> -mg_levels_pc_type jacobi -petscpartitioner_type simple -mat_block_size 3
>>>>>>>>>>>>>>>>> -matrap 0 -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition
>>>>>>>>>>>>>>>>> true
>>>>>>>>>>>>>>>>>     1 KSP Residual norm 20.4696
>>>>>>>>>>>>>>>>>     2 KSP Residual norm 3.95009
>>>>>>>>>>>>>>>>>     3 KSP Residual norm 0.176181
>>>>>>>>>>>>>>>>>     4 KSP Residual norm 0.0208781
>>>>>>>>>>>>>>>>>     5 KSP Residual norm 0.00278873
>>>>>>>>>>>>>>>>>     6 KSP Residual norm 0.000482741
>>>>>>>>>>>>>>>>>     7 KSP Residual norm 4.68085e-05
>>>>>>>>>>>>>>>>>     8 KSP Residual norm 5.42381e-06
>>>>>>>>>>>>>>>>>     9 KSP Residual norm 5.12785e-07
>>>>>>>>>>>>>>>>>    10 KSP Residual norm 2.60389e-08
>>>>>>>>>>>>>>>>>    11 KSP Residual norm 4.96201e-09
>>>>>>>>>>>>>>>>>    12 KSP Residual norm 1.989e-10
>>>>>>>>>>>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations
>>>>>>>>>>>>>>>>> 12
>>>>>>>>>>>>>>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
>>>>>>>>>>>>>>>>> iterations 1
>>>>>>>>>>>>>>>>> DM Object: Mesh (ex56_) 2 MPI processes
>>>>>>>>>>>>>>>>>   type: plex
>>>>>>>>>>>>>>>>> Mesh in 3 dimensions:
>>>>>>>>>>>>>>>>>   0-cells: 12 12
>>>>>>>>>>>>>>>>>   1-cells: 20 20
>>>>>>>>>>>>>>>>>   2-cells: 11 11
>>>>>>>>>>>>>>>>>   3-cells: 2 2
>>>>>>>>>>>>>>>>> Labels:
>>>>>>>>>>>>>>>>>   Face Sets: 5 strata with value/size (1 (2), 2 (2), 3
>>>>>>>>>>>>>>>>> (2), 5 (1), 6 (1))
>>>>>>>>>>>>>>>>> 3 (2))
>>>>>>>>>>>>>>>>> [0] 441 global equations, 147 vertices
>>>>>>>>>>>>>>>>> [0] 441 equations in vector, 147 vertices
>>>>>>>>>>>>>>>>>   0 SNES Function norm 49.7106
>>>>>>>>>>>>>>>>>     0 KSP Residual norm 49.7106
>>>>>>>>>>>>>>>>>     1 KSP Residual norm 12.9252
>>>>>>>>>>>>>>>>>     2 KSP Residual norm 2.38019
>>>>>>>>>>>>>>>>>     3 KSP Residual norm 0.426307
>>>>>>>>>>>>>>>>>     4 KSP Residual norm 0.0692155
>>>>>>>>>>>>>>>>>     5 KSP Residual norm 0.0123092
>>>>>>>>>>>>>>>>>     6 KSP Residual norm 0.00184874
>>>>>>>>>>>>>>>>>     7 KSP Residual norm 0.000320761
>>>>>>>>>>>>>>>>>     8 KSP Residual norm 5.48957e-05
>>>>>>>>>>>>>>>>>     9 KSP Residual norm 9.90089e-06
>>>>>>>>>>>>>>>>>    10 KSP Residual norm 1.5127e-06
>>>>>>>>>>>>>>>>>    11 KSP Residual norm 2.82192e-07
>>>>>>>>>>>>>>>>>    12 KSP Residual norm 4.62364e-08
>>>>>>>>>>>>>>>>>    13 KSP Residual norm 7.99573e-09
>>>>>>>>>>>>>>>>>    14 KSP Residual norm 1.3028e-09
>>>>>>>>>>>>>>>>>    15 KSP Residual norm 2.174e-10
>>>>>>>>>>>>>>>>> 15
>>>>>>>>>>>>>>>>>   1 SNES Function norm 2.174e-10
>>>>>>>>>>>>>>>>> iterations 1
>>>>>>>>>>>>>>>>>   type: plex
>>>>>>>>>>>>>>>>>   0-cells: 45 45
>>>>>>>>>>>>>>>>>   1-cells: 96 96
>>>>>>>>>>>>>>>>>   2-cells: 68 68
>>>>>>>>>>>>>>>>>   3-cells: 16 16
>>>>>>>>>>>>>>>>> Labels:
>>>>>>>>>>>>>>>>>   marker: 1 strata with value/size (1 (129))
>>>>>>>>>>>>>>>>>   Face Sets: 5 strata with value/size (1 (18), 2 (18), 3
>>>>>>>>>>>>>>>>> (18), 5 (9), 6 (9))
>>>>>>>>>>>>>>>>>   boundary: 1 strata with value/size (1 (141))
>>>>>>>>>>>>>>>>>   depth: 4 strata with value/size (0 (45), 1 (96), 2 (68),
>>>>>>>>>>>>>>>>> 3 (16))
>>>>>>>>>>>>>>>>> object type
>>>>>>>>>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>>>> [1]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>>>> object type
>>>>>>>>>>>>>>>>> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <
>>>>>>>>>>>>>>>>>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>>>>>>>>>>>>>>>>>> rchurchi at pppl.gov> wrote:
>>>>>>>>>>>>>>>>>>> Doing some additional testing, the issue goes away when
>>>>>>>>>>>>>>>>>>> removing the gamg preconditioner line from the petsc.rc:
>>>>>>>>>>>>>>>>>>> -pc_type gamg
>>>>>>>>>>>>>>>>>> Yea, this is GAMG setup.
>>>>>>>>>>>>>>>>>> This is the code.  findices is create with
>>>>>>>>>>>>>>>>>> ISCreateStride, so it is sorted ...
>>>>>>>>>>>>>>>>>> Michael is repartitioning the coarse grids. Maybe we
>>>>>>>>>>>>>>>>>> don't have a regression test with this...
>>>>>>>>>>>>>>>>>> I will try to reproduce this.
>>>>>>>>>>>>>>>>>> Michael: you can use hypre for now, or turn
>>>>>>>>>>>>>>>>>> repartitioning off (eg, -fsa_fieldsplit_lambda_upper_pc_gamg_repartition
>>>>>>>>>>>>>>>>>> false), but I'm not sure this will fix this.
>>>>>>>>>>>>>>>>>> You don't have hypre parameters for all of your all of
>>>>>>>>>>>>>>>>>> your solvers. I think 'boomeramg' is the default pc_hypre_type. That should
>>>>>>>>>>>>>>>>>> be good enough for you.
>>>>>>>>>>>>>>>>>>       IS       findices;
>>>>>>>>>>>>>>>>>>       PetscInt Istart,Iend;
>>>>>>>>>>>>>>>>>>       Mat      Pnew;
>>>>>>>>>>>>>>>>>>       ierr = MatGetOwnershipRange(Pold, &Istart,
>>>>>>>>>>>>>>>>>> &Iend);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>> #if defined PETSC_GAMG_USE_LOG
>>>>>>>>>>>>>>>>>>       ierr = PetscLogEventBegin(petsc_gamg_
>>>>>>>>>>>>>>>>>> setup_events[SET15],0,0,0,0);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>> #endif
>>>>>>>>>>>>>>>>>>       ierr = ISCreateStride(comm,Iend-Istar
>>>>>>>>>>>>>>>>>> t,Istart,1,&findices);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>>       ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>>       ierr = MatCreateSubMatrix(Pold, findices,
>>>>>>>>>>>>>>>>>> new_eq_indices, MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>>       ierr = ISDestroy(&findices);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>>       ierr = PetscLogEventEnd(petsc_gamg_se
>>>>>>>>>>>>>>>>>> #endif
>>>>>>>>>>>>>>>>>>       ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>>>>>>>>>>>>>>>>>>       /* output - repartitioned */
>>>>>>>>>>>>>>>>>>       *a_P_inout = Pnew;
>>>>>>>>>>>>>>>>>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov
>>>>>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>>>>>>>> Thanks, I'll check it tomorrow.
>>>>>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>>>>>> OK, this might not be completely satisfactory, because
>>>>>>>>>>>>>>>>>>>>> it doesn't show the partitioning or how the matrix is created, but this
>>>>>>>>>>>>>>>>>>>>> reproduces the problem. I wrote out my matrix, Amat, from the larger
>>>>>>>>>>>>>>>>>>>>> simulation, and load it in this script. This must be run with MPI rank
>>>>>>>>>>>>>>>>>>>>> greater than 1. This may be some combination of my petsc.rc, because when I
>>>>>>>>>>>>>>>>>>>>> use the PetscInitialize with it, it throws the error, but when using
>>>>>>>>>>>>>>>>>>>>> default (PETSC_NULL_CHARACTER) it runs fine.
>>>>>>>>>>>>>>>>>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <
>>>>>>>>>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>>>>>>>>>> It could be a bug or a missing feature in our new
>>>>>>>>>>>>>>>>>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>>>>>>>>>>>>>>>>>> It would be helpful if you can provide us a simple
>>>>>>>>>>>>>>>>>>>>>> example that produces this example.
>>>>>>>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>>>>>>>> I'm running a Fortran code that was just changed over
>>>>>>>>>>>>>>>>>>>>>>> to using petsc 3.8 (previously petsc 3.7.6). An error was thrown during a
>>>>>>>>>>>>>>>>>>>>>>> KSPSetUp() call. The error is "unsorted iscol_local is not implemented yet"
>>>>>>>>>>>>>>>>>>>>>>> (see full error below). I tried to trace down the difference in the source
>>>>>>>>>>>>>>>>>>>>>>> files, but where the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist())
>>>>>>>>>>>>>>>>>>>>>>> doesn't seem to have existed in v3.7.6, so I'm unsure how to compare. It
>>>>>>>>>>>>>>>>>>>>>>> seems the error is that the order of the columns locally are unsorted,
>>>>>>>>>>>>>>>>>>>>>>> though I don't think I specify a column order in the creation of the matrix:
>>>>>>>>>>>>>>>>>>>>>>>      call MatCreate(this%comm,AA,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatSetSizes(AA,npetscloc,npets
>>>>>>>>>>>>>>>>>>>>>>> cloc,nreal,nreal,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatSetType(AA,MATAIJ,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatSetup(AA,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>>>>>>>>>>>>>>>>>>      call getNNZ(grid,npetscloc,low,high
>>>>>>>>>>>>>>>>>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatSeqAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatMPIAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_
>>>>>>>>>>>>>>>>>>>>>>> NULL_INTEGER,o_nnz,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      deallocate(d_nnz,o_nnz)
>>>>>>>>>>>>>>>>>>>>>>>      call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>>>>>>>>>>>>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>>>>>>>>>>      call MatSetOption(AA,MAT_KEEP_NONZE
>>>>>>>>>>>>>>>>>>>>>>> RO_PATTERN,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: No support for this operation for
>>>>>>>>>>>>>>>>>>>>>>> this object type
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not
>>>>>>>>>>>>>>>>>>>>>>> implemented yet
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0,
>>>>>>>>>>>>>>>>>>>>>>> unknown[62]PETSC ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist()
>>>>>>>>>>>>>>>>>>>>>>> line 3418 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>>>>>> 8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line
>>>>>>>>>>>>>>>>>>>>>>> 3247 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872
>>>>>>>>>>>>>>>>>>>>>>> in /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line
>>>>>>>>>>>>>>>>>>>>>>> 383 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>>>>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171109/ecbc3dbf/attachment-0001.html>
