[petsc-users] Newton LS - better results on single processor
zakaryah .
zakaryah at gmail.com
Thu Nov 9 10:16:22 CST 2017
Thanks Stefano, I will try what you suggest.
Matt - my DM is a composite between the redundant field (loading
coefficient, which is included in the Newton solve in Riks' method) and the
displacements, which are represented by a 3D DA with 3 dof. I am using
finite difference.
Probably my problem comes from confusion over how the composite DM is
organized. I am using FormFunction(), and within that I call
DMCompositeGetLocalVectors(), DMCompositeScatter(), DMDAVecGetArray(), and
for the Jacobian, DMCompositeGetLocalISs() and MatGetLocalSubmatrix() to
split J into Jbb, Jbh, Jhb, and Jhh, where b is the loading coefficient,
and h is the displacements). The values of each submatrix are set using
MatSetValuesLocal().
I'm most suspicious of the part of the Jacobian routine where I calculate
the rows of Jhb, the columns of Jbh, and the corresponding values. I take
the DA coordinates and ix,iy,iz, then calculate the row of Jhb as
((((iz-info->gzs)*info->gym
+ (iy-info->gys))*info->gxm + (ix-info->gxs))*info->dof+c), where info is
the DA local info and c is the degree of freedom. The same calculation is
performed for the column of Jbh. I suspect that the indexing of the DA
vector is not so simple, but I don't know for a fact that I'm doing this
incorrectly nor how to do this properly.
Thanks for all the help!
On Nov 9, 2017 8:44 AM, "Matthew Knepley" <knepley at gmail.com> wrote:
On Thu, Nov 9, 2017 at 12:14 AM, zakaryah . <zakaryah at gmail.com> wrote:
> Well the saga of my problem continues. As I described previously in an
> epic thread, I'm using the SNES to solve problems involving an elastic
> material on a rectangular grid, subjected to external forces. In any case,
> I'm occasionally getting poor convergence using Newton's method with line
> search. In troubleshooting by visualizing the residual, I saw that in data
> sets which had good convergence, the residual was nevertheless
> significantly larger along the boundary between different processors.
> Likewise, in data sets with poor convergence, the residual became very
> large on the boundary between different processors. The residual is not
> significantly larger on the physical boundary, i.e. the global boundary.
> When I run on a single process, convergence seems to be good on all data
> sets.
> Any clues to fix this?
It sounds like something is wrong with communication across domains:
- If this is FEM, it sounds like you are not adding contributions from the
other domain to shared vertices/edges/faces
- If this is FDM/FVM, maybe the ghosts are not updated
What DM are you using? Are you using the Local assembly functions
(FormFunctionLocal), or just FormFunction()?
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171109/53cf1659/attachment.html>
