[petsc-users] SNES without SNESSetJacobian, snes_fd or snes_mf
Jed Brown jed at jedbrown.org
Thu Nov 9 09:38:15 CST 2017
Florian Kauer <florian.kauer at koalo.de> writes:
> Hi,
> what is the SNES solver actually doing when you do not provide a
> jacobian and not explicitly select either finite differencing
> approximation or matrix-free Newton-Krylov method?
> I just noticed that I mistakenly did this, but a good solution is found
> anyway (and fast). So what is actually happening? Simple fixed-point
> iteration?
Presumably you are using a DM that can provide a coloring, in which case
the sparse Jacobian is assembled using finite differencing with coloring.
