[petsc-users] troubleshooting AMG, coupled navier stokes, large eigenvalues on coarsest level
Mark Adams mfadams at lbl.gov
Wed Nov 8 19:40:42 CST 2017
On Wed, Nov 8, 2017 at 8:02 PM, Mark Lohry <mlohry at gmail.com> wrote:
> Do you mean the element Jacobian matrix has 35 "vertices"? You have 5x5
>> dense blocks (or at least you don't care about resolving any sparsity or
>> you want to use block preconditioners. So your element Jacobians are
>> [35x5]^2 dense(ish) matrices. This is not particularly useful for the
>> solvers.
> Yes, the local element jacobians are (35x5)^2 ( (N+1)(N+2)(N+3)/6 vertices
> per Nth order element for 3D). They'd be 100% dense. So the real blocks of
> the full system jacobian are of that size, and not 5x5. Block ILU is pretty
> popular for these discretizations for obvious reasons.
OK, but don't set that blocks size.
> This is on the full NS problem I assume. You need special solvers for
>> this. Scalable solvers for NS is not trivial.
> Yes, compressible 3D NS. I'm aware scaling isn't trivial, but this isn't a
> scaling problem, I'm obviously computing a wrong preconditioner since it's
> actively hurting the linear solve.
By scaling I mean not a direct solver.
> Yes, you should use Gauss-Seidel for non-symmetric systems. Or indefinite
>> systems
> Thanks!
sor
> You want to use the Schur complement PCs for NS. We have some support for
>> PC where you give us a mass matrix.
> I'll look into it, but I'm not aware of Schur complement being used for
> compressible/coupled NS, only for incompressible/segregated.
Really? OK, you've looked into it more than me.
This is DG where the mass matrix is a block diagonal constant you typically
> just invert once at the beginning; is there a PC where this can be
> exploited?
Don't know but being able to explicitly invert this might let you compute
an exact Schur complement matrix and then use algebraic solvers (like LU
and AMG).
> On Wed, Nov 8, 2017 at 7:04 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Tue, Nov 7, 2017 at 3:00 PM, Mark Lohry <mlohry at gmail.com> wrote:
>>> I've now got gamg running on matrix-free newton-krylov with the jacobian
>>> provided by coloring finite differences (thanks again for the help). 3D
>>> Poisson with 4th order DG or higher (35^2 blocks), gamg with default
>>> settings is giving textbook convergence, which is great. Of course coupled
>>> compressible navier-stokes is harder, and convergence is bad-to-nonexistent.
>>> 1) Doc says "Equations must be ordered in “vertex-major” ordering"; in
>>> my discretization, each "node" has 5 coupled degrees of freedom (density, 3
>>> x momentum, energy). I'm ordering my unknowns:
>>> rho_i, rhou_i, rhov_i, rhow_i, Et_i, rho_i+1, rhou_i+1, ...  e.g.
>>> row-major matrix order if you wrote the unknowns [{rho}, {rhou}, ... ].
>>> and then setting block size to 5. Is that correct?
>> yes
>>> I've also tried using the actual sparsity of the matrix
>> Sorry, but using for what?
>>> which has larger dense blocks (e.g. [35x5]^2), but neither seemed to
>>> help.
>> solvers.
>>> 2) With default settings, and with -pc_gamg_square_graph,
>>> pc_gamg_sym_graph, agg_nsmooths 0 mentioned in the manual, the eigenvalue
>>> estimates explode on the coarsest level, which I don't see with poisson:
>>>   Down solver (pre-smoother) on level 1 -------------------------------
>>>     KSP Object: (mg_levels_1_) 32 MPI processes
>>>       type: chebyshev
>>>         eigenvalue estimates used:  min = 0.18994, max = 2.08935
>>>         eigenvalues estimate via gmres min 0.00933256, max 1.8994
>>>   Down solver (pre-smoother) on level 2 -------------------------------
>>>     KSP Object: (mg_levels_2_) 32 MPI processes
>>>       type: chebyshev
>>>         eigenvalue estimates used:  min = 0.165969, max = 1.82566
>>>         eigenvalues estimate via gmres min 0.0290728, max 1.65969
>>>   Down solver (pre-smoother) on level 3 -------------------------------
>>>     KSP Object: (mg_levels_3_) 32 MPI processes
>>>       type: chebyshev
>>>         eigenvalue estimates used:  min = 0.146479, max = 1.61126
>>>         eigenvalues estimate via gmres min 0.204673, max 1.46479
>>>   Down solver (pre-smoother) on level 4 -------------------------------
>>>     KSP Object: (mg_levels_4_) 32 MPI processes
>>>       type: chebyshev
>>>         eigenvalue estimates used:  min = 6.81977e+09, max = 7.50175e+10
>>>         eigenvalues estimate via gmres min -2.76436e+12, max 6.81977e+10
>>> What's happening here? (Full -ksp_view below)
>>> 3) I'm not very familiar with chebyshev smoothers, but they're only for
>>> SPD systems (?).
>> systems
>>> Is this an inappropriate smoother for this problem?
>>> 4) With gmres, the preconditioned residual is ~10 orders larger than the
>>> true residual; and the preconditioned residual drops while the true
>>> residual rises. I'm assuming this means something very wrong?
>> Yes, your preconditioner is no good.
>>> 5) -pc_type hyper -pc_hypre_type boomeramg also works perfectly for the
>>> poisson case, but hits NaN on the first cycle for NS.
>> PC where you give us a mass matrix. These are motivated by assuming there
>> is a "commutation" (that is not true). These were developed by, among
>> others, Andy Wathan, if you want to do a literature search. You will
>> probably have to read the literature to understand the options and issues
>> for your problem. Look at the PETSc manual and you should find a
>> description of PETSc support for these PCs and some discussion of them and
>> references. This should get you started.
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171108/b8144a24/attachment.html>
