[petsc-users] GAMG advice
Mark Adams mfadams at lbl.gov
Wed Nov 8 19:05:41 CST 2017
> Now I'd like to try GAMG instead of ML. However, I don't know how to set
> it up to get similar performance.
> The obvious/naive
>     -pc_type gamg
>     -pc_gamg_type agg
> # with and without
>     -pc_gamg_threshold 0.03
>     -pc_mg_levels 3
This looks fine. I would not set the number of levels but if it helps then
go for it.
> converges very slowly on 1 proc and much worse on 8 (~200k dofs per
> proc), for instance:
> np = 1:
> 980 KSP unpreconditioned resid norm 1.065009356215e-02 true resid norm
> 1.065009356215e-02 ||r(i)||/||b|| 4.532259705508e-04
> 981 KSP unpreconditioned resid norm 1.064978578182e-02 true resid norm
> 1.064978578182e-02 ||r(i)||/||b|| 4.532128726342e-04
> 982 KSP unpreconditioned resid norm 1.064956706598e-02 true resid norm
> 1.064956706598e-02 ||r(i)||/||b|| 4.532035649508e-04
> np = 8:
> 980 KSP unpreconditioned resid norm 3.179946748495e-02 true resid norm
> 3.179946748495e-02 ||r(i)||/||b|| 1.353259896710e-03
> 981 KSP unpreconditioned resid norm 3.179946748317e-02 true resid norm
> 3.179946748317e-02 ||r(i)||/||b|| 1.353259896634e-03
> 982 KSP unpreconditioned resid norm 3.179946748317e-02 true resid norm
> A very high threshold seems to improve the GAMG PC, for instance with
> 0.75 I get convergence to rtol=1e-6 after 744 iterations.
> What else should I try?
Not sure. ML use the same algorithm as GAMG (so the threshold means the
same thing pretty much). ML is a good solver and the leader, Ray Tuminaro,
has had a lot of NS experience. But I'm not sure what the differences are
that are resulting in this performance.
* It looks like you are using sor for the coarse grid solver in gamg:
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_levels_0_)     1 MPI processes
      type: preonly
      maximum iterations=2, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      left preconditioning
      using NONE norm type for convergence test
    PC Object:    (mg_levels_0_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations =
You should/must use lu, like in ML. This will kill you.
* smoothed aggregation vs unsmoothed: GAMG's view data does not say if it
is smoothing. Damn, I need to fix that. For NS, you probably want
unsmoothed (-pc_gamg_agg_nsmooths 0). I'm not sure what the ML parameter is
for this nor do I know the default. It should make a noticable difference
(good or bad).
* Threshold for dropping small values from graph 0.75 -- this is crazy :)
This is all that I can think of now.
> I would very much appreciate any advice on configuring GAMG and
> differences w.r.t ML to be taken into account (not a multigrid expert
> though).
> Thanks, best wishes
> David
> ksp_view for -pc_type gamg      -pc_gamg_threshold 0.75 -pc_mg_levels 3
> KSP Object: 1 MPI processes
>   type: fgmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000
>   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
>   right preconditioning
>   using nonzero initial guess
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: gamg
>     MG: type is MULTIPLICATIVE, levels=1 cycles=v
>       Cycles per PCApply=1
>       Using Galerkin computed coarse grid matrices
>       GAMG specific options
>         AGG specific options
>           Symmetric graph false
>       type: preonly
>       type: sor
> 1, omega = 1.
>       linear system matrix = precond matrix:
>       Mat Object:       1 MPI processes
>         type: seqaij
>         rows=1745224, cols=1745224
>         total: nonzeros=99452608, allocated nonzeros=99452608
>         total number of mallocs used during MatSetValues calls =0
>           using I-node routines: found 1037847 nodes, limit used is 5
>     type: seqaij
> ksp_view for -pc_type ml:
> KSP Object: 8 MPI processes
>   type: fgmres
> PC Object: 8 MPI processes
>   type: ml
>     MG: type is MULTIPLICATIVE, levels=3 cycles=v
>     KSP Object:    (mg_coarse_)     8 MPI processes
>       type: preonly
>       maximum iterations=10000, initial guess is zero
>     PC Object:    (mg_coarse_)     8 MPI processes
>       type: redundant
>         Redundant preconditioner: First (color=0) of 8 PCs follows
>         KSP Object:        (mg_coarse_redundant_)         1 MPI processes
>           type: preonly
>         PC Object:        (mg_coarse_redundant_)         1 MPI processes
>           type: lu
>             LU: out-of-place factorization
>             tolerance for zero pivot 2.22045e-14
>             using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>             matrix ordering: nd
>             factor fill ratio given 5., needed 10.4795
>               Factored matrix follows:
>                   type: seqaij
>                   rows=6822, cols=6822
>                   package used to perform factorization: petsc
>                   total: nonzeros=9575688, allocated nonzeros=9575688
>                     not using I-node routines
>             type: seqaij
>             total: nonzeros=913758, allocated nonzeros=913758
>       Mat Object:       8 MPI processes
>         type: mpiaij
>           not using I-node (on process 0) routines
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object:    (mg_levels_1_)     8 MPI processes
>       type: richardson
>         Richardson: damping factor=1.
>     PC Object:    (mg_levels_1_)     8 MPI processes
>       type: sor
> 1, omega = 1.
>         type: mpiaij
>         rows=67087, cols=67087
>         total: nonzeros=9722749, allocated nonzeros=9722749
>   Up solver (post-smoother) same as down solver (pre-smoother)
>   Down solver (pre-smoother) on level 2 -------------------------------
>     KSP Object:    (mg_levels_2_)     8 MPI processes
>       type: richardson
>     PC Object:    (mg_levels_2_)     8 MPI processes
>       type: sor
> 1, omega = 1.
>         type: mpiaij
>           using I-node (on process 0) routines: found 126690 nodes,
> limit used is 5
>     type: mpiaij
>       using I-node (on process 0) routines: found 126690 nodes, limit
> used is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171108/3b9bc3b0/attachment-0001.html>
