[petsc-users] linking PETSC with SSL
Wed Nov 8 08:54:08 CST 2017
Hm --with-ssl=0 should work. Can you do a fresh/clean build and see if the problem persists?
If so send configure.log make.log and test.log for this build.
BTW: 3.8 has better support for fortran usage - so you might consider
upgrading all the way to it.
https://www.mcs.anl.gov/petsc/documentation/changes/38.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html#UsingFortran
Satish
On Wed, 8 Nov 2017, Lukas van de Wiel wrote:
> Good day,
> during an upgrade of PETSc (from 3.4.2 to 3.7.7) and some changes
> needed to use MUMPs I ran into a problem with SSL that I could not
> really figure out.
> I have configured PETSc 3.7.7 using: (explicitly note the option --with-ssl=0  )
> ./configure  \
> COPTFLAGS='-O3 -march=native -mtune=native' \
> CXXOPTFLAGS='-O3 -march=native -mtune=native' \
> FOPTFLAGS='-O3 -march=native -mtune=native' \
> --with-debugging=0 \
> --with-x=0 \
> --with-ssl=0 \
> --with-shared-libraries=0 \
> --download-metis \
> --download-parmetis \
> --download-fblaslapack \
> --download-scalapack \
> --download-openmpi \
> --download-mumps \
> --download-hypre \
> --download-ptscotch
> Next I have a tiny Fortran program to illustrate the problem:
> program sslhuh
> implicit none
> #include "petsc/finclude/petscsys.h"
> write(*,*) "Hello World"
> end program
> I compile it using makefile:
> petscDir = /net/home/gtecton/sw_dev/petsc-3.7.7
> all: compile link
> compile: sslhuh.F
>     $(petscDir)/linux-gnu-x86_64/bin/mpif90 \
>     -c \
>     -o sslhuh.o \
>     -std=f2008 \
>     -ffree-form \
>     -I$(petscDir)/include \
>     -I$(petscDir)/include/petsc/finclude \
>     sslhuh.F
> link: sslhuh.o
>     -o sslhuh \
>     sslhuh.o \
>     $(petscDir)/linux-gnu-x86_64/lib/libpetsc.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libHYPRE.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libzmumps.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libsmumps.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libdmumps.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libcmumps.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libmumps_common.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libesmumps.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libparmetis.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libmetis.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libpord.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libscalapack.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libflapack.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libfblas.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libptscotch.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libptscotcherr.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libptscotcherrexit.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libptscotchparmetis.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libscotch.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libscotcherr.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libscotcherrexit.a \
>     $(petscDir)/linux-gnu-x86_64/lib/libscotchmetis.a \
>     -ldl
> Compiling works fine.
> Linking gives me the error:
> /net/home/gtecton/sw_dev/petsc-3.7.7/linux-gnu-x86_64/lib/libpetsc.a(client.o):
> In function `PetscSSLInitializeContext':
> client.c:(.text+0x3b): undefined reference to `SSLv23_method'
> client.c:(.text+0x43): undefined reference to `SSL_CTX_new'
> client.c:(.text+0x5a): undefined reference to `SSL_CTX_ctrl'
> client.c:(.text+0x79): undefined reference to `SSL_library_init'
> client.c:(.text+0x7e): undefined reference to `SSL_load_error_strings'
> client.c:(.text+0x8c): undefined reference to `BIO_new_fp'
> In function `PetscSSLDestroyContext':
> client.c:(.text+0xa5): undefined reference to `SSL_CTX_free'
> In function `PetscHTTPSRequest':
> client.c:(.text+0xa9e): undefined reference to `SSL_write'
> client.c:(.text+0xaab): undefined reference to `SSL_get_error'
> client.c:(.text+0xb40): undefined reference to `SSL_read'
> client.c:(.text+0xb50): undefined reference to `SSL_get_error'
> client.c:(.text+0xbde): undefined reference to `SSL_free'
> client.c:(.text+0xc74): undefined reference to `SSL_shutdown'
> In function `PetscHTTPSConnect':
> client.c:(.text+0x105c): undefined reference to `SSL_new'
> client.c:(.text+0x106a): undefined reference to `BIO_new_socket'
> client.c:(.text+0x1079): undefined reference to `SSL_set_bio'
> client.c:(.text+0x1082): undefined reference to `SSL_connect'
> collect2: ld returned 1 exit status
> make: *** [link] Error 1
> From what I see, the SSL functionality is in client.o, which is part
> of libpetsc.a, which is included in the linking.
> There is no difference in whether I turn --with-ssl on or off...
> Does anybody have an idea what I am doing wrong?
> Best wishes and thank you for your time!
> Lukas
