[petsc-users] unsorted local columns in 3.8?
Hong
hzhang at mcs.anl.gov
Tue Nov 7 10:45:30 CST 2017
Mark,
The fix is merged to next branch for tests which show diff as
******* Testing: testexamples_PARMETIS *******
5c5
< 1 SNES Function norm 1.983e-10
> 1 SNES Function norm 1.990e-10
10,13c10,13
< 0-cells: 8 8 8 8
< 1-cells: 12 12 12 12
< 2-cells: 6 6 6 6
< 3-cells: 1 1 1 1
> 0-cells: 12 12 0 0
> 1-cells: 20 20 0 0
> 2-cells: 11 11 0 0
> 3-cells: 2 2 0 0
15,18c15,18
< boundary: 1 strata with value/size (1 (23))
< Face Sets: 4 strata with value/size (1 (1), 2 (1), 4 (1), 6 (1))
< marker: 1 strata with value/size (1 (15))
< depth: 4 strata with value/size (0 (8), 1 (12), 2 (6), 3 (1))
> boundary: 1 strata with value/size (1 (39))
> Face Sets: 5 strata with value/size (1 (2), 2 (2), 4 (2), 5 (1), 6 (1))
> marker: 1 strata with value/size (1 (27))
> depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
see http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/07/examples_full_next-tmp.log
I guess parmetis produces random partition on different machines (I
made output file for ex56_1 on my imac). Please take a look at the
differences. If the outputs are correct, I will remove option
'-ex56_dm_view'
Hong
On Sun, Nov 5, 2017 at 9:03 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Mark:
> Bug is fixed in branch hzhang/fix-submat_samerowdist
> https://bitbucket.org/petsc/petsc/branch/hzhang/fix-submat_samerowdist
> I also add the test runex56. Please test it and let me know if there is a
> problem.
> Hong
> Also, I have been using -petscpartition_type but now I see
>> -pc_gamg_mat_partitioning_type. Is -petscpartition_type depreciated for
>> GAMG?
>> Is this some sort of auto generated portmanteau? I can not find
>> pc_gamg_mat_partitioning_type in the source.
>> On Thu, Nov 2, 2017 at 6:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Great, thanks,
>>> And could you please add these parameters to a regression test? As I
>>> recall we have with-parmetis regression test.
>>> On Thu, Nov 2, 2017 at 6:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Mark:
>>>> I used petsc/src/ksp/ksp/examples/tutorials/ex56.c :-(
>>>> Now testing src/snes/examples/tutorials/ex56.c with your options, I
>>>> can reproduce the error.
>>>> I'll fix it.
>>>> Hong
>>>> Hong,
>>>>> I've tested with master and I get the same error. Maybe the
>>>>> partitioning parameters are wrong. -pc_gamg_mat_partitioning_type is new to
>>>>> me.
>>>>> Can you run this (snes ex56) w/o the error?
>>>>> 17:33 *master* *= ~*/Codes/petsc/src/snes/examples/tutorials*$ make
>>>>> runex
>>>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 4
>>>>> ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2
>>>>> -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
>>>>> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
>>>>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>>>>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
>>>>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>>>>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
>>>>> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
>>>>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type
>>>>> jacobi -pc_gamg_mat_partitioning_type parmetis -mat_block_size 3 -matrap 0
>>>>> -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition true
>>>>> [0] 27 global equations, 9 vertices
>>>>> [0] 27 equations in vector, 9 vertices
>>>>> 0 SNES Function norm 122.396
>>>>> 0 KSP Residual norm 122.396
>>>>> <snip>
>>>>> depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
>>>>> [0] 4725 global equations, 1575 vertices
>>>>> [0] 4725 equations in vector, 1575 vertices
>>>>> 0 SNES Function norm 17.9091
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> On Thu, Nov 2, 2017 at 1:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Mark :
>>>>>> I realize that using maint or master branch, I cannot reproduce the
>>>>>> same error.
>>>>>> For this example, you must use a parallel partitioner, e.g.,'current'
>>>>>> gives me following error:
>>>>>> [0]PETSC ERROR: This is the DEFAULT NO-OP partitioner, it currently
>>>>>> only supports one domain per processor
>>>>>> use -pc_gamg_mat_partitioning_type parmetis or chaco or ptscotch for
>>>>>> more than one subdomain per processor
>>>>>> Please rebase your branch with maint or master, then see if you still
>>>>>> have problem.
>>>>>> Hong
>>>>>>> On Thu, Nov 2, 2017 at 11:07 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>> Mark,
>>>>>>>> I can reproduce this in an old branch, but not in current maint and
>>>>>>>> master.
>>>>>>>> Which branch are you using to produce this error?
>>>>>>> I am using a branch from Matt. Let me try to merge it with master.
>>>>>>>> Hong
>>>>>>>> On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> I am able to reproduce this with snes ex56 with 2 processors and
>>>>>>>>> adding -pc_gamg_repartition true
>>>>>>>>> I'm not sure how to fix it.
>>>>>>>>> 10:26 1 knepley/feature-plex-boxmesh-create *=
>>>>>>>>> ~/Codes/petsc/src/snes/examples/tutorials$ make
>>>>>>>>> PETSC_DIR=/Users/markadams/Codes/petsc
>>>>>>>>> PETSC_ARCH=arch-macosx-gnu-g runex
>>>>>>>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 2
>>>>>>>>> jacobi -petscpartitioner_type simple -mat_block_size 3 -matrap 0
>>>>>>>>> 1 KSP Residual norm 20.4696
>>>>>>>>> 2 KSP Residual norm 3.95009
>>>>>>>>> 3 KSP Residual norm 0.176181
>>>>>>>>> 4 KSP Residual norm 0.0208781
>>>>>>>>> 5 KSP Residual norm 0.00278873
>>>>>>>>> 6 KSP Residual norm 0.000482741
>>>>>>>>> 7 KSP Residual norm 4.68085e-05
>>>>>>>>> 8 KSP Residual norm 5.42381e-06
>>>>>>>>> 9 KSP Residual norm 5.12785e-07
>>>>>>>>> 10 KSP Residual norm 2.60389e-08
>>>>>>>>> 11 KSP Residual norm 4.96201e-09
>>>>>>>>> 12 KSP Residual norm 1.989e-10
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 12
>>>>>>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
>>>>>>>>> iterations 1
>>>>>>>>> DM Object: Mesh (ex56_) 2 MPI processes
>>>>>>>>> type: plex
>>>>>>>>> Mesh in 3 dimensions:
>>>>>>>>> 0-cells: 12 12
>>>>>>>>> 1-cells: 20 20
>>>>>>>>> 2-cells: 11 11
>>>>>>>>> 3-cells: 2 2
>>>>>>>>> Labels:
>>>>>>>>> Face Sets: 5 strata with value/size (1 (2), 2 (2), 3 (2), 5 (1),
>>>>>>>>> 6 (1))
>>>>>>>>> [0] 441 global equations, 147 vertices
>>>>>>>>> [0] 441 equations in vector, 147 vertices
>>>>>>>>> 0 SNES Function norm 49.7106
>>>>>>>>> 0 KSP Residual norm 49.7106
>>>>>>>>> 1 KSP Residual norm 12.9252
>>>>>>>>> 2 KSP Residual norm 2.38019
>>>>>>>>> 3 KSP Residual norm 0.426307
>>>>>>>>> 4 KSP Residual norm 0.0692155
>>>>>>>>> 5 KSP Residual norm 0.0123092
>>>>>>>>> 6 KSP Residual norm 0.00184874
>>>>>>>>> 7 KSP Residual norm 0.000320761
>>>>>>>>> 8 KSP Residual norm 5.48957e-05
>>>>>>>>> 9 KSP Residual norm 9.90089e-06
>>>>>>>>> 10 KSP Residual norm 1.5127e-06
>>>>>>>>> 11 KSP Residual norm 2.82192e-07
>>>>>>>>> 12 KSP Residual norm 4.62364e-08
>>>>>>>>> 13 KSP Residual norm 7.99573e-09
>>>>>>>>> 14 KSP Residual norm 1.3028e-09
>>>>>>>>> 15 KSP Residual norm 2.174e-10
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 15
>>>>>>>>> 1 SNES Function norm 2.174e-10
>>>>>>>>> iterations 1
>>>>>>>>> type: plex
>>>>>>>>> 0-cells: 45 45
>>>>>>>>> 1-cells: 96 96
>>>>>>>>> 2-cells: 68 68
>>>>>>>>> 3-cells: 16 16
>>>>>>>>> Labels:
>>>>>>>>> marker: 1 strata with value/size (1 (129))
>>>>>>>>> Face Sets: 5 strata with value/size (1 (18), 2 (18), 3 (18), 5
>>>>>>>>> (9), 6 (9))
>>>>>>>>> boundary: 1 strata with value/size (1 (141))
>>>>>>>>> depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3 (16))
>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>> [1]PETSC ERROR: No support for this operation for this object type
>>>>>>>>> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>> wrote:
>>>>>>>>>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>>>>>>>>>> rchurchi at pppl.gov> wrote:
>>>>>>>>>>> Doing some additional testing, the issue goes away when removing
>>>>>>>>>>> the gamg preconditioner line from the petsc.rc:
>>>>>>>>>>> -pc_type gamg
>>>>>>>>>> Yea, this is GAMG setup.
>>>>>>>>>> This is the code. findices is create with ISCreateStride, so it
>>>>>>>>>> is sorted ...
>>>>>>>>>> Michael is repartitioning the coarse grids. Maybe we don't have a
>>>>>>>>>> regression test with this...
>>>>>>>>>> I will try to reproduce this.
>>>>>>>>>> Michael: you can use hypre for now, or turn repartitioning off
>>>>>>>>>> (eg, -fsa_fieldsplit_lambda_upper_pc_gamg_repartition false),
>>>>>>>>>> but I'm not sure this will fix this.
>>>>>>>>>> You don't have hypre parameters for all of your all of your
>>>>>>>>>> solvers. I think 'boomeramg' is the default pc_hypre_type. That should be
>>>>>>>>>> good enough for you.
>>>>>>>>>> IS findices;
>>>>>>>>>> PetscInt Istart,Iend;
>>>>>>>>>> Mat Pnew;
>>>>>>>>>> ierr = MatGetOwnershipRange(Pold, &Istart,
>>>>>>>>>> &Iend);CHKERRQ(ierr);
>>>>>>>>>> #if defined PETSC_GAMG_USE_LOG
>>>>>>>>>> ierr = PetscLogEventBegin(petsc_gamg_
>>>>>>>>>> setup_events[SET15],0,0,0,0);CHKERRQ(ierr);
>>>>>>>>>> #endif
>>>>>>>>>> ierr = ISCreateStride(comm,Iend-Istar
>>>>>>>>>> t,Istart,1,&findices);CHKERRQ(ierr);
>>>>>>>>>> ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>>>>>>>>>> ierr = MatCreateSubMatrix(Pold, findices, new_eq_indices,
>>>>>>>>>> MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>>>>>>>>>> ierr = ISDestroy(&findices);CHKERRQ(ierr);
>>>>>>>>>> ierr = PetscLogEventEnd(petsc_gamg_se
>>>>>>>>>> #endif
>>>>>>>>>> ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>>>>>>>>>> /* output - repartitioned */
>>>>>>>>>> *a_P_inout = Pnew;
>>>>>>>>>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>>>>> Randy:
>>>>>>>>>>>> Thanks, I'll check it tomorrow.
>>>>>>>>>>>> Hong
>>>>>>>>>>>> OK, this might not be completely satisfactory, because it
>>>>>>>>>>>>> doesn't show the partitioning or how the matrix is created, but this
>>>>>>>>>>>>> reproduces the problem. I wrote out my matrix, Amat, from the larger
>>>>>>>>>>>>> simulation, and load it in this script. This must be run with MPI rank
>>>>>>>>>>>>> greater than 1. This may be some combination of my petsc.rc, because when I
>>>>>>>>>>>>> use the PetscInitialize with it, it throws the error, but when using
>>>>>>>>>>>>> default (PETSC_NULL_CHARACTER) it runs fine.
>>>>>>>>>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>> It could be a bug or a missing feature in our new
>>>>>>>>>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>>>>>>>>>> It would be helpful if you can provide us a simple example
>>>>>>>>>>>>>> that produces this example.
>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>> I'm running a Fortran code that was just changed over to
>>>>>>>>>>>>>>> using petsc 3.8 (previously petsc 3.7.6). An error was thrown during a
>>>>>>>>>>>>>>> KSPSetUp() call. The error is "unsorted iscol_local is not implemented yet"
>>>>>>>>>>>>>>> (see full error below). I tried to trace down the difference in the source
>>>>>>>>>>>>>>> files, but where the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist())
>>>>>>>>>>>>>>> doesn't seem to have existed in v3.7.6, so I'm unsure how to compare. It
>>>>>>>>>>>>>>> seems the error is that the order of the columns locally are unsorted,
>>>>>>>>>>>>>>> though I don't think I specify a column order in the creation of the matrix:
>>>>>>>>>>>>>>> call MatCreate(this%comm,AA,ierr)
>>>>>>>>>>>>>>> call MatSetSizes(AA,npetscloc,npets
>>>>>>>>>>>>>>> cloc,nreal,nreal,ierr)
>>>>>>>>>>>>>>> call MatSetType(AA,MATAIJ,ierr)
>>>>>>>>>>>>>>> call MatSetup(AA,ierr)
>>>>>>>>>>>>>>> call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>>>>>>>>>> allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>>>>>>>>>> call getNNZ(grid,npetscloc,low,high
>>>>>>>>>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>>>>>>>>>> call MatSeqAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>>>>>>>>>> call MatMPIAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>>>>>>>>>> deallocate(d_nnz,o_nnz)
>>>>>>>>>>>>>>> call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>>>>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>> call MatSetOption(AA,MAT_KEEP_NONZE
>>>>>>>>>>>>>>> RO_PATTERN,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>> [62]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>> object type
>>>>>>>>>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0,
>>>>>>>>>>>>>>> unknown[62]PETSC ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist()
>>>>>>>>>>>>>>> line 3418 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>> 8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line 3247 in
>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>>>>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>>>>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/ksp/interface/itfu
>>>>>>>>>>>>>>> nc.c
>>>>>>>>>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171107/84709466/attachment-0001.html>
