[petsc-users] Performance of Fieldsplit PC
Tue Nov 7 08:03:39 CST 2017
On Tue, Nov 7, 2017 at 8:43 AM, Bernardo Rocha <
bernardomartinsrocha at gmail.com> wrote:
> Hello everyone,
> I have a general question about the performance of the PCFieldSplit
> that I'm not sure if I understood properly.
> Consider a simple Poisson problem discretized by FEM into a system Ax=b
> which is then solved by CG and Jacobi.
> Then, I create a "vectorial Poisson" problem by simply adding another block
> of this problem to create a block-like version of it.
> Something like
> [ [A, 0]
>   [0, A]]
> then I create a PCFieldSplit with CG and Jacobi for each block.
> Either with additive or multiplicative fieldsplit, the PC is much better
> and solves it
> with fewer iterations than the scalar case. However, the execution time
> taken by
> the PCFieldSplit is much bigger than the simple Jacobi for the scalar case.
> (From -log_view I see all the time difference in PCApply)
> Why is this happening?
1) This is block-Jacobi, why not use PCBJACOBI? Is it because you want to
select rows?
2) We cannot tell anything without knowing how many iterates were used
  -ksp_monitor_true_residual -ksp_converged_reason
-pc_fieldsplit_[0,1]_ksp_monitor_true_residual
3) We cannot say anything about performance without seeing the log for both
runs
  -log_view
     Matt
> Best regards,
> Bernardo
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171107/8071ca39/attachment.html>
