[petsc-users] Newton methods that converge all the time
Tue Nov 7 05:53:44 CST 2017
On Tue, Nov 7, 2017 at 4:19 AM, Buesing, Henrik <
hbuesing at eonerc.rwth-aachen.de> wrote:
> Dear all,
> I am solving a system of nonlinear, transient PDEs. I am using Newton’s
> method in every time step to solve the nonlinear algebraic equations. Of
> course, Newton’s method only converges if the initial guess is sufficiently
> close to the solution.
> This is often not the case and Newton’s method diverges. Then, I reduce
> the time step and try again. This can become prohibitively costly, if the
> time steps get very small. I am thus looking for variants of Newton’s
> method, which have a bigger convergence radius or ideally converge all the
> time.
> I tried out the pseudo-timestepping described in
> http://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/
> tutorials/ex1f.F.html.
> However, this does converge even worse. I am seeing breakdown when I have
> phase changes (e.g. liquid to two-phase).
> I was under the impression that pseudo-timestepping should converge
> better. Thus, my question:
> Am I doing something wrong or is it possible that Newton’s method
> converges and pseudo-timestepping does not?
> Thank you for any insight on this.
Hi Hendrik,
I would try using NGMRES as a nonlinear preconditioner. I have an example
in my tutorial slides for using it with SNES ex19.
I hope this will work because I suspect that around the phase boundary
Newton directions are noisy, since sometimes you
step into the other phase. NGMRES takes a few directions (you set the m)
and then picks the best one.
  Hopefully this helps,
     Matt
> Henrik
> Dipl.-Math. Henrik Büsing
> Institute for Applied Geophysics and Geothermal Energy
> E.ON Energy Research Center
> RWTH Aachen University
> Mathieustr. 10
> <https://maps.google.com/?q=Mathieustr.+10&entry=gmail&source=g>
> |    Tel +49 (0)241 80 49907 <+49%20241%208049907>
> 52074 Aachen, Germany     |    Fax +49 (0)241 80 49889
> <+49%20241%208049889>
> http://www.eonerc.rwth-aachen.de/GGE
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171107/fe824811/attachment.html>
