[petsc-users] SNESGetJacobian Quasi-Newton
Bikash Kanungo
bikash at umich.edu
Mon Nov 6 17:29:00 CST 2017
Thank you so much Matthew. I'll try to wrap the Jacobian inverse as a
MatShell and pass it to SLEPc.
On Mon, Nov 6, 2017 at 2:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 6, 2017 at 2:11 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>> Hi,
>> I would like to access the approximate Jacobian in quasi-Newton solvers
>> (e.g., BFGS) to analyze its condition number. I guess for BFGS, where the
>> approximate Jacobian is built from outer products of several vectors coming
>> from current and previous gradient vectors, the approximate Jacobian might
>> not be stored explicitly as a matrix and instead the Jacobian times a
>> vector is performed in a matrix-free manner. My reason for believing so is
>> the fact that when I try to retrieve the Jacobian matrix using
>> SNESGetJacobian and feed it to SLEPc, I incur segmentation fault at
>> EPSSetOperators.
>> If that's the case, is there a way to still get access to the approximate
>> Jacobian and feed it to SLEPc for eigen analysis, like with the use of
>> MatShell operations?
> There is no code in SNESQN to apply the Jacobian, just its inverse. You
> could wrap up that code in a MatShell and hand it to SLEPc. I am not
> sure what you are looking for, but its doable. I would think there are
> analytic expressions or at least bounds for the condition number.
> Thanks,
> Matt
>> Thanks,
>> Bikash
>> Bikash S. Kanungo
>> PhD Student
>> Computational Materials Physics Group
>> Mechanical Engineering
>> University of Michigan
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
Bikash S. Kanungo
PhD Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171106/4e88e3fc/attachment-0001.html>
