[petsc-users] DMPlex with AMR
Matthew Knepley
knepley at gmail.com
Sun Nov 5 13:06:55 CST 2017
On Sun, Nov 5, 2017 at 2:04 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Nov 5, 2017 at 1:45 PM, Yann Jobic <yann.jobic at univ-amu.fr> wrote:
>> Dear PETSc expert,
>> I first correctly solve the advection/diffusion equation, with the
>> advection/diffusion of a gaussian, in a rotate field.
>> I'm using finit element, with PetscFE and the velocity field is in an
>> auxillary one, in order to correctly set the residual and the jacobian.
>> Then, i would like to use p4est, with AMR. To do that, I re-use the
>> example : "petsc/examples/src/dm/impls/forest/examples/tests/ex2.c"
>> I create a "base" DM, which has everything : PetscFE, PetscDS, the
>> boundaries, ... Then, i correctly adapt the mesh, by using :
>> ierr = DMForestTemplate(base,comm,&postForest);CHKERRQ(ierr);
>> ierr = DMForestSetAdaptivityLabel(postForest,adaptLabel);CHKERRQ(ierr);
>> My problem is that nothing happens when i'm solving the system, i.e. my
>> initial solution does not move, or diffuse.
>> That would mean that i didn't correctly transfer the problem definition.
>> I tried to attach everything to the adapted mesh, without succes.
>> What is the correct way to transfer the problem definition (PetscFE and
>> PetscDS) from one DM to another ?
> One way to do it is just
> DMGetDS(dm, &prob);
> DMSetDS(newdm, prob);
> I think I have this working automatically now in
> knepley/feature-adaptor-plex
> Check out the test in SNES ex12
> make -f ./gmakefile test globsearch="snes_tutorials-runex12_quad_q1_adapt_0"
> EXTRA_OPTIONS="-dm_adapt_view hdf5:$PWD/adapt.h5"
> ./bin/petsc_gen_xdmf.py adapt.h5
> and then look at adapt.xmf in Paraview. This also works if you try it with
> simplicial meshes and Pragmatic, see tri_p1_adapt_1.
I just looked at your code. That is not going to adapt I think because
there is nothing in TS to do it automatically yet. You can see it done by
hand
in TS ex11. I am slowly marching through getting all this stuff hooked up.
I will get to TS hopefully by the end of the year.
Matt
> Thanks,
> Matt
>> Many thanks in advance,
>> Regards,
>> Yann
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171105/254d1b5d/attachment.html>
