[petsc-users] petsc with fortran modules
Ed D'Azevedo
dazevedoef at ornl.gov
Fri Nov 3 17:33:56 CDT 2017
Dear PETSc expert,
I have a question on the correct way to use Fortran module in petsc.
In this url on "UsingFortran"
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html#UsingFortran
it mentions including both the "petsc/finclude/petscXXX.h" file and the
Fortran "use" statement.
The example show the following:
#include "petsc/finclude/petscvec.h"
use petscvec
Vec b
type(tVec) x
My understanding of Fortran syntax is there cannot be "parameter"
statements before the module "use" statement or in other words "use"
statement cannot follow "parameter" statement.
Do I understand correctly then all ".h" include header files under
"petsc/finclude/" should not have "parameter" statements but just pure
cpp macro statements such as "#define" or "#ifdef"?
One may imagine substituting "parameter" statements with '#define' such
as instead of
parameter (NOT_SET_VALUES=0)
#define NOT_SET_VALUES 0
#define not_set_values 0
In the petsc version 3.6.2 under include/petsc/finclude, there seems
to be some files such as petscvec.h and petscmat.h that contain
"parameter" statements.
If there should be "parameter" statements in the petsc/finclude header
files, perhaps the order of the code should be to list all F90 module
"use" statements first, then include 'petsc/finclude' header files?
! parameter statements after the module use statement
use petscvec
Vec b
type(tVec) x
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171103/e74c8462/attachment.html>
