[petsc-users] unsorted local columns in 3.8?
    Mark Adams
    mfadams at lbl.gov
    Thu Nov  2 17:54:39 CDT 2017
Also, I have been using -petscpartition_type but now I see
-pc_gamg_mat_partitioning_type.
Is -petscpartition_type depreciated for GAMG?
Is this some sort of auto generated portmanteau? I can not find
in the source.
On Thu, Nov 2, 2017 at 6:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Great, thanks,
> And could you please add these parameters to a regression test? As I
> recall we have with-parmetis regression test.
> On Thu, Nov 2, 2017 at 6:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> Mark:
>> I used petsc/src/ksp/ksp/examples/tutorials/ex56.c :-(
>> Now testing src/snes/examples/tutorials/ex56.c with your options, I can
>> reproduce the error.
>> I'll fix it.
>> Hong
>> Hong,
>>> I've tested with master and I get the same error. Maybe the partitioning
>>> parameters are wrong. -pc_gamg_mat_partitioning_type is new to me.
>>> Can you run this (snes ex56) w/o the error?
>>> 17:33 *master* *= ~*/Codes/petsc/src/snes/examples/tutorials*$ make
>>> runex
>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 4 ./ex56
>>> -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2 -ksp_max_it
>>> 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type unpreconditioned
>>> -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
>>> -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true
>>> -pc_gamg_square_graph 1 -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0
>>> -ksp_converged_reason -snes_monitor_short -ksp_monitor_short
>>> -snes_converged_reason -use_mat_nearnullspace true -mg_levels_ksp_max_it 1
>>> -mg_levels_ksp_type chebyshev -mg_levels_esteig_ksp_type cg
>>> -mg_levels_esteig_ksp_max_it 10 -mg_levels_ksp_chebyshev_esteig
>>> 0,0.05,0,1.05 -mg_levels_pc_type jacobi -pc_gamg_mat_partitioning_type
>>> parmetis -mat_block_size 3 -matrap 0 -matptap_scalable -ex56_dm_view
>>> -run_type 1 -pc_gamg_repartition true
>>> [0] 27 global equations, 9 vertices
>>> [0] 27 equations in vector, 9 vertices
>>>   0 SNES Function norm 122.396
>>>     0 KSP Residual norm 122.396
>>>   <snip>
>>>   depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
>>> [0] 4725 global equations, 1575 vertices
>>> [0] 4725 equations in vector, 1575 vertices
>>>   0 SNES Function norm 17.9091
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: No support for this operation for this object type
>>> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> On Thu, Nov 2, 2017 at 1:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Mark :
>>>> I realize that using maint or master branch, I cannot reproduce the
>>>> same error.
>>>> For this example, you must use a parallel partitioner, e.g.,'current'
>>>> gives me following error:
>>>> [0]PETSC ERROR: This is the DEFAULT NO-OP partitioner, it currently
>>>> only supports one domain per processor
>>>> use -pc_gamg_mat_partitioning_type parmetis or chaco or ptscotch for
>>>> more than one subdomain per processor
>>>> Please rebase your branch with maint or master, then see if you still
>>>> have problem.
>>>> Hong
>>>>> On Thu, Nov 2, 2017 at 11:07 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Mark,
>>>>>> I can reproduce this in an old branch, but not in current maint and
>>>>>> master.
>>>>>> Which branch are you using to produce this error?
>>>>> I am using a branch from Matt. Let me try to merge it with master.
>>>>>> Hong
>>>>>> On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> I am able to reproduce this with snes ex56 with 2 processors and
>>>>>>> adding -pc_gamg_repartition true
>>>>>>> I'm not sure how to fix it.
>>>>>>> 10:26 1 knepley/feature-plex-boxmesh-create *=
>>>>>>> ~/Codes/petsc/src/snes/examples/tutorials$ make
>>>>>>> PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-g
>>>>>>> runex
>>>>>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 2
>>>>>>> ./ex56  -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2
>>>>>>> -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>>>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
>>>>>>> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
>>>>>>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>>>>>>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
>>>>>>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>>>>>>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
>>>>>>> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
>>>>>>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type
>>>>>>> jacobi -petscpartitioner_type simple -mat_block_size 3 -matrap 0
>>>>>>> -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition true
>>>>>>>     1 KSP Residual norm 20.4696
>>>>>>>     2 KSP Residual norm 3.95009
>>>>>>>     3 KSP Residual norm 0.176181
>>>>>>>     4 KSP Residual norm 0.0208781
>>>>>>>     5 KSP Residual norm 0.00278873
>>>>>>>     6 KSP Residual norm 0.000482741
>>>>>>>     7 KSP Residual norm 4.68085e-05
>>>>>>>     8 KSP Residual norm 5.42381e-06
>>>>>>>     9 KSP Residual norm 5.12785e-07
>>>>>>>    10 KSP Residual norm 2.60389e-08
>>>>>>>    11 KSP Residual norm 4.96201e-09
>>>>>>>    12 KSP Residual norm 1.989e-10
>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 12
>>>>>>>   1 SNES Function norm 1.990e-10
>>>>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations
>>>>>>> 1
>>>>>>> DM Object: Mesh (ex56_) 2 MPI processes
>>>>>>>   type: plex
>>>>>>> Mesh in 3 dimensions:
>>>>>>>   0-cells: 12 12
>>>>>>>   1-cells: 20 20
>>>>>>>   2-cells: 11 11
>>>>>>>   3-cells: 2 2
>>>>>>> Labels:
>>>>>>>   boundary: 1 strata with value/size (1 (39))
>>>>>>>   Face Sets: 5 strata with value/size (1 (2), 2 (2), 3 (2), 5 (1), 6
>>>>>>> (1))
>>>>>>>   marker: 1 strata with value/size (1 (27))
>>>>>>>   depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
>>>>>>> [0] 441 global equations, 147 vertices
>>>>>>> [0] 441 equations in vector, 147 vertices
>>>>>>>   0 SNES Function norm 49.7106
>>>>>>>     0 KSP Residual norm 49.7106
>>>>>>>     1 KSP Residual norm 12.9252
>>>>>>>     2 KSP Residual norm 2.38019
>>>>>>>     3 KSP Residual norm 0.426307
>>>>>>>     4 KSP Residual norm 0.0692155
>>>>>>>     5 KSP Residual norm 0.0123092
>>>>>>>     6 KSP Residual norm 0.00184874
>>>>>>>     7 KSP Residual norm 0.000320761
>>>>>>>     8 KSP Residual norm 5.48957e-05
>>>>>>>     9 KSP Residual norm 9.90089e-06
>>>>>>>    10 KSP Residual norm 1.5127e-06
>>>>>>>    11 KSP Residual norm 2.82192e-07
>>>>>>>    12 KSP Residual norm 4.62364e-08
>>>>>>>    13 KSP Residual norm 7.99573e-09
>>>>>>>    14 KSP Residual norm 1.3028e-09
>>>>>>>    15 KSP Residual norm 2.174e-10
>>>>>>>   Linear solve converged due to CONVERGED_RTOL iterations 15
>>>>>>>   1 SNES Function norm 2.174e-10
>>>>>>> 1
>>>>>>>   type: plex
>>>>>>>   0-cells: 45 45
>>>>>>>   1-cells: 96 96
>>>>>>>   2-cells: 68 68
>>>>>>>   3-cells: 16 16
>>>>>>> Labels:
>>>>>>>   marker: 1 strata with value/size (1 (129))
>>>>>>>   Face Sets: 5 strata with value/size (1 (18), 2 (18), 3 (18), 5
>>>>>>> (9), 6 (9))
>>>>>>>   boundary: 1 strata with value/size (1 (141))
>>>>>>>   depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3 (16))
>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>> [1]PETSC ERROR: No support for this operation for this object type
>>>>>>> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>>>>>>>> rchurchi at pppl.gov> wrote:
>>>>>>>>> Doing some additional testing, the issue goes away when removing
>>>>>>>>> the gamg preconditioner line from the petsc.rc:
>>>>>>>>> -pc_type gamg
>>>>>>>> Yea, this is GAMG setup.
>>>>>>>> This is the code.  findices is create with ISCreateStride, so it is
>>>>>>>> sorted ...
>>>>>>>> Michael is repartitioning the coarse grids. Maybe we don't have a
>>>>>>>> regression test with this...
>>>>>>>> I will try to reproduce this.
>>>>>>>> Michael: you can use hypre for now, or turn repartitioning off (eg,
>>>>>>>> -fsa_fieldsplit_lambda_upper_pc_gamg_repartition false), but I'm
>>>>>>>> not sure this will fix this.
>>>>>>>> You don't have hypre parameters for all of your all of your
>>>>>>>> solvers. I think 'boomeramg' is the default pc_hypre_type. That should be
>>>>>>>> good enough for you.
>>>>>>>>       IS       findices;
>>>>>>>>       PetscInt Istart,Iend;
>>>>>>>>       Mat      Pnew;
>>>>>>>>       ierr = MatGetOwnershipRange(Pold, &Istart,
>>>>>>>> &Iend);CHKERRQ(ierr);
>>>>>>>> #if defined PETSC_GAMG_USE_LOG
>>>>>>>>       ierr = PetscLogEventBegin(petsc_gamg_
>>>>>>>> setup_events[SET15],0,0,0,0);CHKERRQ(ierr);
>>>>>>>> #endif
>>>>>>>>       ierr = ISCreateStride(comm,Iend-Istar
>>>>>>>> t,Istart,1,&findices);CHKERRQ(ierr);
>>>>>>>>       ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>>>>>>>>       ierr = MatCreateSubMatrix(Pold, findices, new_eq_indices,
>>>>>>>> MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>>>>>>>>       ierr = ISDestroy(&findices);CHKERRQ(ierr);
>>>>>>>>       ierr = PetscLogEventEnd(petsc_gamg_se
>>>>>>>> #endif
>>>>>>>>       ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>>>>>>>>       /* output - repartitioned */
>>>>>>>>       *a_P_inout = Pnew;
>>>>>>>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>>> Randy:
>>>>>>>>>> Thanks, I'll check it tomorrow.
>>>>>>>>>> Hong
>>>>>>>>>> OK, this might not be completely satisfactory, because it doesn't
>>>>>>>>>>> show the partitioning or how the matrix is created, but this reproduces the
>>>>>>>>>>> problem. I wrote out my matrix, Amat, from the larger simulation, and load
>>>>>>>>>>> it in this script. This must be run with MPI rank greater than 1. This may
>>>>>>>>>>> be some combination of my petsc.rc, because when I use the PetscInitialize
>>>>>>>>>>> with it, it throws the error, but when using default (PETSC_NULL_CHARACTER)
>>>>>>>>>>> it runs fine.
>>>>>>>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Randy:
>>>>>>>>>>>> It could be a bug or a missing feature in our new
>>>>>>>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>>>>>>>> It would be helpful if you can provide us a simple example that
>>>>>>>>>>>> produces this example.
>>>>>>>>>>>> Hong
>>>>>>>>>>>> I'm running a Fortran code that was just changed over to using
>>>>>>>>>>>>> petsc 3.8 (previously petsc 3.7.6). An error was thrown during a KSPSetUp()
>>>>>>>>>>>>> call. The error is "unsorted iscol_local is not implemented yet" (see full
>>>>>>>>>>>>> error below). I tried to trace down the difference in the source files, but
>>>>>>>>>>>>> where the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist())
>>>>>>>>>>>>> doesn't seem to have existed in v3.7.6, so I'm unsure how to compare. It
>>>>>>>>>>>>> seems the error is that the order of the columns locally are unsorted,
>>>>>>>>>>>>> though I don't think I specify a column order in the creation of the matrix:
>>>>>>>>>>>>>      call MatCreate(this%comm,AA,ierr)
>>>>>>>>>>>>>      call MatSetSizes(AA,npetscloc,npetscloc,nreal,nreal,ierr)
>>>>>>>>>>>>>      call MatSetType(AA,MATAIJ,ierr)
>>>>>>>>>>>>>      call MatSetup(AA,ierr)
>>>>>>>>>>>>>      call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>>>>>>>>      allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>>>>>>>>      call getNNZ(grid,npetscloc,low,high
>>>>>>>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>>>>>>>>      call MatSeqAIJSetPreallocation(AA,P
>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>>>>>>>>      call MatMPIAIJSetPreallocation(AA,P
>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>>>>>>>>      deallocate(d_nnz,o_nnz)
>>>>>>>>>>>>>      call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>>>>>>>>      call MatSetOption(AA,MAT_KEEP_NONZE
>>>>>>>>>>>>> RO_PATTERN,PETSC_TRUE,ierr)
>>>>>>>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>> [62]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>>>> type
>>>>>>>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0, unknown[62]PETSC
>>>>>>>>>>>>> ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist() line 3418
>>>>>>>>>>>>> in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>> 8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line 3247 in
>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/ksp/interface/itfu
>>>>>>>>>>>>> nc.c
>>>>>>>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171102/76b49645/attachment-0001.html>
