[petsc-users] unsorted local columns in 3.8?
Hong hzhang at mcs.anl.gov
Thu Nov 2 12:35:28 CDT 2017
Mark :
I realize that using maint or master branch, I cannot reproduce the same
error.
For this example, you must use a parallel partitioner, e.g.,'current' gives
me following error:
[0]PETSC ERROR: This is the DEFAULT NO-OP partitioner, it currently only
supports one domain per processor
use -pc_gamg_mat_partitioning_type parmetis or chaco or ptscotch for more
than one subdomain per processor
Please rebase your branch with maint or master, then see if you still have
problem.
Hong
> On Thu, Nov 2, 2017 at 11:07 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> Mark,
>> I can reproduce this in an old branch, but not in current maint and
>> master.
>> Which branch are you using to produce this error?
> I am using a branch from Matt. Let me try to merge it with master.
>> Hong
>> On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> I am able to reproduce this with snes ex56 with 2 processors and adding
>>> -pc_gamg_repartition true
>>> I'm not sure how to fix it.
>>> 10:26 1 knepley/feature-plex-boxmesh-create *=
>>> ~/Codes/petsc/src/snes/examples/tutorials$ make
>>> PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-g
>>> runex
>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 2 ./ex56
>>> -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2 -ksp_max_it
>>> 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type unpreconditioned
>>> -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
>>> -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true
>>> -pc_gamg_square_graph 1 -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0
>>> -ksp_converged_reason -snes_monitor_short -ksp_monitor_short
>>> -snes_converged_reason -use_mat_nearnullspace true -mg_levels_ksp_max_it 1
>>> -mg_levels_ksp_type chebyshev -mg_levels_esteig_ksp_type cg
>>> -mg_levels_esteig_ksp_max_it 10 -mg_levels_ksp_chebyshev_esteig
>>> 0,0.05,0,1.05 -mg_levels_pc_type jacobi -petscpartitioner_type simple
>>> -mat_block_size 3 -matrap 0 -matptap_scalable -ex56_dm_view -run_type 1
>>> [0] 27 global equations, 9 vertices
>>> [0] 27 equations in vector, 9 vertices
>>>   0 SNES Function norm 122.396
>>>     0 KSP Residual norm 122.396
>>>     1 KSP Residual norm 20.4696
>>>     2 KSP Residual norm 3.95009
>>>     3 KSP Residual norm 0.176181
>>>     4 KSP Residual norm 0.0208781
>>>     5 KSP Residual norm 0.00278873
>>>     6 KSP Residual norm 0.000482741
>>>     7 KSP Residual norm 4.68085e-05
>>>     8 KSP Residual norm 5.42381e-06
>>>     9 KSP Residual norm 5.12785e-07
>>>    10 KSP Residual norm 2.60389e-08
>>>    11 KSP Residual norm 4.96201e-09
>>>    12 KSP Residual norm 1.989e-10
>>>   Linear solve converged due to CONVERGED_RTOL iterations 12
>>>   1 SNES Function norm 1.990e-10
>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
>>> DM Object: Mesh (ex56_) 2 MPI processes
>>>   type: plex
>>> Mesh in 3 dimensions:
>>>   0-cells: 12 12
>>>   1-cells: 20 20
>>>   2-cells: 11 11
>>>   3-cells: 2 2
>>> Labels:
>>>   boundary: 1 strata with value/size (1 (39))
>>>   Face Sets: 5 strata with value/size (1 (2), 2 (2), 3 (2), 5 (1), 6 (1))
>>>   marker: 1 strata with value/size (1 (27))
>>>   depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
>>> [0] 441 global equations, 147 vertices
>>> [0] 441 equations in vector, 147 vertices
>>>   0 SNES Function norm 49.7106
>>>     0 KSP Residual norm 49.7106
>>>     1 KSP Residual norm 12.9252
>>>     2 KSP Residual norm 2.38019
>>>     3 KSP Residual norm 0.426307
>>>     4 KSP Residual norm 0.0692155
>>>     5 KSP Residual norm 0.0123092
>>>     6 KSP Residual norm 0.00184874
>>>     7 KSP Residual norm 0.000320761
>>>     8 KSP Residual norm 5.48957e-05
>>>     9 KSP Residual norm 9.90089e-06
>>>    10 KSP Residual norm 1.5127e-06
>>>    11 KSP Residual norm 2.82192e-07
>>>    12 KSP Residual norm 4.62364e-08
>>>    13 KSP Residual norm 7.99573e-09
>>>    14 KSP Residual norm 1.3028e-09
>>>    15 KSP Residual norm 2.174e-10
>>>   Linear solve converged due to CONVERGED_RTOL iterations 15
>>>   1 SNES Function norm 2.174e-10
>>>   type: plex
>>>   0-cells: 45 45
>>>   1-cells: 96 96
>>>   2-cells: 68 68
>>>   3-cells: 16 16
>>> Labels:
>>>   marker: 1 strata with value/size (1 (129))
>>>   Face Sets: 5 strata with value/size (1 (18), 2 (18), 3 (18), 5 (9), 6
>>> (9))
>>>   boundary: 1 strata with value/size (1 (141))
>>>   depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3 (16))
>>> [0] 4725 global equations, 1575 vertices
>>> [0] 4725 equations in vector, 1575 vertices
>>>   0 SNES Function norm 17.9091
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: No support for this operation for this object type
>>> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: No support for this operation for this object type
>>> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
>>> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>>>> rchurchi at pppl.gov> wrote:
>>>>> Doing some additional testing, the issue goes away when removing the
>>>>> gamg preconditioner line from the petsc.rc:
>>>>> -pc_type gamg
>>>> Yea, this is GAMG setup.
>>>> This is the code.  findices is create with ISCreateStride, so it is
>>>> sorted ...
>>>> Michael is repartitioning the coarse grids. Maybe we don't have a
>>>> regression test with this...
>>>> I will try to reproduce this.
>>>> Michael: you can use hypre for now, or turn repartitioning off (eg,
>>>> -fsa_fieldsplit_lambda_upper_pc_gamg_repartition false), but I'm not
>>>> sure this will fix this.
>>>> You don't have hypre parameters for all of your all of your solvers. I
>>>> think 'boomeramg' is the default pc_hypre_type. That should be good enough
>>>> for you.
>>>>       IS       findices;
>>>>       PetscInt Istart,Iend;
>>>>       Mat      Pnew;
>>>>       ierr = MatGetOwnershipRange(Pold, &Istart, &Iend);CHKERRQ(ierr);
>>>> #if defined PETSC_GAMG_USE_LOG
>>>>       ierr = PetscLogEventBegin(petsc_gamg_
>>>> setup_events[SET15],0,0,0,0);CHKERRQ(ierr);
>>>> #endif
>>>>       ierr = ISCreateStride(comm,Iend-Istar
>>>> t,Istart,1,&findices);CHKERRQ(ierr);
>>>>       ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>>>>       ierr = MatCreateSubMatrix(Pold, findices, new_eq_indices,
>>>> MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>>>>       ierr = ISDestroy(&findices);CHKERRQ(ierr);
>>>>       ierr = PetscLogEventEnd(petsc_gamg_se
>>>> #endif
>>>>       ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>>>>       /* output - repartitioned */
>>>>       *a_P_inout = Pnew;
>>>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Randy:
>>>>>> Thanks, I'll check it tomorrow.
>>>>>> Hong
>>>>>> OK, this might not be completely satisfactory, because it doesn't
>>>>>>> show the partitioning or how the matrix is created, but this reproduces the
>>>>>>> problem. I wrote out my matrix, Amat, from the larger simulation, and load
>>>>>>> it in this script. This must be run with MPI rank greater than 1. This may
>>>>>>> be some combination of my petsc.rc, because when I use the PetscInitialize
>>>>>>> with it, it throws the error, but when using default (PETSC_NULL_CHARACTER)
>>>>>>> it runs fine.
>>>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>> Randy:
>>>>>>>> It could be a bug or a missing feature in our new
>>>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>>>> It would be helpful if you can provide us a simple example that
>>>>>>>> produces this example.
>>>>>>>> Hong
>>>>>>>> I'm running a Fortran code that was just changed over to using
>>>>>>>>> petsc 3.8 (previously petsc 3.7.6). An error was thrown during a KSPSetUp()
>>>>>>>>> call. The error is "unsorted iscol_local is not implemented yet" (see full
>>>>>>>>> error below). I tried to trace down the difference in the source files, but
>>>>>>>>> where the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist())
>>>>>>>>> doesn't seem to have existed in v3.7.6, so I'm unsure how to compare. It
>>>>>>>>> seems the error is that the order of the columns locally are unsorted,
>>>>>>>>> though I don't think I specify a column order in the creation of the matrix:
>>>>>>>>>      call MatCreate(this%comm,AA,ierr)
>>>>>>>>>      call MatSetSizes(AA,npetscloc,npetscloc,nreal,nreal,ierr)
>>>>>>>>>      call MatSetType(AA,MATAIJ,ierr)
>>>>>>>>>      call MatSetup(AA,ierr)
>>>>>>>>>      call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>>>>      allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>>>>      call getNNZ(grid,npetscloc,low,high
>>>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>>>>      call MatSeqAIJSetPreallocation(AA,P
>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>>>>      call MatMPIAIJSetPreallocation(AA,P
>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>>>>      deallocate(d_nnz,o_nnz)
>>>>>>>>>      call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>>>>      call MatSetOption(AA,MAT_KEEP_NONZE
>>>>>>>>> RO_PATTERN,PETSC_TRUE,ierr)
>>>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>>>> [62]PETSC ERROR: No support for this operation for this object type
>>>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0, unknown[62]PETSC
>>>>>>>>> ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist() line 3418 in
>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line 3247 in
>>>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/interface/precon.c
>>>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/ksp/interface/itfunc.c
>>>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171102/1ecdb80f/attachment.html>
