[petsc-users] unsorted local columns in 3.8?
Hong
hzhang at mcs.anl.gov
Thu Nov 2 10:07:28 CDT 2017
Mark,
I can reproduce this in an old branch, but not in current maint and master.
Which branch are you using to produce this error?
Hong
On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I am able to reproduce this with snes ex56 with 2 processors and adding
> -pc_gamg_repartition true
> I'm not sure how to fix it.
> 10:26 1 knepley/feature-plex-boxmesh-create *= ~/Codes/petsc/src/snes/examples/tutorials$
> make PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-g
> runex
> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 2 ./ex56
> -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2 -ksp_max_it
> 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type unpreconditioned
> -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
> -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true
> -pc_gamg_square_graph 1 -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0
> -ksp_converged_reason -snes_monitor_short -ksp_monitor_short
> -snes_converged_reason -use_mat_nearnullspace true -mg_levels_ksp_max_it 1
> -mg_levels_ksp_type chebyshev -mg_levels_esteig_ksp_type cg
> -mg_levels_esteig_ksp_max_it 10 -mg_levels_ksp_chebyshev_esteig
> 0,0.05,0,1.05 -mg_levels_pc_type jacobi -petscpartitioner_type simple
> -mat_block_size 3 -matrap 0 -matptap_scalable -ex56_dm_view -run_type 1
> [0] 27 global equations, 9 vertices
> [0] 27 equations in vector, 9 vertices
> 0 SNES Function norm 122.396
> 0 KSP Residual norm 122.396
> 1 KSP Residual norm 20.4696
> 2 KSP Residual norm 3.95009
> 3 KSP Residual norm 0.176181
> 4 KSP Residual norm 0.0208781
> 5 KSP Residual norm 0.00278873
> 6 KSP Residual norm 0.000482741
> 7 KSP Residual norm 4.68085e-05
> 8 KSP Residual norm 5.42381e-06
> 9 KSP Residual norm 5.12785e-07
> 10 KSP Residual norm 2.60389e-08
> 11 KSP Residual norm 4.96201e-09
> 12 KSP Residual norm 1.989e-10
> Linear solve converged due to CONVERGED_RTOL iterations 12
> 1 SNES Function norm 1.990e-10
> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
> DM Object: Mesh (ex56_) 2 MPI processes
> type: plex
> Mesh in 3 dimensions:
> 0-cells: 12 12
> 1-cells: 20 20
> 2-cells: 11 11
> 3-cells: 2 2
> Labels:
> boundary: 1 strata with value/size (1 (39))
> Face Sets: 5 strata with value/size (1 (2), 2 (2), 3 (2), 5 (1), 6 (1))
> marker: 1 strata with value/size (1 (27))
> depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
> [0] 441 global equations, 147 vertices
> [0] 441 equations in vector, 147 vertices
> 0 SNES Function norm 49.7106
> 0 KSP Residual norm 49.7106
> 1 KSP Residual norm 12.9252
> 2 KSP Residual norm 2.38019
> 3 KSP Residual norm 0.426307
> 4 KSP Residual norm 0.0692155
> 5 KSP Residual norm 0.0123092
> 6 KSP Residual norm 0.00184874
> 7 KSP Residual norm 0.000320761
> 8 KSP Residual norm 5.48957e-05
> 9 KSP Residual norm 9.90089e-06
> 10 KSP Residual norm 1.5127e-06
> 11 KSP Residual norm 2.82192e-07
> 12 KSP Residual norm 4.62364e-08
> 13 KSP Residual norm 7.99573e-09
> 14 KSP Residual norm 1.3028e-09
> 15 KSP Residual norm 2.174e-10
> Linear solve converged due to CONVERGED_RTOL iterations 15
> 1 SNES Function norm 2.174e-10
> type: plex
> 0-cells: 45 45
> 1-cells: 96 96
> 2-cells: 68 68
> 3-cells: 16 16
> Labels:
> marker: 1 strata with value/size (1 (129))
> Face Sets: 5 strata with value/size (1 (18), 2 (18), 3 (18), 5 (9), 6
> (9))
> boundary: 1 strata with value/size (1 (141))
> depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3 (16))
> [0] 4725 global equations, 1575 vertices
> [0] 4725 equations in vector, 1575 vertices
> 0 SNES Function norm 17.9091
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: No support for this operation for this object type
> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>> rchurchi at pppl.gov> wrote:
>>> Doing some additional testing, the issue goes away when removing the
>>> gamg preconditioner line from the petsc.rc:
>>> -pc_type gamg
>> Yea, this is GAMG setup.
>> This is the code. findices is create with ISCreateStride, so it is
>> sorted ...
>> Michael is repartitioning the coarse grids. Maybe we don't have a
>> regression test with this...
>> I will try to reproduce this.
>> Michael: you can use hypre for now, or turn repartitioning off (eg,
>> -fsa_fieldsplit_lambda_upper_pc_gamg_repartition false), but I'm not
>> sure this will fix this.
>> You don't have hypre parameters for all of your all of your solvers. I
>> think 'boomeramg' is the default pc_hypre_type. That should be good enough
>> for you.
>> IS findices;
>> PetscInt Istart,Iend;
>> Mat Pnew;
>> ierr = MatGetOwnershipRange(Pold, &Istart, &Iend);CHKERRQ(ierr);
>> #if defined PETSC_GAMG_USE_LOG
>> ierr = PetscLogEventBegin(petsc_gamg_setup_events[SET15],0,0,0,0);C
>> HKERRQ(ierr);
>> #endif
>> ierr = ISCreateStride(comm,Iend-Istart,Istart,1,&findices);CHKERRQ(
>> ierr);
>> ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>> ierr = MatCreateSubMatrix(Pold, findices, new_eq_indices,
>> MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>> ierr = ISDestroy(&findices);CHKERRQ(ierr);
>> ierr = PetscLogEventEnd(petsc_gamg_setup_events[SET15],0,0,0,0);CHK
>> ERRQ(ierr);
>> #endif
>> ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>> /* output - repartitioned */
>> *a_P_inout = Pnew;
>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Randy:
>>>> Thanks, I'll check it tomorrow.
>>>> Hong
>>>> OK, this might not be completely satisfactory, because it doesn't show
>>>>> the partitioning or how the matrix is created, but this reproduces the
>>>>> problem. I wrote out my matrix, Amat, from the larger simulation, and load
>>>>> it in this script. This must be run with MPI rank greater than 1. This may
>>>>> be some combination of my petsc.rc, because when I use the PetscInitialize
>>>>> with it, it throws the error, but when using default (PETSC_NULL_CHARACTER)
>>>>> it runs fine.
>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Randy:
>>>>>> It could be a bug or a missing feature in our new
>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>> It would be helpful if you can provide us a simple example that
>>>>>> produces this example.
>>>>>> Hong
>>>>>> I'm running a Fortran code that was just changed over to using petsc
>>>>>>> 3.8 (previously petsc 3.7.6). An error was thrown during a KSPSetUp() call.
>>>>>>> The error is "unsorted iscol_local is not implemented yet" (see full error
>>>>>>> below). I tried to trace down the difference in the source files, but where
>>>>>>> the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist()) doesn't
>>>>>>> seem to have existed in v3.7.6, so I'm unsure how to compare. It seems the
>>>>>>> error is that the order of the columns locally are unsorted, though I don't
>>>>>>> think I specify a column order in the creation of the matrix:
>>>>>>> call MatCreate(this%comm,AA,ierr)
>>>>>>> call MatSetSizes(AA,npetscloc,npetscloc,nreal,nreal,ierr)
>>>>>>> call MatSetType(AA,MATAIJ,ierr)
>>>>>>> call MatSetup(AA,ierr)
>>>>>>> call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>> allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>> call getNNZ(grid,npetscloc,low,high
>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>> call MatSeqAIJSetPreallocation(AA,P
>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>> call MatMPIAIJSetPreallocation(AA,P
>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>> deallocate(d_nnz,o_nnz)
>>>>>>> call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>> call MatSetOption(AA,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE,ierr)
>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>> [62]PETSC ERROR: No support for this operation for this object type
>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0, unknown[62]PETSC
>>>>>>> ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist() line 3418 in
>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line 3247 in
>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/interface/precon.c
>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/ksp/interface/itfunc.c
>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171102/5b44ef29/attachment-0001.html>
