[petsc-users] unsorted local columns in 3.8?
Randy Michael Churchill rchurchi at pppl.gov
Thu Nov 2 09:27:31 CDT 2017
Thanks Mark, both your suggestions of using pc hypre or turning off
repartitioning does indeed make the error go away.
On Thu, Nov 2, 2017 at 8:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <rchurchi at pppl.gov
> > wrote:
>> Doing some additional testing, the issue goes away when removing the gamg
>> preconditioner line from the petsc.rc:
>> -pc_type gamg
> Yea, this is GAMG setup.
> This is the code.  findices is create with ISCreateStride, so it is sorted
> Michael is repartitioning the coarse grids. Maybe we don't have a
> regression test with this...
> I will try to reproduce this.
> Michael: you can use hypre for now, or turn repartitioning off (eg,
> -fsa_fieldsplit_lambda_upper_pc_gamg_repartition false), but I'm not sure
> this will fix this.
> You don't have hypre parameters for all of your all of your solvers. I
> think 'boomeramg' is the default pc_hypre_type. That should be good enough
> for you.
>       IS       findices;
>       PetscInt Istart,Iend;
>       Mat      Pnew;
>       ierr = MatGetOwnershipRange(Pold, &Istart, &Iend);CHKERRQ(ierr);
> #if defined PETSC_GAMG_USE_LOG
>       ierr = PetscLogEventBegin(petsc_gamg_setup_events[SET15],0,0,0,0);
> CHKERRQ(ierr);
> #endif
>       ierr = ISCreateStride(comm,Iend-Istart,Istart,1,&findices);
> CHKERRQ(ierr);
>       ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>       ierr = MatCreateSubMatrix(Pold, findices, new_eq_indices,
> MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>       ierr = ISDestroy(&findices);CHKERRQ(ierr);
>       ierr = PetscLogEventEnd(petsc_gamg_setup_events[SET15],0,0,0,0);
> CHKERRQ(ierr);
> #endif
>       ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>       /* output - repartitioned */
>       *a_P_inout = Pnew;
>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>> Randy:
>>> Thanks, I'll check it tomorrow.
>>> Hong
>>> OK, this might not be completely satisfactory, because it doesn't show
>>>> the partitioning or how the matrix is created, but this reproduces the
>>>> problem. I wrote out my matrix, Amat, from the larger simulation, and load
>>>> it in this script. This must be run with MPI rank greater than 1. This may
>>>> be some combination of my petsc.rc, because when I use the PetscInitialize
>>>> with it, it throws the error, but when using default (PETSC_NULL_CHARACTER)
>>>> it runs fine.
>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>> Randy:
>>>>> It could be a bug or a missing feature in our new
>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>> It would be helpful if you can provide us a simple example that
>>>>> produces this example.
>>>>> Hong
>>>>> I'm running a Fortran code that was just changed over to using petsc
>>>>>> 3.8 (previously petsc 3.7.6). An error was thrown during a KSPSetUp() call.
>>>>>> The error is "unsorted iscol_local is not implemented yet" (see full error
>>>>>> below). I tried to trace down the difference in the source files, but where
>>>>>> the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist()) doesn't
>>>>>> seem to have existed in v3.7.6, so I'm unsure how to compare. It seems the
>>>>>> error is that the order of the columns locally are unsorted, though I don't
>>>>>> think I specify a column order in the creation of the matrix:
>>>>>>      call MatCreate(this%comm,AA,ierr)
>>>>>>      call MatSetSizes(AA,npetscloc,npetscloc,nreal,nreal,ierr)
>>>>>>      call MatSetType(AA,MATAIJ,ierr)
>>>>>>      call MatSetup(AA,ierr)
>>>>>>      call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>      allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>      call getNNZ(grid,npetscloc,low,high
>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>      call MatSeqAIJSetPreallocation(AA,PETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>      call MatMPIAIJSetPreallocation(AA,P
>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>      deallocate(d_nnz,o_nnz)
>>>>>>      call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>      call MatSetOption(AA,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE,ierr)
>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>> [62]PETSC ERROR: No support for this operation for this object type
>>>>>> [62]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0, unknown[62]PETSC ERROR:
>>>>>> #1 MatCreateSubMatrix_MPIAIJ_SameRowDist() line 3418 in
>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line 3247 in
>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/interface/precon.c
>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/ksp/ksp/interface/itfunc.c
>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171102/0136a1ce/attachment-0001.html>
