[petsc-users] Question on incomplete factorization level and	fill
    Hong
    hzhang at mcs.anl.gov
    Wed May 24 14:21:05 CDT 2017
Danyang :
I tested your data.
Your matrices encountered zero pivots, e.g.
petsc/src/ksp/ksp/examples/tutorials (master)
$ mpiexec -n 24 ./ex10 -f0 a_react_in_2.bin -rhs b_react_in_2.bin
-ksp_monitor -ksp_error_if_not_converged
[15]PETSC ERROR: Zero pivot in LU factorization:
http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
[15]PETSC ERROR: Zero pivot row 1249 value 2.05808e-14 tolerance 2.22045e-14
Adding option '-sub_pc_factor_shift_type nonzero', I got
-ksp_monitor -ksp_error_if_not_converged -sub_pc_factor_shift_type nonzero
-mat_view ascii::ascii_info
Mat Object: 24 MPI processes
  type: mpiaij
  rows=450000, cols=450000
  total: nonzeros=6991400, allocated nonzeros=6991400
  total number of mallocs used during MatSetValues calls =0
    not using I-node (on process 0) routines
  0 KSP Residual norm 5.849777711755e+01
  1 KSP Residual norm 6.824179430230e-01
  2 KSP Residual norm 3.994483555787e-02
  3 KSP Residual norm 6.085841461433e-03
  4 KSP Residual norm 8.876162583511e-04
  5 KSP Residual norm 9.407780665278e-05
Number of iterations =   5
Residual norm 0.00542891
Hong
> Hi Matt,
> Yes. The matrix is 450000x450000 sparse. The hypre takes hundreds of
> iterates, not for all but in most of the timesteps. The matrix is not well
> conditioned, with nonzero entries range from 1.0e-29 to 1.0e2. I also made
> double check if there is anything wrong in the parallel version, however,
> the matrix is the same with sequential version except some round error
> which is relatively very small. Usually for those not well conditioned
> matrix, direct solver should be faster than iterative solver, right? But
> when I use the sequential iterative solver with ILU prec developed almost
> 20 years go by others, the solver converge fast with appropriate
> factorization level. In other words, when I use 24 processor using hypre,
> the speed is almost the same as as the old sequential iterative solver
> using 1 processor.
> I use most of the default configuration for the general case with pretty
> good speedup. And I am not sure if I miss something for this problem.
> Thanks,
> Danyang
> On 17-05-24 11:12 AM, Matthew Knepley wrote:
> On Wed, May 24, 2017 at 12:50 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi Matthew and Barry,
>> Thanks for the quick response.
>> I also tried superlu and mumps, both work but it is about four times
>> slower than ILU(dt) prec through hypre, with 24 processors I have tested.
> You mean the total time is 4x? And you are taking hundreds of iterates?
> That seems hard to believe, unless you are dropping
> a huge number of elements.
>> When I look into the convergence information, the method using ILU(dt)
>> still takes 200 to 3000 linear iterations for each newton iteration. One
>> reason is this equation is hard to solve. As for the general cases, the
>> same method works awesome and get very good speedup.
> I do not understand what you mean here.
>> I also doubt if I use hypre correctly for this case. Is there anyway to
>> check this problem, or is it possible to increase the factorization level
>> through hypre?
> I don't know.
>   Matt
>> Thanks,
>> Danyang
>> On 17-05-24 04:59 AM, Matthew Knepley wrote:
>> On Wed, May 24, 2017 at 2:21 AM, Danyang Su <danyang.su at gmail.com> wrote:
>>> Dear All,
>>> I use PCFactorSetLevels for ILU and PCFactorSetFill for other
>>> preconditioning in my code to help solve the problems that the default
>>> option is hard to solve. However, I found the latter one, PCFactorSetFill
>>> does not take effect for my problem. The matrices and rhs as well as the
>>> solutions are attached from the link below. I obtain the solution using
>>> hypre preconditioner and it takes 7 and 38 iterations for matrix 1 and
>>> matrix 2. However, if I use other preconditioner, the solver just failed at
>>> the first matrix. I have tested this matrix using the native sequential
>>> solver (not PETSc) with ILU preconditioning. If I set the incomplete
>>> factorization level to 0, this sequential solver will take more than 100
>>> iterations. If I increase the factorization level to 1 or more, it just
>>> takes several iterations. This remind me that the PC factor for this
>>> matrices should be increased. However, when I tried it in PETSc, it just
>>> does not work.
>>> Matrix and rhs can be obtained from the link below.
>>> https://eilinator.eos.ubc.ca:8443/index.php/s/CalUcq9CMeblk4R
>>> Would anyone help to check if you can make this work by increasing the
>>> PC factor level or fill?
>> We have ILU(k) supported in serial. However ILU(dt) which takes a
>> tolerance only works through Hypre
>>   http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>> I recommend you try SuperLU or MUMPS, which can both be downloaded
>> automatically by configure, and
>> do a full sparse LU.
>>   Thanks,
>>     Matt
>>> Thanks and regards,
>>> Danyang
>> experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170524/03c50857/attachment-0001.html>
