[petsc-users] Accessing submatrices without additional memory usage
Wed May 24 12:44:47 CDT 2017
On Wed, May 24, 2017 at 12:37 PM, Michał Dereziński <
michal.derezinski at gmail.com> wrote:
> Great! Then I have a follow-up question:
> My goal is to be able to load the full matrix X from disk, while at the
> same time in parallel, performing computations on the submatrices that have
> already been loaded. Essentially, I want to think of X as a block matrix
> (where the blocks are horizontal, spanning the full width of the matrix),
> where I’m loading one block at a time, and all the blocks that have already
> been loaded are combined using MatCreateNest, so that I can make
> computations on that portion of the matrix.
I need to understand better. So
  1) You want to load a sparse matrix from disk
  2) You are imagining that it is loaded row-wise, since you can do a
calculation with some rows before others are loaded.
       What calculation, a MatMult?
       How long does that MatMult take compared to loading?
  3) If you are talking about a dense matrix, you should be loading in
parallel using MPI-I/O. We do this for Vec.
Before you do complicated programming, I would assure myself that the
performance gain is worth it.
> In this scenario, every process needs to be simultaneously loading the
> next block of X, and perform computations on the previously loaded portion.
> My strategy is for each MPI process to spawn a thread for data loading (so
> that the memory between the process and the thread is shared), while the
> process does computations. My concern is that the data loading thread may
> be using up computational resources of the processor, even though it is
> mainly doing IO. Will this be an issue? What is the best way to minimize
> the cpu time of this parallel data loading scheme?
Oh, you want to load each block in parallel, but there are many blocks. I
would really caution you against using threads. They
are death to clean code. Use non-blocking reads.
     Matt
> Thanks,
> Michal.
> Wiadomość napisana przez Matthew Knepley <knepley at gmail.com> w dniu
> 24.05.2017, o godz. 04:55:
> On Wed, May 24, 2017 at 1:09 AM, Michal Derezinski <mderezin at ucsc.edu>
> wrote:
>> Hi,
>> I want to be able to perform matrix operations on several contiguous
>> submatrices of a full matrix, without allocating the memory redundantly for
>> the submatrices (in addition to the memory that is already allocated for
>> the full matrix).
>> I tried using MatGetSubMatrix, but this function appears to allocate the
>> additional memory.
>> The other way I found to do this is to create the smallest submatrices I
>> need first, then use MatCreateNest to combine them into bigger ones
>> (including the full matrix).
>> The documentation of MatCreateNest seems to indicate that it does not
>> allocate additional memory for storing the new matrix.
>> Is this the right approach, or is there a better one?
> Yes, that is the right approach.
>   Thanks,
>     Matt
>> Thanks,
>> Michal Derezinski.
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170524/7a2e865c/attachment.html>
