[petsc-users] [3.7.5] strange config error on macOS with XCode 8.3 and Clang 8.1.0
Denis Davydov
davydden at gmail.com
Tue Mar 28 15:12:45 CDT 2017
Dear all,
Yesterday I updated to the latest XCode and now have problems configuring PETSc (see below).
I must say that a number of other packages which need MPI fortran wrappers compiled fine.
Denis.
Executing: /Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/openmpi-2.1.0-rh7brts6lzesj46zopjj5rzmkcyiktx7/bin/mpif90 -c -o /var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/config.setCompilers/conftest.o -I/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/config.setCompilers -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Executing: /Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/openmpi-2.1.0-rh7brts6lzesj46zopjj5rzmkcyiktx7/bin/mpif90 -o /var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/config.setCompilers/conftest -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/config.setCompilers/conftest.o -lto_library -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib -lLTO -Wl,-rpath,/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/hwloc-1.11.6-pkbyijayr66g3wq3hojj3l44qc7kjno3/lib -L/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/hwloc-1.11.6-pkbyijayr66g3wq3hojj3l44qc7kjno3/lib -Wl,-rpath,/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/openmpi-2.1.0-rh7brts6lzesj46zopjj5rzmkcyiktx7/lib -L/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/openmpi-2.1.0-rh7brts6lzesj46zopjj5rzmkcyiktx7/lib -ldl -lmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin -lclang_rt.osx -ldl
Possible ERROR while running linker: exit code 256
stderr:
ld: can't map file, errno=22 file '/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib' for architecture x86_64
collect2: error: ld returned 1 exit status
Popping language FC
compilers: Error message from compiling {Cannot compile/link FC with /Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.1.0-apple/openmpi-2.1.0-rh7brts6lzesj46zopjj5rzmkcyiktx7/bin/mpif90.}
**** Configure header /var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/confdefs.h ****
#if !defined(INCLUDED_UNKNOWN)
#define INCLUDED_UNKNOWN
#ifndef PETSC_HAVE_DLFCN_H
#define PETSC_HAVE_DLFCN_H 1
#endif
#ifndef PETSC_HAVE_RTLD_NOW
#define PETSC_HAVE_RTLD_NOW 1
#endif
#ifndef PETSC_HAVE_RTLD_LOCAL
#define PETSC_HAVE_RTLD_LOCAL 1
#endif
#ifndef PETSC_HAVE_RTLD_LAZY
#define PETSC_HAVE_RTLD_LAZY 1
#endif
#ifndef PETSC_C_STATIC_INLINE
#define PETSC_C_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_RTLD_GLOBAL
#define PETSC_HAVE_RTLD_GLOBAL 1
#endif
#ifndef PETSC_C_RESTRICT
#define PETSC_C_RESTRICT restrict
#endif
#ifndef PETSC_HAVE_LIBDL
#define PETSC_HAVE_LIBDL 1
#endif
#ifndef PETSC_ARCH
#define PETSC_ARCH "arch-darwin-c-opt"
#endif
#ifndef PETSC_CLANGUAGE_C
#define PETSC_CLANGUAGE_C 1
#endif
#ifndef PETSC_HAVE_DYNAMIC_LIBRARIES
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#endif
#ifndef PETSC_HAVE_SHARED_LIBRARIES
#define PETSC_HAVE_SHARED_LIBRARIES 1
#endif
#ifndef PETSC_USE_SHARED_LIBRARIES
#define PETSC_USE_SHARED_LIBRARIES 1
#endif
#ifndef PETSC_USE_ERRORCHECKING
#define PETSC_USE_ERRORCHECKING 1
#endif
#endif
**** C specific Configure header /var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/petsc-eLXjKy/conffix.h ****
#if defined(__cplusplus)
extern "C" {
#else
#endif
#endif
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
C libraries cannot directly be used from Fortran
File "./config/configure.py", line 405, in petsc_configure
framework.configure(out = sys.stdout)
File "/Users/davydden/spack/var/spack/stage/petsc-3.7.5-tpsz2lfspkqa7tq2keqowsk4xrebsfwi/petsc-3.7.5/config/BuildSystem/config/framework.py", line 1090, in configure
self.processChildren()
File "/Users/davydden/spack/var/spack/stage/petsc-3.7.5-tpsz2lfspkqa7tq2keqowsk4xrebsfwi/petsc-3.7.5/config/BuildSystem/config/framework.py", line 1079, in processChildren
self.serialEvaluation(self.childGraph)
File "/Users/davydden/spack/var/spack/stage/petsc-3.7.5-tpsz2lfspkqa7tq2keqowsk4xrebsfwi/petsc-3.7.5/config/BuildSystem/config/framework.py", line 1060, in serialEvaluation
child.configure()
File "/Users/davydden/spack/var/spack/stage/petsc-3.7.5-tpsz2lfspkqa7tq2keqowsk4xrebsfwi/petsc-3.7.5/config/BuildSystem/config/compilers.py", line 1438, in configure
self.executeTest(self.checkCLibraries)
File "/Users/davydden/spack/var/spack/stage/petsc-3.7.5-tpsz2lfspkqa7tq2keqowsk4xrebsfwi/petsc-3.7.5/config/BuildSystem/config/base.py", line 126, in executeTest
ret = test(*args,**kargs)
File "/Users/davydden/spack/var/spack/stage/petsc-3.7.5-tpsz2lfspkqa7tq2keqowsk4xrebsfwi/petsc-3.7.5/config/BuildSystem/config/compilers.py", line 313, in checkCLibraries
raise RuntimeError('C libraries cannot directly be used from Fortran')
Finishing Configure Run at Tue Mar 28 21:56:48 2017
