[petsc-users] Is OpenMP still available for PETSc?
Danyang Su danyang.su at gmail.com
Fri Jun 30 17:40:58 CDT 2017
Dear All,
I recalled there was OpenMP available for PETSc for the old development
version. When google "petsc hybrid mpi openmp", there returned some
papers about this feature. My code was first parallelized using OpenMP
and then redeveloped using PETSc, with OpenMP kept but not used together
with MPI. Before retesting the code using hybrid mpi-openmp, I picked
one PETSc example ex10 by adding "omp_set_num_threads(max_threads);"
under PetscInitialize.
The PETSc is the current development version configured as follows
--with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-debugging=0
--CFLAGS=-fopenmp --CXXFLAGS=-fopenmp --FFLAGS=-fopenmp COPTFLAGS="-O3
-march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native
-mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native"
--with-large-file-io=1 --download-cmake=yes --download-mumps
--download-scalapack --download-parmetis --download-metis
--download-ptscotch --download-fblaslapack --download-mpich
--download-hypre --download-superlu_dist --download-hdf5=yes
--with-openmp --with-threadcomm --with-pthreadclasses --with-openmpclasses
The code can be successfully compiled. However, when I run the code with
OpenMP, it does not work, the time shows no change in performance if 1
or 2 threads per processor is used. Also, the CPU/Threads usage
indicates that no thread is used.
I just wonder if OpenMP is still available in the latest version, though
it is not recommended to use.
mpiexec -n 2 ./ex10 -f0 mat_rhs_pc_nonzero/a_react_in_2.bin -rhs
mat_rhs_pc_nonzero/b_react_in_2.bin -ksp_rtol 1.0e-20 -ksp_monitor
-ksp_error_if_not_converged -sub_pc_factor_shift_type nonzero -mat_view
ascii::ascii_info -log_view -max_threads 1 -threadcomm_type openmp
-threadcomm_nthreads 1
KSPSolve               1 1.0 8.9934e-01 1.0 1.03e+09 1.0 7.8e+01 3.6e+04
7.8e+01 69 97 89  6 76  89 97 98 98 96  2290
PCSetUp                2 1.0 8.9590e-02 1.0 2.91e+07 1.0 0.0e+00 0.0e+00
0.0e+00  7  3  0  0  0   9  3  0  0  0   648
PCSetUpOnBlocks        2 1.0 8.9465e-02 1.0 2.91e+07 1.0 0.0e+00 0.0e+00
0.0e+00  7  3  0  0  0   9  3  0  0  0   649
PCApply               40 1.0 3.1993e-01 1.0 2.70e+08 1.0 0.0e+00 0.0e+00
0.0e+00 24 25  0  0  0  32 25  0  0  0  1686
ascii::ascii_info -log_view -max_threads 2 -threadcomm_type openmp
-threadcomm_nthreads 2
KSPSolve               1 1.0 8.9701e-01 1.0 1.03e+09 1.0 7.8e+01 3.6e+04
7.8e+01 69 97 89  6 76  89 97 98 98 96  2296
PCSetUp                2 1.0 8.7635e-02 1.0 2.91e+07 1.0 0.0e+00 0.0e+00
0.0e+00  7  3  0  0  0   9  3  0  0  0   663
PCSetUpOnBlocks        2 1.0 8.7511e-02 1.0 2.91e+07 1.0 0.0e+00 0.0e+00
0.0e+00  7  3  0  0  0   9  3  0  0  0   664
PCApply               40 1.0 3.1878e-01 1.0 2.70e+08 1.0 0.0e+00 0.0e+00
0.0e+00 24 25  0  0  0  32 25  0  0  0  1692
Thanks and regards,
Danyang
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170630/99417911/attachment-0001.c>
CFLAGS	         =
FFLAGS	         =
CPPFLAGS         =
FPPFLAGS         =
LOCDIR           = src/ksp/ksp/examples/tutorials/
EXAMPLESC        = ex1.c ex2.c ex3.c ex4.c ex5.c ex6.c ex7.c ex8.c ex9.c \
                ex10.c ex11.c ex12.c ex13.c ex15.c ex16.c ex18.c ex23.c \
                ex25.c ex27.c ex28.c ex29.c ex30.c ex31.c ex32.c ex34.c \
                ex41.c ex42.c ex43.c \
                ex45.c ex46.c  ex49.c ex50.c ex51.c ex52.c ex53.c \
                ex54.c ex55.c ex56.c ex58.c ex62.c ex63.cxx ex64.c ex65.c
EXAMPLESF        = ex1f.F ex2f.F ex6f.F ex11f.F ex13f90.F ex14f.F ex15f.F ex21f.F ex22f.F ex44f.F90 ex45f.F \
                   ex52f.F ex54f.F ex61f.F90
MANSEC           = KSP
CLEANFILES       = rhs.vtk solution.vtk
NP               = 1
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
ex1: ex1.o  chkopts
	-${CLINKER} -o ex1 ex1.o  ${PETSC_KSP_LIB}
	${RM} ex1.o
ex1f: ex1f.o  chkopts
	-${FLINKER} -o ex1f ex1f.o  ${PETSC_KSP_LIB}
	${RM} ex1f.o
ex2: ex2.o  chkopts
	-${CLINKER} -o ex2 ex2.o  ${PETSC_KSP_LIB}
	${RM} ex2.o
ex2a: ex2a.o  chkopts
	-${CLINKER} -o ex2a ex2a.o  ${PETSC_KSP_LIB}
	${RM} ex2a.o
ex2f: ex2f.o  chkopts
	-${FLINKER} -o ex2f ex2f.o  ${PETSC_KSP_LIB}
	${RM} ex2f.o
ex3: ex3.o  chkopts
	-${CLINKER} -o ex3 ex3.o  ${PETSC_KSP_LIB}
	${RM} ex3.o
ex4: ex4.o  chkopts
	-${CLINKER} -o ex4 ex4.o  ${PETSC_KSP_LIB}
	${RM} ex4.o
ex5: ex5.o  chkopts
	-${CLINKER} -o ex5 ex5.o  ${PETSC_KSP_LIB}
	${RM} ex5.o
ex6: ex6.o  chkopts
	-${CLINKER} -o ex6 ex6.o  ${PETSC_KSP_LIB}
	${RM} ex6.o
ex6f: ex6f.o  chkopts
	-${FLINKER} -o ex6f ex6f.o  ${PETSC_KSP_LIB}
	${RM} ex6f.o
ex7: ex7.o  chkopts
	-${CLINKER} -o ex7 ex7.o  ${PETSC_KSP_LIB}
	${RM} ex7.o
ex8: ex8.o  chkopts
	-${CLINKER} -o ex8 ex8.o  ${PETSC_KSP_LIB}
	${RM} ex8.o
ex9: ex9.o  chkopts
	-${CLINKER} -o ex9 ex9.o  ${PETSC_KSP_LIB}
	${RM} ex9.o
ex10: ex10.o  chkopts
	-${CLINKER} -o ex10 ex10.o  ${PETSC_KSP_LIB}
	${RM} ex10.o
ex11: ex11.o  chkopts
	-${CLINKER} -o ex11 ex11.o  ${PETSC_KSP_LIB}
	${RM} ex11.o
ex11f: ex11f.o  chkopts
	-${FLINKER} -o ex11f ex11f.o  ${PETSC_KSP_LIB}
	${RM} ex11f.o
ex12: ex12.o  chkopts
	-${CLINKER} -o ex12 ex12.o  ${PETSC_KSP_LIB}
	${RM} ex12.o
ex13: ex13.o  chkopts
	-${CLINKER} -o ex13 ex13.o  ${PETSC_KSP_LIB}
	${RM} ex13.o
ex13f90: ex13f90.o  chkopts
	-${FLINKER} -o ex13f90 ex13f90.o  ${PETSC_KSP_LIB}
	${RM} ex13f90.o
ex14: ex14.o  chkopts
	-${CLINKER} -o ex14 ex14.o  ${PETSC_KSP_LIB}
	${RM} ex14.o
ex14f: ex14f.o  chkopts
	-${FLINKER} -o ex14f ex14f.o  ${PETSC_KSP_LIB}
	${RM} ex14f.o
ex15: ex15.o  chkopts
	-${CLINKER} -o ex15 ex15.o  ${PETSC_KSP_LIB}
	${RM} ex15.o
ex15f: ex15f.o  chkopts
	-${FLINKER} -o ex15f ex15f.o  ${PETSC_KSP_LIB}
	${RM} ex15f.o
ex16: ex16.o  chkopts
	-${CLINKER} -o ex16 ex16.o  ${PETSC_KSP_LIB}
	${RM} ex16.o
ex17: ex17.o  chkopts
	-${CLINKER} -o ex17 ex17.o  ${PETSC_KSP_LIB}
	${RM} ex17.o
ex18: ex18.o  chkopts
	-${CLINKER} -o ex18 ex18.o  ${PETSC_KSP_LIB}
	${RM} ex18.o
ex20: ex20.o  chkopts
	-${CLINKER} -o ex20 ex20.o  ${PETSC_KSP_LIB}
	${RM} ex20.o
ex21f: ex21f.o  chkopts
	-${FLINKER} -o ex21f ex21f.o  ${PETSC_KSP_LIB}
	${RM} ex21f.o
ex22: ex22.o  chkopts
	-${CLINKER} -o ex22 ex22.o  ${PETSC_SNES_LIB}
	${RM} ex22.o
ex22f: ex22f.o  chkopts
	-${FLINKER} -o ex22f ex22f.o  ${PETSC_SNES_LIB}
	${RM} ex22f.o
ex23: ex23.o  chkopts
	-${CLINKER} -o ex23 ex23.o  ${PETSC_KSP_LIB}
	${RM} ex23.o
ex25: ex25.o  chkopts
	-${CLINKER} -o ex25 ex25.o  ${PETSC_SNES_LIB}
	${RM} ex25.o
ex26: ex26.o  chkopts
	-${CLINKER} -o ex26 ex26.o  ${PETSC_KSP_LIB}
	${RM} ex26.o
ex27: ex27.o  chkopts
	-${CLINKER} -o ex27 ex27.o  ${PETSC_KSP_LIB}
	${RM} ex27.o
ex28: ex28.o  chkopts
	-${CLINKER} -o ex28 ex28.o  ${PETSC_SNES_LIB}
	${RM} ex28.o
ex29: ex29.o  chkopts
	-${CLINKER} -o ex29 ex29.o  ${PETSC_SNES_LIB}
	${RM} ex29.o
ex30: ex30.o  chkopts
	-${CLINKER} -o ex30 ex30.o  ${PETSC_KSP_LIB}
	${RM} ex30.o
ex31: ex31.o  chkopts
	-${CLINKER} -o ex31 ex31.o  ${PETSC_SNES_LIB}
	${RM} ex31.o
ex32: ex32.o  chkopts
	-${CLINKER} -o ex32 ex32.o  ${PETSC_SNES_LIB}
	${RM} ex32.o
ex33: ex33.o chkopts
	-${CLINKER} -o ex33 ex33.o ${PETSC_SNES_LIB}
	${RM} ex33.o
ex34: ex34.o chkopts
	-${CLINKER} -o ex34 ex34.o ${PETSC_SNES_LIB}
	${RM} ex34.o
ex35: ex35.o chkopts
	-${CLINKER} -o ex35 ex35.o ${PETSC_SNES_LIB}
	${RM} ex35.o
ex36: ex36.o chkopts
	-${CLINKER} -o ex36 ex36.o ${PETSC_SNES_LIB}
	${RM} ex36.o
ex37: ex37.o chkopts
	-${CLINKER} -o ex37 ex37.o ${PETSC_SNES_LIB}
	${RM} ex37.o
ex38: ex38.o chkopts
	-${CLINKER} -o ex38 ex38.o ${PETSC_SNES_LIB}
	${RM} ex38.o
ex39: ex39.o chkopts
	-${CLINKER} -o ex39 ex39.o ${PETSC_SNES_LIB}
	${RM} ex39.o
ex40: ex40.o chkopts
	-${CLINKER} -o ex40 ex40.o ${PETSC_SNES_LIB}
	${RM} ex40.o
ex41: ex41.o chkopts
	-${CLINKER} -o ex41 ex41.o ${PETSC_SNES_LIB}
	${RM} ex41.o
ex42: ex42.o chkopts
	-${CLINKER} -o ex42 ex42.o ${PETSC_KSP_LIB}
	${RM} ex42.o
ex43: ex43.o chkopts
	-${CLINKER} -o ex43 ex43.o ${PETSC_KSP_LIB}
	${RM} ex43.o
# not tested in nightly builds because requires F90 compiler that handles long lines
ex44f: ex44f.o  chkopts
	-${FLINKER} -o ex44f ex44f.o  ${PETSC_KSP_LIB}
	${RM} ex44f.o
ex45f: ex45f.o  chkopts
	-${FLINKER} -o ex45f ex45f.o  ${PETSC_KSP_LIB}
	${RM} ex45f.o
ex45: ex45.o chkopts
	-${CLINKER} -o ex45 ex45.o ${PETSC_KSP_LIB}
	${RM} ex45.o
ex46: ex46.o chkopts
	-${CLINKER} -o ex46 ex46.o ${PETSC_KSP_LIB}
	${RM} ex46.o
ex47: ex47.o chkopts
	-${CLINKER} -o ex47 ex47.o ${PETSC_KSP_LIB}
	${RM} ex47.o
ex49: ex49.o chkopts
	-${CLINKER} -o ex49 ex49.o ${PETSC_KSP_LIB}
	${RM} ex49.o
ex50: ex50.o chkopts
	-${CLINKER} -o ex50 ex50.o ${PETSC_KSP_LIB}
	${RM} ex50.o
ex51: ex51.o chkopts
	-${CLINKER} -o ex51 ex51.o ${PETSC_KSP_LIB}
	${RM} ex51.o
ex52: ex52.o chkopts
	-${CLINKER} -o ex52 ex52.o ${PETSC_KSP_LIB}
	${RM} ex52.o
ex52f: ex52f.o  chkopts
	-${FLINKER} -o ex52f ex52f.o  ${PETSC_KSP_LIB}
	${RM} ex52f.o
ex53: ex53.o chkopts
	-${CLINKER} -o ex53 ex53.o ${PETSC_KSP_LIB}
	${RM} ex53.o
ex54: ex54.o chkopts
	-${CLINKER} -o ex54 ex54.o ${PETSC_KSP_LIB}
	${RM} ex54.o
ex54f: ex54f.o  chkopts
	-${FLINKER} -o ex54f ex54f.o  ${PETSC_KSP_LIB}
	${RM} ex54f.o
ex55: ex55.o chkopts
	-${CLINKER} -o ex55 ex55.o ${PETSC_KSP_LIB}
	${RM} ex55.o
ex56: ex56.o chkopts
	-${CLINKER} -o ex56 ex56.o ${PETSC_KSP_LIB}
	${RM} ex56.o
ex57f: ex57f.o  chkopts
	-${FLINKER} -o ex57f ex57f.o  ${PETSC_KSP_LIB}
	${RM} ex57f.o
ex58: ex58.o chkopts
	-${CLINKER} -o ex58 ex58.o ${PETSC_KSP_LIB}
	${RM} ex58.o
ex59: ex59.o chkopts
	-${CLINKER} -o ex59 ex59.o ${PETSC_KSP_LIB}
	${RM} ex59.o
ex60: ex60.o  chkopts
	-${CLINKER} -o ex60 ex60.o  ${PETSC_KSP_LIB}
	${RM} ex60.o
ex61f: ex61f.o  chkopts
	-${FLINKER} -o ex61f ex61f.o  ${PETSC_KSP_LIB}
	${RM} ex61f.o
ex62: ex62.o  chkopts
	-${CLINKER} -o ex62 ex62.o  ${PETSC_KSP_LIB}
	${RM} ex62.o
ex63: ex63.o  chkopts
	-${CLINKER} -o ex63 ex63.o  ${PETSC_KSP_LIB}
	${RM} ex63.o
ex64: ex64.o  chkopts
	-${CLINKER} -o ex64 ex64.o  ${PETSC_KSP_LIB}
	${RM} ex64.
ex65: ex65.o  chkopts
	-${CLINKER} -o ex65 ex65.o  ${PETSC_KSP_LIB}
	${RM} ex65.o
runex1:
	-@${MPIEXEC} -n 1 ./ex1 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex1_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex1_1.out ex1_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex1_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex1_1.tmp
runex1_2:
	-@${MPIEXEC} -n 1 ./ex1 -pc_type sor -pc_sor_symmetric -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always >\
	   ex1_2.tmp 2>&1;   \
	   if (${DIFF} output/ex1_2.out ex1_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex1_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex1_2.tmp
runex1_3:
	-@${MPIEXEC} -n 1 ./ex1 -pc_type eisenstat -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always >\
	   ex1_3.tmp 2>&1;   \
	   if (${DIFF} output/ex1_3.out ex1_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex1_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex1_3.tmp
runex1f:
	-@${MPIEXEC} -n 1 ./ex1f -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex1f_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex1f_1.out ex1f_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex1f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex1f_1.tmp
runex2:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_monitor_short -m 5 -n 5 -ksp_gmres_cgs_refinement_type refine_always > ex2_1.tmp 2>&1; \
	   if (${DIFF} output/ex2_1.out ex2_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2_1.tmp
runex2_2:
	-@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 5 -n 5 -ksp_gmres_cgs_refinement_type refine_always > ex2_2.tmp 2>&1; \
	   if (${DIFF} output/ex2_2.out ex2_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2_2.tmp
runex2_3:
	-@${MPIEXEC} -n 1 ./ex2 -pc_type sor -pc_sor_symmetric -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > \
	    ex2_3.tmp 2>&1;   \
	   if (${DIFF} output/ex2_3.out ex2_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2_3.tmp
runex2_4:
	-@${MPIEXEC} -n 1 ./ex2 -pc_type eisenstat -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always >\
	    ex2_4.tmp 2>&1;   \
	   if (${DIFF} output/ex2_4.out ex2_4.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_4, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2_4.tmp
runex2_5:
	-@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 5 -n 5 -mat_view draw -ksp_gmres_cgs_refinement_type refine_always -nox  > ex2_5.tmp 2>&1; \
	   if (${DIFF} output/ex2_2.out ex2_5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_5, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2_5.tmp
runex2_bjacobi:
	-@${MPIEXEC} -n 4 ./ex2 -pc_type bjacobi -pc_bjacobi_blocks 1 -ksp_monitor_short -sub_pc_type jacobi -sub_ksp_type gmres > ex2.tmp 2>&1; \
	   if (${DIFF} output/ex2_bjacobi.out ex2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_bjacobi, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2.tmp
runex2_bjacobi_2:
	-@${MPIEXEC} -n 4 ./ex2 -pc_type bjacobi -pc_bjacobi_blocks 2 -ksp_monitor_short -sub_pc_type jacobi -sub_ksp_type gmres -ksp_view > ex2.tmp 2>&1; \
	   if (${DIFF} output/ex2_bjacobi_2.out ex2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_bjacobi_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2.tmp
runex2_bjacobi_3:
	-@${MPIEXEC} -n 4 ./ex2 -pc_type bjacobi -pc_bjacobi_blocks 4 -ksp_monitor_short -sub_pc_type jacobi -sub_ksp_type gmres > ex2.tmp 2>&1; \
	   if (${DIFF} output/ex2_bjacobi_3.out ex2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2_bjacobi_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2.tmp
runex2_chebyest_1:
	-@${MPIEXEC} -n 1 ./ex2 -m 80 -n 80 -ksp_pc_side right -pc_type ksp -ksp_ksp_type chebyshev -ksp_ksp_max_it 5 -ksp_ksp_chebyshev_esteig 0.9,0,0,1.1 -ksp_monitor_short > ex2.tmp 2>&1; \
           ${DIFF} output/ex2_chebyest_1.out ex2.tmp || printf "${PWD}\nPossible problem with ex2_chebyest_1, diffs above\n=========================================\n"; \
           ${RM} -f ex2.tmp
runex2_chebyest_2:
	-@${MPIEXEC} -n 1 ./ex2 -m 80 -n 80 -ksp_pc_side right -pc_type ksp -ksp_ksp_type chebyshev -ksp_ksp_max_it 5 -ksp_ksp_chebyshev_esteig 0.9,0,0,1.1 -ksp_esteig_ksp_type cg -ksp_monitor_short > ex2.tmp 2>&1; \
           ${DIFF} output/ex2_chebyest_2.out ex2.tmp || printf "${PWD}\nPossible problem with ex2_chebyest_2, diffs above\n=========================================\n"; \
           ${RM} -f ex2.tmp
runex2_umfpack:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package umfpack > ex2_umfpack.tmp 2>&1; \
           if (${DIFF} output/ex2_umfpack.out ex2_umfpack.tmp) then true; \
           else printf "${PWD}\nPossible problem with ex2_umfpack, diffs above\n=========================================\n"; fi; \
           ${RM} -f ex2_umfpack.tmp
runex2_mkl_pardiso_lu:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mkl_pardiso > ex2_mkl_pardiso.tmp 2>&1; \
           if (${DIFF} output/ex2_mkl_pardiso_lu.out ex2_mkl_pardiso.tmp) then true; \
           else printf "${PWD}\nPossible problem with ex2_mkl_pardiso_lu, diffs above\n=========================================\n"; fi; \
           ${RM} -f ex2_mkl_pardiso.tmp
runex2_mkl_pardiso_cholesky:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package mkl_pardiso > ex2_mkl_pardiso.tmp 2>&1; \
           if (${DIFF} output/ex2_mkl_pardiso_cholesky.out ex2_mkl_pardiso.tmp) then true; \
           else printf "${PWD}\nPossible problem with ex2_mkl_pardiso_cholesky, diffs above\n=========================================\n"; fi; \
runex2_fbcgs:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type fbcgs -pc_type ilu  > ex2.tmp 2>&1; \
           if (${DIFF} output/ex2_fbcgs.out ex2.tmp) then true; \
           else printf "${PWD}\nPossible problem with ex2_fbcgs, diffs above\n=========================================\n"; fi; \
           ${RM} -f ex2.tmp
runex2_fbcgs_2:
	-@${MPIEXEC} -n 3 ./ex2 -ksp_type fbcgsr -pc_type bjacobi > ex2.tmp 2>&1; \
           if (${DIFF} output/ex2_fbcgs_2.out ex2.tmp) then true; \
           else printf "${PWD}\nPossible problem with ex2_fbcgs_2, diffs above\n=========================================\n"; fi; \
           ${RM} -f ex2.tmp
runex2_telescope:
	-@${MPIEXEC} -n 4 ./ex2 -m 100 -n 100 -ksp_converged_reason -pc_type telescope -pc_telescope_reduction_factor 4 -telescope_pc_type bjacobi > ex2.tmp 2>&1; \
           if (${DIFF} output/ex2_telescope.out ex2.tmp) then true; \
           else printf "${PWD}\nPossible problem with ex2_telescope, diffs above\n=========================================\n"; fi; \
           ${RM} -f ex2.tmp
runex2_pipecg:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_monitor_short -ksp_type pipecg -m 9 -n 9 > ex2_pipecg.tmp 2>&1; \
	   ${DIFF} output/ex2_pipecg.out ex2_pipecg.tmp || printf "${PWD}\nPossible problem with ex2_pipecg, diffs above\n=========================================\n"; \
	   ${RM} -f ex2_pipecg.tmp
runex2_pipecr:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_monitor_short -ksp_type pipecr -m 9 -n 9 > ex2_pipecr.tmp 2>&1; \
	   ${DIFF} output/ex2_pipecr.out ex2_pipecr.tmp || printf "${PWD}\nPossible problem with ex2_pipecr, diffs above\n=========================================\n"; \
	   ${RM} -f ex2_pipecr.tmp
runex2_groppcg:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_monitor_short -ksp_type groppcg -m 9 -n 9 > ex2_groppcg.tmp 2>&1; \
	   ${DIFF} output/ex2_groppcg.out ex2_groppcg.tmp || printf "${PWD}\nPossible problem with ex2_groppcg, diffs above\n=========================================\n"; \
	   ${RM} -f ex2_groppcg.tmp
runex2_pipecgrr:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_monitor_short -ksp_type pipecgrr -m 9 -n 9 > ex2_pipecgrr.tmp 2>&1; \
	   ${DIFF} output/ex2_pipecgrr.out ex2_pipecgrr.tmp || printf "${PWD}\nPossible problem with ex2_pipecgrr, diffs above\n=========================================\n"; \
	   ${RM} -f ex2_pipecgrr.tmp
runex2f:
	-@${MPIEXEC} -n 2 ./ex2f -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex2f_1.tmp 2>&1; \
	   if (${DIFF} output/ex2f_1.out ex2f_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2f_1.tmp
runex2f_2:
	-@${MPIEXEC} -n 2 ./ex2f -pc_type jacobi -my_ksp_monitor -ksp_gmres_cgs_refinement_type refine_always > ex2f_2.tmp 2>&1; \
	   if (${DIFF} output/ex2f_2.out ex2f_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex2f_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex2f_2.tmp
runex5:
	-@${MPIEXEC} -n 1 ./ex5 -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex5_1.tmp 2>&1; \
	   if (${DIFF} output/ex5_1.out ex5_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5_1.tmp
runex5_2:
	-@${MPIEXEC} -n 2 ./ex5 -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always \
	   -ksp_rtol .000001 > ex5_2.tmp 2>&1;   \
	   if (${DIFF} output/ex5_2.out ex5_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5_2.tmp
runex5_5:
	-@${MPIEXEC} -n 2 ./ex5 -ksp_gmres_cgs_refinement_type refine_always > ex5_5.tmp 2>&1; \
	   if (${DIFF} output/ex5_5.out ex5_5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_5, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5_5.tmp
runex5_redundant_0:
	-@${MPIEXEC} -n 1 ./ex5 -m 1000 -pc_type redundant -pc_redundant_number 1 -redundant_ksp_type gmres -redundant_pc_type jacobi  > ex5.tmp 2>&1;   \
	   if (${DIFF} output/ex5_redundant_0.out ex5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_redundant, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5.tmp
runex5_redundant_1:
	-@${MPIEXEC} -n 5 ./ex5 -pc_type redundant -pc_redundant_number 1 -redundant_ksp_type gmres -redundant_pc_type jacobi  > ex5.tmp 2>&1;   \
	   if (${DIFF} output/ex5_redundant_1.out ex5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_redundant_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5.tmp
runex5_redundant_2:
	-@${MPIEXEC} -n 5 ./ex5 -pc_type redundant -pc_redundant_number 3 -redundant_ksp_type gmres -redundant_pc_type jacobi > ex5.tmp 2>&1;   \
	   if (${DIFF} output/ex5_redundant_2.out ex5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_redundant_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5.tmp
runex5_redundant_3:
	-@${MPIEXEC} -n 5 ./ex5 -pc_type redundant -pc_redundant_number 5 -redundant_ksp_type gmres -redundant_pc_type jacobi  > ex5.tmp 2>&1;   \
	   if (${DIFF} output/ex5_redundant_3.out ex5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_redundant_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5.tmp
runex5_redundant_4:
	-@${MPIEXEC} -n 5 ./ex5 -pc_type redundant -pc_redundant_number 3 -redundant_ksp_type gmres -redundant_pc_type jacobi -psubcomm_type interlaced > ex5.tmp 2>&1;   \
	   if (${DIFF} output/ex5_redundant_4.out ex5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex5_redundant_4, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex5.tmp
runex6:
	-@${MPIEXEC} -n 1 ./ex6 -ksp_view  > ex6_0.tmp 2>&1; \
	   if (${DIFF} output/ex6_0.out ex6_0.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex6_0, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex6_0.tmp
runex6_1:
	-@${MPIEXEC} -n 4 ./ex6 -ksp_view > ex6_1.tmp 2>&1; \
	   if (${DIFF} output/ex6_1.out ex6_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex6_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex6_1.tmp
runex6_2:
	-@${MPIEXEC} -n 4 ./ex6 -user_subdomains -ksp_view ${ARGS} > ex6_2.tmp 2>&1; \
	   if (${DIFF} output/ex6_2.out ex6_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex6_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex6_2.tmp
runex6f:
	-@${MPIEXEC} -n 1 ./ex6f -pc_type jacobi -mat_view -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex6f_1.tmp 2>&1; \
	   if (${DIFF} output/ex6f_1.out ex6f_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex6f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex6f_1.tmp
runex7:
	-@${MPIEXEC} -n 2 ./ex7 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always> ex7_1.tmp 2>&1; \
	   if (${DIFF} output/ex7_1.out ex7_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex7_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_1.tmp
runex7_2:
	-@${MPIEXEC} -n 2 ./ex7 -ksp_view > ex7_2.tmp 2>&1; \
	   if (${DIFF} output/ex7_2.out ex7_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex7_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_2.tmp
runex7_mpiaijcusp:
	-@${MPIEXEC} -n 1 ./ex7 -ksp_monitor_short  -mat_type mpiaijcusp -sub_pc_factor_mat_solver_package cusparse -vec_type mpicusp > ex7_mpiaijcusp.tmp 2>&1; \
	   if (${DIFF} output/ex7_mpiaijcusp.out ex7_mpiaijcusp.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex7_mpiaijcusp, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_mpiaijcusp.tmp
runex7_mpiaijcusp_2:
	-@${MPIEXEC} -n 2 ./ex7 -ksp_monitor_short  -mat_type mpiaijcusp -sub_pc_factor_mat_solver_package cusparse -vec_type mpicusp > ex7_mpiaijcusp_2.tmp 2>&1; \
	   if (${DIFF} output/ex7_mpiaijcusp_2.out ex7_mpiaijcusp_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex7_mpiaijcusp_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_mpiaijcusp_2.tmp
runex7_mpiaijcusp_simple:
	-@${MPIEXEC} -n 1 ./ex7 -ksp_monitor_short  -mat_type mpiaijcusp -sub_pc_factor_mat_solver_package cusparse -vec_type mpicusp -sub_ksp_type preonly -sub_pc_type ilu > ex7_mpiaijcusp_simple.tmp 2>&1; \
	   if (${DIFF} output/ex7_mpiaijcusp_simple.out ex7_mpiaijcusp_simple.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex7_mpiaijcusp_simple, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_mpiaijcusp_simple.tmp
runex7_mpiaijcusp_simple_2:
	-@${MPIEXEC} -n 2 ./ex7 -ksp_monitor_short  -mat_type mpiaijcusp -sub_pc_factor_mat_solver_package cusparse -vec_type mpicusp -sub_ksp_type preonly -sub_pc_type ilu > ex7_mpiaijcusp_simple_2.tmp 2>&1; \
	   if (${DIFF} output/ex7_mpiaijcusp_simple_2.out ex7_mpiaijcusp_simple_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex7_mpiaijcusp_simple_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_mpiaijcusp_simple_2.tmp
runex7_mpiaijcusparse:
	-@${MPIEXEC} -n 1 ./ex7 -ksp_monitor_short -mat_type mpiaijcusparse -sub_pc_factor_mat_solver_package cusparse  -vec_type mpicuda > ex7_mpiaijcusparse.tmp 2>&1; \
	   if (${DIFF} output/ex7_mpiaijcusparse.out ex7_mpiaijcusparse.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex7_mpiaijcusparse, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_mpiaijcusparse.tmp
runex7_mpiaijcusparse_2:
	-@${MPIEXEC} -n 2 ./ex7 -ksp_monitor_short -mat_type mpiaijcusparse -sub_pc_factor_mat_solver_package cusparse  -vec_type mpicuda > ex7_mpiaijcusparse_2.tmp 2>&1; \
	   if (${DIFF} output/ex7_mpiaijcusparse_2.out ex7_mpiaijcusparse_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex7_mpiaijcusparse_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex7_mpiaijcusparse_2.tmp
NP = 1
M  = 4
N  = 5
MDOMAINS = 2
NDOMAINS = 1
OVERLAP=1
runex8:
	-@${MPIEXEC} -n ${NP} ./ex8 -m $M -n $N -user_set_subdomains -Mdomains ${MDOMAINS} -Ndomains ${NDOMAINS} -overlap ${OVERLAP} -print_error ${ARGS}
runex8_1:
	-@${MPIEXEC} -n 1 ./ex8 -print_error > ex8_1.tmp 2>&1; \
	   if (${DIFF} output/ex8_1.out ex8_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex8_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex8_1.tmp
runex9:
	-@${MPIEXEC} -n 1 ./ex9 -t 2 -pc_type jacobi -ksp_monitor_short -ksp_type gmres -ksp_gmres_cgs_refinement_type refine_always \
	   -s2_ksp_type bcgs -s2_pc_type jacobi -s2_ksp_monitor_short \
           > ex9_1.tmp 2>&1; \
	   if (${DIFF} output/ex9_1.out ex9_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex9_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex9_1.tmp
runex10:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${PETSC_DIR}/share/petsc/datafiles/matrices/spd-real-int${PETSC_INDEX_SIZE}-float${PETSC_SCALAR_SIZE} > ex10_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_1.out ex10_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_1.tmp
# See http://www.mcs.anl.gov/petsc/documentation/faq.html#datafiles for how to obtain the datafiles used below
runex10_2:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_type bicg \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_2.out ex10_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_2.tmp
runex10_3:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_type bicg -pc_type asm \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_3.tmp 2>&1; \
	   if (${DIFF} output/ex10_3.out ex10_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_3.tmp
runex10_4:
	-@${MPIEXEC} -n 1 ./ex10 -ksp_type bicg -pc_type lu \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_4.tmp 2>&1; \
	   if (${DIFF} output/ex10_4.out ex10_4.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_4, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_4.tmp
runex10_5:
	-@${MPIEXEC} -n 1 ./ex10 -ksp_type bicg \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_5.tmp 2>&1; \
	   if (${DIFF} output/ex10_5.out ex10_5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_5, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_5.tmp
runex10_6:
	-@${MPIEXEC} -n 1 ./ex10 -pc_factor_levels 2 -pc_factor_fill 1.73 -ksp_gmres_cgs_refinement_type refine_always \
	   -f0 ${DATAFILESPATH}/matrices/fem1 > ex10_6.tmp 2>&1; \
	   if (${DIFF} output/ex10_6.out ex10_6.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_6, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_6.tmp
BS = 2 3 4 5 6 7 8
runex10_7:
	- at touch ex10_7.tmp
	- at for bs in ${BS}; do \
	 ${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -viewer_binary_skip_info \
                    -mat_type seqbaij -matload_block_size $$bs -ksp_max_it 100 -ksp_gmres_cgs_refinement_type refine_always -ksp_rtol \
                    1.0e-15 -ksp_monitor_short >> ex10_7.tmp 2>&1 ; \
                    1.0e-15 -ksp_monitor_short -pc_factor_mat_ordering_type nd >> ex10_7.tmp 2>&1 ; \
                    1.0e-15 -ksp_monitor_short -pc_factor_levels 1 >> ex10_7.tmp 2>&1 ; \
                    -mat_type seqbaij -matload_block_size $$bs -ksp_type preonly \
                    -pc_type lu  >> ex10_7.tmp 2>&1 ; \
         done;
	- at if (${DIFF} output/ex10_7.out ex10_7.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_7, diffs above\n=========================================\n"; fi;
	-@${RM} -f ex10_7.tmp
runex10_8:
	-@${MPIEXEC} -n 1 ./ex10 -ksp_diagonal_scale -pc_type eisenstat -ksp_monitor_short -ksp_diagonal_scale_fix \
	   -f0 ${DATAFILESPATH}/matrices/medium -ksp_gmres_cgs_refinement_type refine_always  -mat_no_inode > ex10_8.tmp 2>&1; \
	   if (${DIFF} output/ex10_8.out ex10_8.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_8, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_8.tmp
runex10_9:
	- at touch ex10_9.tmp
	- at for type in gmres; do \
          for bs in 1 2 3 4 5 6 7; do \
                    1.0e-15 -ksp_monitor_short >> ex10_9.tmp 2>&1 ; \
	 ${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_gmres_cgs_refinement_type refine_always -viewer_binary_skip_info \
                    -mat_type seqbaij -matload_block_size $$bs -ksp_max_it 100 -ksp_rtol \
                    1.0e-15 -ksp_monitor_short -trans >> ex10_9.tmp 2>&1 ; \
          for np in 2 3; do \
	 ${MPIEXEC} -n $$np ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -viewer_binary_skip_info \
                    -mat_type mpibaij -matload_block_size $$bs -ksp_max_it 100 -ksp_gmres_cgs_refinement_type refine_always -ksp_rtol \
	 ${MPIEXEC} -n $$np ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_gmres_cgs_refinement_type refine_always -viewer_binary_skip_info \
                    -mat_type mpibaij -matload_block_size $$bs -ksp_max_it 100 -ksp_rtol \
         done; done; done;
	- at if (${DIFF} output/ex10_9.out ex10_9.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_9, diffs above\n=========================================\n"; fi;
	-@${RM} -f ex10_9.tmp
runex10_10:
	-@${MPIEXEC} -n 2 ./ex10  -ksp_type fgmres -pc_type ksp \
	   -f0 ${DATAFILESPATH}/matrices/medium -ksp_fgmres_modifypcksp -ksp_monitor_short> ex10_10.tmp 2>&1; \
	   if (${DIFF} output/ex10_10.out ex10_10.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_10, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_10.tmp
runex10_11:
	-@${MPIEXEC} -n 2 ./ex10 -f0 http://ftp.mcs.anl.gov/pub/petsc/matrices/testmatrix.gz > ex10_11.tmp 2>&1;\
	   if (${DIFF} output/ex10_11.out ex10_11.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_11, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_11.tmp
runex10_12:
	-@${MPIEXEC} -n 1 ./ex10 -pc_type lu -pc_factor_mat_solver_package matlab -f0 ${DATAFILESPATH}/matrices/arco1 > ex10_12.tmp 2>&1;\
	   if (${DIFF} output/ex10_12.out ex10_12.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_12, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_12.tmp
runex10_13:
	-@${MPIEXEC} -n 1 ./ex10 -mat_type lusol -pc_type lu -f0 ${DATAFILESPATH}/matrices/arco1 > ex10_13.tmp 2>&1;\
	   if (${DIFF} output/ex10_13.out ex10_13.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_13, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_13.tmp
runex10_14:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type spai -f0 ${DATAFILESPATH}/matrices/medium > ex10_14.tmp 2>&1; \
	  ${DIFF} output/ex10_14.out ex10_14.tmp || printf "${PWD}\nPossible problem with ex10_14, diffs above\n=========================================\n"; \
	  ${RM} -f ex10_14.tmp
runex10_15:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type pilut -f0 ${DATAFILESPATH}/matrices/medium > ex10_15.tmp 2>&1;\
	   if (${DIFF} output/ex10_15.out ex10_15.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_15, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_15.tmp
runex10_16:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type parasails -f0 ${DATAFILESPATH}/matrices/medium > ex10_16.tmp 2>&1;\
	   if (${DIFF} output/ex10_16.out ex10_16.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_16, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_16.tmp
runex10_17:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type boomeramg -f0 ${DATAFILESPATH}/matrices/medium > ex10_17.tmp 2>&1;\
	   if (${DIFF} output/ex10_17.out ex10_17.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_17, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_17.tmp
runex10_boomeramg_schwarz:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_monitor_short -ksp_rtol 1.E-9 -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_smooth_type Schwarz-smoothers -f0 ${DATAFILESPATH}/matrices/poisson2.gz > ex10_boomeramg_schwarz.tmp 2>&1;\
	   if (${DIFF} output/ex10_boomeramg_schwarz.out ex10_boomeramg_schwarz.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_boomeramg_schwarz, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_boomeramg_schwarz.tmp
runex10_boomeramg_pilut:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_monitor_short -ksp_rtol 1.E-9 -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_smooth_type Pilut -pc_hypre_boomeramg_smooth_num_levels 2 -f0 ${DATAFILESPATH}/matrices/poisson2.gz > ex10_boomeramg_pilut.tmp 2>&1;\
	   if (${DIFF} output/ex10_boomeramg_pilut.out ex10_boomeramg_pilut.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_boomeramg_pilut, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_boomeramg_pilut.tmp
runex10_boomeramg_parasails:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_monitor_short -ksp_rtol 1.E-9 -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_smooth_type ParaSails -pc_hypre_boomeramg_smooth_num_levels 2 -f0 ${DATAFILESPATH}/matrices/poisson2.gz > ex10_boomeramg_parasails.tmp 2>&1;\
	   if (${DIFF} output/ex10_boomeramg_parasails.out ex10_boomeramg_parasails.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_boomeramg_parasails, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_boomeramg_parasails.tmp
# Euclid has a bug in its handling of MPI communicators resulting in some memory not being freed at conclusion of the run
runex10_boomeramg_euclid:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_monitor_short -ksp_rtol 1.E-9 -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_smooth_type Euclid -pc_hypre_boomeramg_smooth_num_levels 2 -pc_hypre_boomeramg_eu_level 1 -pc_hypre_boomeramg_eu_droptolerance 0.01  -f0 ${DATAFILESPATH}/matrices/poisson2.gz > ex10_boomeramg_euclid.tmp 2>&1;\
	   if (${DIFF} output/ex10_boomeramg_euclid.out ex10_boomeramg_euclid.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_boomeramg_euclid, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_boomeramg_euclid.tmp
runex10_boomeramg_euclid_bj:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_monitor_short -ksp_rtol 1.E-9 -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_smooth_type Euclid -pc_hypre_boomeramg_smooth_num_levels 2 -pc_hypre_boomeramg_eu_level 1 -pc_hypre_boomeramg_eu_droptolerance 0.01 -pc_hypre_boomeramg_eu_bj -f0 ${DATAFILESPATH}/matrices/poisson2.gz > ex10_boomeramg_euclid_bj.tmp 2>&1;\
	   if (${DIFF} output/ex10_boomeramg_euclid_bj.out ex10_boomeramg_euclid_bj.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_boomeramg_euclid_bj, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_boomeramg_euclid_bj.tmp
LEVELS = 0 2 4
runex10_19:
	- at touch ex10_19aij.tmp
	- at touch ex10_19sbaij.tmp
	- at for levels in ${LEVELS}; do \
	${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/poisson1 -ksp_type cg -pc_type icc -pc_factor_levels $$levels >> ex10_19aij.tmp 2>&1; \
	 ${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/poisson1 -ksp_type cg -pc_type icc -pc_factor_levels $$levels -mat_type seqsbaij >> ex10_19sbaij.tmp 2>&1; \
	done;
	- at if (${DIFF} ex10_19aij.tmp ex10_19sbaij.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_19, diffs above\n=========================================\n"; fi; \
	${RM} -f ex10_19aij.tmp ex10_19sbaij.tmp
runex10_superlu_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu -num_numfac 2 -num_rhs 2 > ex10_superlu_lu_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_superlu_lu_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_superlu_lu_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_superlu_lu_1.tmp
runex10_superlu_dist_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist -num_numfac 2 -num_rhs 2 > ex10_superlu_lu_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_superlu_lu_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_superlu_lu_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_superlu_lu_2.tmp
runex10_superlu_dist_lu_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist -num_numfac 2 -num_rhs 2 > ex10_superlu_lu_2.tmp 2>&1; \
runex10_umfpack:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqaij -pc_factor_mat_solver_package umfpack -num_numfac 2 -num_rhs 2 > ex10_umfpack.tmp 2>&1; \
	   if (${DIFF} output/ex10_umfpack.out ex10_umfpack.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_umfpack, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_umfpack.tmp
runex10_mumps_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_lu_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_lu_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_lu_1.tmp
runex10_mumps_lu_metis:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type aij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -mat_mumps_icntl_7 5 > ex10_mumps_lu_1.tmp 2>&1; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_lu_metis, diffs above\n=========================================\n"; fi; \
runex10_mumps_lu_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type mpiaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_lu_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_lu_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_lu_2.tmp
runex10_mumps_lu_parmetis:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type mpiaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2 > ex10_mumps_lu_2.tmp 2>&1; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_lu_parmetis, diffs above\n=========================================\n"; fi; \
runex10_mumps_lu_3:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqbaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -matload_block_size 2 > ex10_mumps_lu_3.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_lu_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_lu_3.tmp
runex10_mumps_lu_4:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type mpibaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -matload_block_size 2 > ex10_mumps_lu_4.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_4.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_lu_4, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_lu_4.tmp
runex10_mumps_cholesky_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -mat_ignore_lower_triangular > ex10_mumps_cholesky_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_cholesky_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_cholesky_1.tmp
runex10_mumps_cholesky_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -mat_ignore_lower_triangular > ex10_mumps_cholesky_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_cholesky_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_cholesky_2.tmp
runex10_mumps_cholesky_3:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_3.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_cholesky_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_cholesky_3.tmp
runex10_mumps_cholesky_4:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_4.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_4.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_cholesky_4, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_cholesky_4.tmp
runex10_mumps_cholesky_spd_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -matload_spd -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_spd_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_spd_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_cholesky_spd_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_cholesky_spd_1.tmp
runex10_mumps_cholesky_spd_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -matload_spd -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_spd_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_spd_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_cholesky_spd_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mumps_cholesky_spd_2.tmp
NSUBCOMM = 8 7 6 5 4 3 2 1
runex10_mumps_redundant:
	- at touch ex10_mumps_redundant.tmp
	- at for nsubcomm in ${NSUBCOMM}; do \
	${MPIEXEC} -n 8 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_type preonly -pc_type redundant -pc_redundant_number $$nsubcomm -redundant_pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 >> ex10_mumps_redundant.tmp 2>&1; \
	done;
	- at if (${DIFF} output/ex10_mumps_redundant.out ex10_mumps_redundant.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mumps_redundant, diffs above\n=========================================\n"; fi; \
	${RM} -f ex10_mumps_redundant.tmp;
runex10_pastix_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqaij -pc_factor_mat_solver_package pastix -num_numfac 2 -num_rhs 2 > ex10_pastix_lu_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_pastix_lu_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_pastix_lu_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_pastix_lu_1.tmp
runex10_pastix_lu_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type mpiaij -pc_factor_mat_solver_package pastix -num_numfac 2 -num_rhs 2 > ex10_pastix_lu_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_pastix_lu_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_pastix_lu_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_pastix_lu_2.tmp
runex10_pastix_cholesky_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package pastix -num_numfac 2 -num_rhs 2 -mat_ignore_lower_triangular > ex10_pastix_cholesky_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_pastix_cholesky_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_pastix_cholesky_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_pastix_cholesky_1.tmp
runex10_pastix_cholesky_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package pastix -num_numfac 2 -num_rhs 2 -mat_ignore_lower_triangular > ex10_pastix_cholesky_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_pastix_cholesky_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_pastix_cholesky_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_pastix_cholesky_2.tmp
runex10_pastix_redundant:
	- at touch ex10_pastix_redundant.tmp
	${MPIEXEC} -n 8 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_type preonly -pc_type redundant -pc_redundant_number $$nsubcomm -redundant_pc_factor_mat_solver_package pastix -num_numfac 2 -num_rhs 2 >> ex10_pastix_redundant.tmp 2>&1; \
	done;
	- at if (${DIFF} output/ex10_mumps_redundant.out ex10_pastix_redundant.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_pastix_redundant, diffs above\n=========================================\n"; fi; \
	${RM} -f ex10_pastix_redundant.tmp;
runex10_superlu_dist_redundant:
	- at touch ex10_superlu_dist_redundant.tmp
	${MPIEXEC} -n 8 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_type preonly -pc_type redundant -pc_redundant_number $$nsubcomm -redundant_pc_factor_mat_solver_package superlu_dist -num_numfac 2 -num_rhs 2 >> ex10_superlu_dist_redundant.tmp 2>&1; \
	done;
	- at if (${DIFF} output/ex10_mumps_redundant.out ex10_superlu_dist_redundant.tmp) then true; \
	  else printf "${PWD}\nPossible problem with ex10_superlu_dist_redundant, diffs above\n=========================================\n"; fi; \
	${RM} -f ex10_superlu_dist_redundant.tmp;
runex10_ILU: # test ilu fill greater than zero
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -pc_factor_levels 1  > ex10_20.tmp 2>&1; \
	   if (${DIFF} output/ex10_ILU.out ex10_20.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_ILU, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_20.tmp
runex10_ILUBAIJ: # test ilu fill greater than zero
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -pc_factor_levels 1 -mat_type baij > ex10_20.tmp 2>&1; \
runex10_cg:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -mat_type mpisbaij -ksp_type cg -pc_type eisenstat -ksp_monitor_short -ksp_converged_reason > ex10_20.tmp 2>&1; \
	   if (${DIFF} output/ex10_cg_singlereduction.out ex10_20.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_cg, diffs above\n=========================================\n"; fi; \
runex10_cg_singlereduction:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -mat_type mpisbaij -ksp_type cg -pc_type eisenstat -ksp_monitor_short -ksp_converged_reason -ksp_cg_single_reduction > ex10_20.tmp 2>&1; \
	   else printf "${PWD}\nPossible problem with ex10_cg_singlereduction, diffs above\n=========================================\n"; fi; \
runex10_seqaijcrl:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type seqaijcrl > ex10_seqaijcrl.tmp 2>&1; \
	   if (${DIFF} output/ex10_seqcrl.out ex10_seqaijcrl.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_seqaijcrl, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_seqaijcrl.tmp
runex10_mpiaijcrl:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view  -mat_type mpiaijcrl > ex10_mpiaijcrl.tmp 2>&1; \
	   if (${DIFF} output/ex10_mpiaij.out ex10_mpiaijcrl.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mpiaijcrl, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mpiaijcrl.tmp
runex10_seqaijperm:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type seqaijperm > ex10_seqaijperm.tmp 2>&1; \
	   if (${DIFF} output/ex10_seqcsrperm.out ex10_seqaijperm.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_seqaijperm, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_seqaijperm.tmp
runex10_mpiaijperm:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view  -mat_type mpiaijperm > ex10_mpiaijperm.tmp 2>&1; \
	   if (${DIFF} output/ex10_mpicsrperm.out ex10_mpiaijperm.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_mpiaijperm, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_mpiaijperm.tmp
runex10_aijcusparse:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type aijcusparse -pc_factor_mat_solver_package cusparse -pc_type ilu > ex10_aijcusparse.tmp 2>&1; \
	   if (${DIFF} output/ex10_aijcusparse.out ex10_aijcusparse.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_aijcusparse, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10_aijcusparse.tmp
runex10_zeropivot:
	-@${MPIEXEC} -n 3 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -test_zeropivot -ksp_converged_reason -ksp_type fgmres -pc_type ksp -ksp_pc_type bjacobi > ex10.tmp 2>&1; \
	   if (${DIFF} output/ex10_zeropivot.out ex10.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_zeropivot, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10.tmp
runex10_zeropivot_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -test_zeropivot -ksp_converged_reason -ksp_type fgmres -pc_type ksp -ksp_ksp_type cg -ksp_pc_type bjacobi -ksp_pc_bjacobi_blocks 1 > ex10.tmp 2>&1; \
	   else printf "${PWD}\nPossible problem with ex10_zeropivot_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10.tmp
runex10_zeropivot_3:
	-@${MPIEXEC} -n 3 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -test_zeropivot -ksp_converged_reason -ksp_type fgmres -pc_type ksp -ksp_ksp_converged_reason -ksp_pc_type bjacobi -ksp_sub_ksp_converged_reason > ex10.tmp 2>&1; \
	   if (${DIFF} output/ex10_zeropivot_3.out ex10.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex10_zeropivot_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex10.tmp
runex11:
	-@${MPIEXEC} -n 1 ./ex11 -n 6 -norandom -pc_type none -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex11_1.tmp 2>&1; \
	   if (${DIFF} output/ex11_1.out ex11_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex11_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex11_1.tmp
runex11f:
	-@${MPIEXEC} -n 1 ./ex11f -n 6 -norandom -pc_type none -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex11f_1.tmp 2>&1; \
	   if (${DIFF} output/ex11f_1.out ex11f_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex11f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex11f_1.tmp
runex12:
	-@${MPIEXEC} -n 1 ./ex12 -ksp_gmres_cgs_refinement_type refine_always > ex12_1.tmp 2>&1; \
	   if (${DIFF} output/ex12_1.out ex12_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex12_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex12_1.tmp
runex13:
	-@${MPIEXEC} -n 1 ./ex13 -m 19 -n 20 -ksp_gmres_cgs_refinement_type refine_always > ex13_1.tmp 2>&1; \
	   if (${DIFF} output/ex13_1.out ex13_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex13_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex13_1.tmp
runex13f90:
	-@${MPIEXEC} -n 1 ./ex13f90 -m 19 -n 20 -ksp_gmres_cgs_refinement_type refine_always > ex13f90_1.tmp 2>&1; \
	   if (${DIFF} output/ex13f90_1.out ex13f90_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex13f90_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex13f90_1.tmp
runex14f:
	-@${MPIEXEC} -n 1 ./ex14f -no_output -ksp_gmres_cgs_refinement_type refine_always > ex14_1.tmp 2>&1; \
	   if (${DIFF} output/ex14_1.out ex14_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex14f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex14_1.tmp
runex15:
	-@${MPIEXEC} -n 2 ./ex15 -ksp_view -user_defined_pc -ksp_gmres_cgs_refinement_type refine_always > ex15_1.tmp 2>&1; \
	   if (${DIFF} output/ex15_1.out ex15_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex15_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex15_1.tmp
runex15f:
	-@${MPIEXEC} -n 2 ./ex15f -ksp_view -user_defined_pc -ksp_gmres_cgs_refinement_type refine_always > ex15f_1.tmp 2>&1; \
	   if (${DIFF} output/ex15f_1.out ex15f_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex15f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex15f_1.tmp
runex16:
	-@${MPIEXEC} -n 2 ./ex16 -ntimes 4 -ksp_gmres_cgs_refinement_type refine_always > ex16_1.tmp 2>&1; \
	   if (${DIFF} output/ex16_1.out ex16_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex16_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex16_1.tmp
runex18:
	-@${MPIEXEC} -n 3 ./ex18 -m 39 -n 18 -ksp_monitor_short -permute nd > ex18_1.tmp 2>&1; \
	   ${DIFF} output/ex18_1.out ex18_1.tmp || printf "${PWD}\nPossible problem with ex18_1, diffs above\n=========================================\n"; \
	   ${RM} -f ex18_1.tmp
runex18_2:
	-@${MPIEXEC} -n 3 ./ex18 -m 39 -n 18 -ksp_monitor_short -permute rcm > ex18_2.tmp 2>&1; \
	   ${DIFF} output/ex18_2.out ex18_2.tmp || printf "${PWD}\nPossible problem with ex18_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex18_2.tmp
runex18_3:
	-@${MPIEXEC} -n 3 ./ex18 -m 13 -n 17 -ksp_monitor_short -ksp_type cg -ksp_cg_single_reduction > ex18_3.tmp 2>&1; \
	   ${DIFF} output/ex18_3.out ex18_3.tmp || printf "${PWD}\nPossible problem with ex18_3, diffs above\n=========================================\n"; \
	   ${RM} -f ex18_3.tmp
runex21f:
	-@${MPIEXEC} -n 1 ./ex21f  > ex21f_1.tmp 2>&1; \
	   if (${DIFF} output/ex21f_1.out ex21f_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex21f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex21f_1.tmp
runex22f:
	-@${MPIEXEC} -n 1 ./ex22f -pc_mg_type full -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type preconditioned -pc_type mg -da_refine 2 -ksp_type fgmres > ex22_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex22_1.out ex22_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex22f_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex22_1.tmp
runex23:
	-@${MPIEXEC} -n 1 ./ex23 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex23_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex23_1.out ex23_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex23_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex23_1.tmp
runex23_2:
	-@${MPIEXEC} -n 3 ./ex23 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex23_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex23_2.out ex23_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex23_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex23_2.tmp
runex23_3 :
	-@${MPIEXEC} -n 2 ./ex23 -ksp_monitor_short -ksp_rtol 1e-6 -ksp_type pipefgmres > ex23_3.tmp 2>&1;	  \
	   if (${DIFF} output/ex23_3.out ex23_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex23_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex23_3.tmp
runex25:
	-@${MPIEXEC} -n 1 ./ex25 -pc_type mg -ksp_type fgmres -da_refine 2 -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type unpreconditioned -ksp_view -pc_mg_type full  > ex25_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex25_1.out ex25_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex25_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex25_1.tmp
runex25_2:
	-@${MPIEXEC} -n 2 ./ex25 -pc_type mg -ksp_type fgmres -da_refine 2 -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type unpreconditioned -ksp_view -pc_mg_type full > ex25_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex25_2.out ex25_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex25_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex25_2.tmp
runex27:
	-@${MPIEXEC} -n 1 ./ex27 -f ${DATAFILESPATH}/matrices/medium  -ksp_view  -ksp_monitor_short -ksp_max_it 100  > ex27_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex27_1.out ex27_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex27_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex27_1.tmp
runex28:
	-@${MPIEXEC} -n 1 ./ex28 -ksp_monitor_short -pc_type mg -pc_mg_type full -ksp_type fgmres -da_refine 2 -mg_levels_ksp_type gmres -mg_levels_ksp_max_it 1 -mg_levels_pc_type ilu > ex28_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex28_1.out ex28_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex28_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex28_1.tmp
runex29:
	-@${MPIEXEC} -n 1 ./ex29 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 8 > ex29_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex29_1.out ex29_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex29_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex29_1.tmp
runex29_2:
	-@${MPIEXEC} -n 1 ./ex29  -bc_type neumann -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 8 -mg_coarse_pc_factor_shift_type nonzero > ex29_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex29_2.out ex29_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex29_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex29_2.tmp
runex29_telescope:
	-@${MPIEXEC} -n 4 ./ex29 -ksp_monitor_short -da_grid_x 257 -da_grid_y 257 -pc_type mg -pc_mg_galerkin -pc_mg_levels 4 -ksp_type richardson -mg_levels_ksp_type chebyshev -mg_levels_pc_type jacobi -mg_coarse_pc_type telescope -mg_coarse_pc_telescope_ignore_kspcomputeoperators -mg_coarse_telescope_pc_type mg -mg_coarse_telescope_pc_mg_galerkin -mg_coarse_telescope_pc_mg_levels 3 -mg_coarse_telescope_mg_levels_ksp_type chebyshev -mg_coarse_telescope_mg_levels_pc_type jacobi -mg_coarse_pc_telescope_reduction_factor 4 > ex29_telescope.tmp 2>&1;	  \
	   if (${DIFF} output/ex29_telescope.out ex29_telescope.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex29_telescope, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex29_telescope.tmp
runex30:
	-@${MPIEXEC} -n 1 ./ex30 > ex30_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex30_1.out ex30_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex30_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex30_1.tmp
runex32:
	-@${MPIEXEC} -n 1 ./ex32 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -pc_mg_levels 3 -mg_coarse_pc_factor_shift_type nonzero > ex32_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex32_1.out ex32_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex32_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex32_1.tmp
runex34:
	-@${MPIEXEC} -n 1 ./ex34  -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -pc_mg_levels 3 -mg_coarse_pc_factor_shift_type nonzero -ksp_view > ex34_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex34_1.out ex34_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex34_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex34_1.tmp
runex34_2 :
	-@${MPIEXEC} -n 2 ./ex34 -ksp_monitor_short -da_grid_x 50 -da_grid_y 50 -pc_type ksp -ksp_ksp_type cg -ksp_pc_type bjacobi -ksp_ksp_rtol 1e-1 -ksp_ksp_monitor -ksp_type pipefgmres -ksp_gmres_restart 5 > ex34_2.tmp 2>&1; \
	   if (${DIFF} output/ex34_2.out ex34_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex34_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex34_2.tmp
runex35:
	-@${MPIEXEC} -n 1 ./ex35 -bc_type dirichlet -nu .01 -n 10 -ksp_type cg -pc_type sor -ksp_converged_reason > ex35_1.tmp 2>&1;\
	   if (${DIFF} output/ex35_1.out ex35_1.tmp) then true ;  \
	   else echo ${PWD} ; echo "Possible problem with runex35, diffs above \n========================================="; fi ;\
	   ${RM} -f ex35_1.tmp
runex35_2:
	-@${MPIEXEC} -n 2 ./ex35 -bc_type dirichlet -nu .01 -n 20 -ksp_type cg -pc_type sor -ksp_converged_reason > ex35_2.tmp 2>&1;\
	   if (${DIFF} output/ex35_2.out ex35_2.tmp) then true ;  \
	   else echo ${PWD} ; echo "Possible problem with runex35_2, diffs above \n========================================="; fi ;\
	   ${RM} -f ex35_2.tmp
runex43:
	-@${MPIEXEC} -n 1 ./ex43 -stokes_ksp_type fgmres -stokes_pc_type fieldsplit -stokes_pc_fieldsplit_block_size 3 -stokes_pc_fieldsplit_type SYMMETRIC_MULTIPLICATIVE -stokes_pc_fieldsplit_0_fields 0,1 -stokes_pc_fieldsplit_1_fields 2 -stokes_fieldsplit_0_ksp_type preonly -stokes_fieldsplit_0_pc_type lu -stokes_fieldsplit_1_ksp_type preonly -stokes_fieldsplit_1_pc_type jacobi -c_str 0 -solcx_eta0 1.0 -solcx_eta1 1.0e6 -solcx_xc 0.5 -solcx_nz 2 -mx 20 -my 20 -stokes_ksp_monitor_short > ex43_1.tmp 2>&1;	  \
	   ${DIFF} output/ex43_1.out ex43_1.tmp || printf "${PWD}\nPossible problem with ex43_1, diffs above\n=========================================\n"; \
	   ${RM} -f ex43_1.tmp
runex43_2:
	-@${MPIEXEC} -n 1 ./ex43 -stokes_ksp_type fgmres -stokes_pc_type fieldsplit -stokes_pc_fieldsplit_block_size 3 -stokes_pc_fieldsplit_type SYMMETRIC_MULTIPLICATIVE -stokes_fieldsplit_u_ksp_type preonly -stokes_fieldsplit_u_pc_type lu -stokes_fieldsplit_p_ksp_type preonly -stokes_fieldsplit_p_pc_type jacobi -c_str 0 -solcx_eta0 1.0 -solcx_eta1 1.0e6 -solcx_xc 0.5 -solcx_nz 2 -mx 20 -my 20 -stokes_ksp_monitor_short > ex43_2.tmp 2>&1;	  \
	   ${DIFF} output/ex43_1.out ex43_2.tmp || printf "${PWD}\nPossible problem with ex43_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex43_2.tmp
runex43_3:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_type gcr -stokes_ksp_gcr_restart 60 -stokes_ksp_norm_type unpreconditioned -stokes_ksp_rtol 1.e-2 -c_str 3 -sinker_eta0 1.0 -sinker_eta1 100 -sinker_dx 0.4 -sinker_dy 0.3 -mx 128 -my 128 -stokes_ksp_monitor_short -stokes_pc_type mg -stokes_mg_levels_pc_type fieldsplit -stokes_pc_mg_galerkin -stokes_mg_levels_pc_fieldsplit_block_size 3 -stokes_mg_levels_pc_fieldsplit_0_fields 0,1 -stokes_mg_levels_pc_fieldsplit_1_fields 2 -stokes_mg_levels_fieldsplit_0_pc_type sor -stokes_mg_levels_fieldsplit_1_pc_type sor -stokes_mg_levels_ksp_type chebyshev -stokes_mg_levels_ksp_max_it 1 -stokes_mg_levels_ksp_chebyshev_esteig 0,0.2,0,1.1 -stokes_pc_mg_levels 4 -stokes_ksp_view > ex43_3.tmp 2>&1;	  \
	   ${DIFF} output/ex43_3.out ex43_3.tmp || printf "${PWD}\nPossible problem with ex43_3, diffs above\n=========================================\n"; \
	   ${RM} -f ex43_3.tmp
runex43_bjacobi:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_rtol 1.e-4 -stokes_pc_type bjacobi -stokes_pc_bjacobi_blocks 2 -mat_type aij -stokes_ksp_converged_reason > ex43.tmp 2>&1;	  \
	   ${DIFF} output/ex43_bjacobi.out ex43.tmp || printf "${PWD}\nPossible problem with ex43_bjacobi, diffs above\n=========================================\n"; \
	   ${RM} -f ex43.tmp
runex43_bjacobi_baij:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_rtol 1.e-4 -stokes_pc_type bjacobi -stokes_pc_bjacobi_blocks 2 -mat_type baij -stokes_ksp_converged_reason > ex43.tmp 2>&1;	  \
	   ${DIFF} output/ex43_bjacobi.out ex43.tmp || printf "${PWD}\nPossible problem with ex43_bjacobi_baij, diffs above\n=========================================\n"; \
	   ${RM} -f ex43.tmp
runex43_nested_gmg:
	-@${MPIEXEC} -n 4 ./ex43 -mx 16 -my 16 -stokes_ksp_type fgmres  -stokes_pc_type fieldsplit -stokes_fieldsplit_u_pc_type mg -stokes_fieldsplit_u_pc_mg_levels 5 -stokes_fieldsplit_u_pc_mg_galerkin -stokes_fieldsplit_u_ksp_type cg -stokes_fieldsplit_u_ksp_rtol 1.0e-4 -stokes_fieldsplit_u_mg_levels_pc_type jacobi -solcx_eta0 1.0e4 -stokes_fieldsplit_u_ksp_converged_reason -stokes_ksp_converged_reason -stokes_fieldsplit_p_sub_pc_factor_zeropivot 1.e-8 > ex43.tmp 2>&1;	  \
	   ${DIFF} output/ex43_nested_gmg.out ex43.tmp || printf "${PWD}\nPossible problem with ex43_nested_gmg, diffs above\n=========================================\n"; \
	   ${RM} -f ex43.tmp
runex43_4:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_type pipegcr -stokes_ksp_pipegcr_mmax 60 -stokes_ksp_pipegcr_unroll_w 1 -stokes_ksp_norm_type natural -c_str 3 -sinker_eta0 1.0 -sinker_eta1 100 -sinker_dx 0.4 -sinker_dy 0.3 -mx 128 -my 128 -stokes_ksp_monitor_short -stokes_pc_type mg -stokes_mg_levels_pc_type fieldsplit -stokes_pc_mg_galerkin -stokes_mg_levels_pc_fieldsplit_block_size 3 -stokes_mg_levels_pc_fieldsplit_0_fields 0,1 -stokes_mg_levels_pc_fieldsplit_1_fields 2 -stokes_mg_levels_fieldsplit_0_pc_type sor -stokes_mg_levels_fieldsplit_1_pc_type sor -stokes_mg_levels_ksp_type chebyshev -stokes_mg_levels_ksp_max_it 1 -stokes_mg_levels_ksp_chebyshev_esteig 0,0.2,0,1.1 -stokes_pc_mg_levels 4 -stokes_ksp_view > ex43_4.tmp 2>&1;	  \
	   ${DIFF} output/ex43_4.out ex43_4.tmp || printf "${PWD}\nPossible problem with ex43_4, diffs above\n=========================================\n"; \
	   ${RM} -f ex43_4.tmp
runex43_5:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_type pipegcr -stokes_pc_type fieldsplit -stokes_pc_fieldsplit_block_size 3 -stokes_pc_fieldsplit_type SYMMETRIC_MULTIPLICATIVE -stokes_pc_fieldsplit_0_fields 0,1 -stokes_pc_fieldsplit_1_fields 2 -stokes_fieldsplit_0_ksp_type preonly -stokes_fieldsplit_0_pc_type bjacobi -stokes_fieldsplit_1_ksp_type preonly -stokes_fieldsplit_1_pc_type bjacobi -c_str 0 -solcx_eta0 1.0 -solcx_eta1 1.0e6 -solcx_xc 0.5 -solcx_nz 2 -mx 20 -my 20 -stokes_ksp_monitor_short -stokes_ksp_view > ex43_5.tmp 2>&1;	  \
	   ${DIFF} output/ex43_5.out ex43_5.tmp || printf "${PWD}\nPossible problem with ex43_5, diffs above\n=========================================\n"; \
	   ${RM} -f ex43_5.tmp
runex45:
	-@${MPIEXEC} -n 4 ./ex45 -pc_type exotic -ksp_monitor_short -ksp_type fgmres -mg_levels_ksp_type gmres -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi > ex45_1.tmp 2>&1;	  \
	   ${DIFF} output/ex45_1.out ex45_1.tmp || printf "${PWD}\nPossible problem with ex45_1, diffs above\n=========================================\n"; \
	   ${RM} -f ex45_1.tmp
runex45_2:
	-@${MPIEXEC} -n 4 ./ex45 -ksp_monitor_short -da_grid_x 21 -da_grid_y 21 -da_grid_z 21 -pc_type mg -pc_mg_levels 3 -mg_levels_ksp_type richardson -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi > ex45_2.tmp 2>&1; \
	   ${DIFF} output/ex45_2.out ex45_2.tmp || printf "${PWD}\nPossible problem with ex45_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex45_2.tmp
runex45_telescope:
	-@${MPIEXEC} -n 4 ./ex45 -ksp_type fgmres -ksp_monitor_short -pc_type mg -mg_levels_ksp_type richardson -mg_levels_pc_type jacobi  -pc_mg_levels 2 -da_grid_x 65 -da_grid_y 65 -da_grid_z 65 -mg_coarse_pc_type telescope -mg_coarse_pc_telescope_ignore_kspcomputeoperators -mg_coarse_pc_telescope_reduction_factor 4 -mg_coarse_telescope_pc_type mg -mg_coarse_telescope_pc_mg_galerkin -mg_coarse_telescope_pc_mg_levels 3 -mg_coarse_telescope_mg_levels_ksp_type richardson -mg_coarse_telescope_mg_levels_pc_type jacobi   -mg_levels_ksp_type richardson -mg_coarse_telescope_mg_levels_ksp_type richardson -ksp_rtol 1.0e-4  > ex45_telescope.tmp 2>&1; \
	   ${DIFF} output/ex45_telescope.out ex45_telescope.tmp || printf "${PWD}\nPossible problem with ex45_telescope, diffs above\n=========================================\n"; \
	   ${RM} -f ex45_telescope.tmp
runex45_telescope_2:
	-@${MPIEXEC} -n 4 ./ex45 -ksp_type fgmres -ksp_monitor_short -pc_type mg -mg_levels_ksp_type richardson -mg_levels_pc_type jacobi  -pc_mg_levels 2 -da_grid_x 65 -da_grid_y 65 -da_grid_z 65 -mg_coarse_pc_type telescope -mg_coarse_pc_telescope_reduction_factor 2 -mg_coarse_telescope_pc_type mg -mg_coarse_telescope_pc_mg_galerkin -mg_coarse_telescope_pc_mg_levels 3 -mg_coarse_telescope_mg_levels_ksp_type richardson -mg_coarse_telescope_mg_levels_pc_type jacobi   -mg_levels_ksp_type richardson -mg_coarse_telescope_mg_levels_ksp_type richardson -ksp_rtol 1.0e-4  > ex45_telescope_2.tmp 2>&1; \
	   ${DIFF} output/ex45_telescope_2.out ex45_telescope_2.tmp || printf "${PWD}\nPossible problem with ex45_telescope_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex45_telescope_2.tmp
runex45f:
	-@${MPIEXEC} -n 4 ./ex45f -ksp_monitor_short -da_refine 5 -pc_type mg -pc_mg_levels 5 -mg_levels_ksp_type chebyshev -mg_levels_ksp_max_it 2 -mg_levels_pc_type jacobi -ksp_pc_side right > ex45f_1.tmp 2>&1; \
	   ${DIFF} output/ex45f_1.out ex45f_1.tmp || printf "${PWD}\nPossible problem with ex45f_1, diffs above\n=========================================\n"; \
	   ${RM} -f ex45f_1.tmp
runex46_aijcusp:
	-@${MPIEXEC} -n 1 ./ex46 -mat_type aijcusp -dm_vec_type cusp -random_exact_sol > ex46_aijcusp.tmp 2>& 1; \
		${DIFF} output/ex46_aijcusp.out ex46_aijcusp.tmp || printf "${PWD}\nPossible problem with ex46_aijcusp, diffs above\n=========================================\n"; \
		${RM} ex46_aijcusp.tmp
runex46_aijcusparse:
	-@${MPIEXEC} -n 1 ./ex46 -mat_type aijcusparse -dm_vec_type cuda -random_exact_sol > ex46_aijcusparse.tmp 2>& 1; \
		${DIFF} output/ex46_aijcusparse.out ex46_aijcusparse.tmp || printf "${PWD}\nPossible problem with ex46_aijcusparse, diffs above\n=========================================\n"; \
		${RM} ex46_aijcusparse.tmp
runex49:
	-@${MPIEXEC} -n 1 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 -elas_ksp_rtol 5e-3 -elas_ksp_view  > ex49_1.tmp 2>&1;	  \
	   ${DIFF} output/ex49_1.out ex49_1.tmp || printf "${PWD}\nPossible problem with ex49_1, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_1.tmp
runex49_2:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 -elas_ksp_type gcr -elas_pc_type asm -elas_sub_pc_type lu -elas_ksp_rtol 5e-3 > ex49_2.tmp 2>&1;	  \
	   ${DIFF} output/ex49_2.out ex49_2.tmp || printf "${PWD}\nPossible problem with ex49_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_2.tmp
runex49_3:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 2 -brick_E 1,10,1000,100 -brick_nu 0.4,0.2,0.3,0.1 -brick_span 3 -elas_pc_type asm -elas_sub_pc_type lu -elas_ksp_rtol 5e-3  > ex49_3.tmp 2>&1; \
	   ${DIFF} output/ex49_3.out ex49_3.tmp || printf "${PWD}\nPossible problem with ex49_3, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_3.tmp
runex49_4:
	-@${MPIEXEC} -n 4 ./ex49 -elas_ksp_monitor_short -elas_ksp_converged_reason -elas_ksp_type cg -elas_ksp_norm_type unpreconditioned -mx 40 -my 40 -c_str 2 -brick_E 1,1e-6,1e-2 -brick_nu .3,.2,.4 -brick_span 8 -elas_mg_levels_ksp_type chebyshev -elas_pc_type ml -elas_mg_levels_ksp_chebyshev_esteig 0,0.2,0,1.1 -elas_mg_levels_pc_type pbjacobi -elas_mg_levels_ksp_max_it 2 -use_nonsymbc -elas_pc_ml_nullspace user > ex49_4.tmp 2>&1; \
	   ${DIFF} output/ex49_4.out ex49_4.tmp || printf "${PWD}\nPossible problem with ex49_4, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_4.tmp
runex49_5:
	-@${MPIEXEC} -n 3 ./ex49 -elas_ksp_monitor_short -elas_ksp_converged_reason -elas_ksp_type cg -elas_ksp_norm_type natural -mx 22 -my 22 -c_str 2 -brick_E 1,1e-6,1e-2 -brick_nu .3,.2,.4 -brick_span 8 -elas_pc_type gamg -elas_mg_levels_ksp_type chebyshev -elas_mg_levels_ksp_max_it 1 -elas_mg_levels_ksp_chebyshev_esteig 0.2,1.1 -elas_mg_levels_pc_type jacobi -elas_pc_gamg_random_no_imaginary_part -elas_pc_gamg_random_no_imaginary_part > ex49_5.tmp 2>&1; \
	   ${DIFF} output/ex49_5.out ex49_5.tmp || printf "${PWD}\nPossible problem with ex49_5, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_5.tmp
# hyper has some valgrind serious bus in it for vec_interp_variant hence this crashes on some systems, waiting for hypre team to fix
runex49_hypre_nullspace:
	-@${MPIEXEC} -n 1 ./ex49 -elas_ksp_monitor_short -elas_ksp_converged_reason -elas_ksp_type cg -elas_ksp_norm_type natural -mx 22 -my 22 -c_str 2 -brick_E 1,1e-6,1e-2 -brick_nu .3,.2,.4 -brick_span 8 -elas_pc_type hypre  -elas_pc_hypre_boomeramg_nodal_coarsen  6 -elas_pc_hypre_boomeramg_vec_interp_variant 3 -elas_ksp_view > ex49_hypre_nullspace.tmp 2>&1; \
	   ${DIFF} output/ex49_hypre_nullspace.out ex49_hypre_nullspace.tmp || printf "${PWD}\nPossible problem with ex49_hypre_nullspace, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_hypre_nullspace.tmp
runex49_6:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 -elas_ksp_type pipegcr -elas_pc_type asm -elas_sub_pc_type lu > ex49_6.tmp 2>&1;	  \
	   ${DIFF} output/ex49_6.out ex49_6.tmp || printf "${PWD}\nPossible problem with ex49_6, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_6.tmp
runex49_7:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 -elas_ksp_type pipegcr -elas_pc_type asm -elas_sub_pc_type ksp -elas_sub_ksp_ksp_type cg -elas_sub_ksp_ksp_max_it 15 > ex49_7.tmp 2>&1;	  \
	   ${DIFF} output/ex49_7.out ex49_7.tmp || printf "${PWD}\nPossible problem with ex49_7, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_7.tmp
runex49_8:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 -elas_ksp_type pipefgmres -elas_pc_type asm -elas_sub_pc_type ksp -elas_sub_ksp_ksp_type cg -elas_sub_ksp_ksp_max_it 15 > ex49_8.tmp 2>&1;	  \
	   ${DIFF} output/ex49_8.out ex49_8.tmp || printf "${PWD}\nPossible problem with ex49_8, diffs above\n=========================================\n"; \
	   ${RM} -f ex49_8.tmp
runex50:
	-@${MPIEXEC} -n 1 ./ex50 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 1 -mg_levels_pc_factor_shift_type nonzero -mg_coarse_pc_factor_shift_type nonzero -ksp_view  > ex50.tmp 2>&1;         \
        ${DIFF} output/ex50.out ex50.tmp || printf "${PWD}\nPossible problem with ex50, diffs above\n=========================================\n"; \
        ${RM} -f ex50.tmp
runex50_2:
	-@${MPIEXEC} -n 2 ./ex50 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 1 -mg_levels_sub_pc_factor_shift_type nonzero -mg_coarse_pc_type redundant -mg_coarse_redundant_pc_type svd -ksp_view > ex50_2.tmp 2>&1;         \
        ${DIFF} output/ex50_2.out ex50_2.tmp || printf "${PWD}\nPossible problem with ex50_2, diffs above\n=========================================\n"; \
        ${RM} -f ex50_2.tmp
runex50_3 :
	-@${MPIEXEC} -n 2 ./ex50 -pc_type mg -pc_mg_type full -ksp_monitor_short -da_refine 5 -mg_coarse_ksp_type cg -mg_coarse_ksp_converged_reason -mg_coarse_ksp_rtol 1e-2 -mg_coarse_ksp_max_it 5 -mg_coarse_pc_type none -pc_mg_levels 2 -ksp_type pipefgmres -ksp_pipefgmres_shift 1.5 > ex50_3.tmp 2>&1;	  \
	   ${DIFF} output/ex50_3.out ex50_3.tmp || printf "${PWD}\nPossible problem with ex50_3, diffs above\n=========================================\n"; \
	   ${RM} -f ex50_3.tmp
runex51:
	-@${MPIEXEC} -n 2 ./ex51 -ksp_monitor_short > ex51.tmp 2>&1;	  \
	   ${DIFF} output/ex51_1.out ex51.tmp || printf "${PWD}\nPossible problem with ex51, diffs above\n=========================================\n"; \
	   ${RM} -f ex51.tmp
runex52:
	-@${MPIEXEC} -n 1 ./ex52 -use_petsc_lu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_2.out ex52.tmp || printf "${PWD}\nPossible problem with ex52, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52_mumps:
	-@${MPIEXEC} -n 3 ./ex52 -use_mumps_lu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_1.out ex52.tmp || printf "${PWD}\nPossible problem with ex52_mumps, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52_mumps_2:
	-@${MPIEXEC} -n 3 ./ex52 -use_mumps_ch > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_1.out ex52.tmp || printf "${PWD}\nPossible problem with ex52_mumps_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52_mumps_3:
	-@${MPIEXEC} -n 3 ./ex52 -use_mumps_ch -mat_type sbaij > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_1.out ex52.tmp || printf "${PWD}\nPossible problem with ex52_mumps_3, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52_superlu_ilu:
	-@${MPIEXEC} -n 1 ./ex52 -use_superlu_ilu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_2.out ex52.tmp || printf "${PWD}\nPossible problem with ex52_superlu_ilu, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52_superlu:
	-@${MPIEXEC} -n 1 ./ex52 -use_superlu_lu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_2.out ex52.tmp || printf "${PWD}\nPossible problem with ex52_superlu, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52_superlu_dist:
	-@${MPIEXEC} -n 2 ./ex52 -use_superlu_lu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_2.out ex52.tmp || printf "${PWD}\nPossible problem with ex52_superlu_dist, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex52f_mumps:
	-@${MPIEXEC} -n 3 ./ex52f > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52f_1.out ex52.tmp || printf "${PWD}\nPossible problem with ex52f_mumps, diffs above\n=========================================\n"; \
	   ${RM} -f ex52.tmp
runex53:
	-@${MPIEXEC} -n 1 ./ex53 > ex53.tmp 2>&1;         \
        ${DIFF} output/ex53.out ex53.tmp || printf "${PWD}\nPossible problem with ex53, diffs above\n=========================================\n"; \
        ${RM} -f ex53.tmp
runex53_2:
	-@${MPIEXEC} -n 2 ./ex53 > ex53.tmp 2>&1;	  \
	   ${DIFF} output/ex53.out ex53.tmp || printf "${PWD}\nPossible problem with ex53_2, diffs above\n=========================================\n"; \
	   ${RM} -f ex53.tmp
runex54_geo:
	-@${MPIEXEC} -n 4 ./ex54 -ne 49 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type geo -pc_gamg_coarse_eq_limit 200 -mg_levels_pc_type jacobi -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -ksp_monitor_short -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1;	  \
         ${DIFF} output/ex54_0.out ex.tmp || printf "${PWD}\nPossible problem with ex54_0.out, diffs above\n=========================================\n"; \
        ${RM} -f ex.tmp
runex54:
	-@${MPIEXEC} -n 4 ./ex54 -ne 49 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -ksp_converged_reason -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1; \
         ${DIFF} output/ex54_1.out ex.tmp || printf "${PWD}\nPossible problem with ex54_1.out, diffs above\n======================================\n"; \
        ${RM} -f ex.tmp
runex54_Classical:
	-@${MPIEXEC} -n 4 ./ex54 -ne 49 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type classical -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -ksp_converged_reason -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1; \
         ${DIFF} output/ex54_classical.out ex.tmp || printf "${PWD}\nPossible problem with ex54_classical.out, diffs above\n======================================\n"; \
       ${RM} -f ex.tmp
runex54f:
	-@${MPIEXEC} -n 4 ./ex54f -ne 39 -theta 30.0 -epsilon 1.e-1 -blob_center 0.,0. -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mat_coarsen_type hem -pc_gamg_square_graph 0 -ksp_monitor_short -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1; \
         ${DIFF} output/ex54f.out ex.tmp || printf "${PWD}\nPossible problem with ex54f.out, diffs above\n======================================\n"; \
        ${RM} -f ex.tmp
runex55_geo:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type geo -use_coordinates -ksp_monitor_short -mg_levels_esteig_ksp_type cg -ksp_type cg -ksp_norm_type unpreconditioned > ex.tmp 2>&1;	  \
         ${DIFF} output/ex55_0.out ex.tmp || printf "${PWD}\nPossible problem with ex55_0.out, diffs above\n=========================================\n"; \
        ${RM} -f ex.tmp
runex55_hypre:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_type cg -pc_type hypre -pc_hypre_type boomeramg -ksp_monitor_short > ex.tmp 2>&1;	  \
         ${DIFF} output/ex55_hypre.out ex.tmp || printf "${PWD}\nPossible problem with ex55_hypre, diffs above\n=========================================\n"; \
        ${RM} -f ex.tmp
runex55:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -use_coordinates -ksp_converged_reason -mg_levels_esteig_ksp_type cg -ksp_rtol 1.e-3 -ksp_monitor > ex.tmp 2>&1; \
         ${DIFF} output/ex55_sa.out ex.tmp || printf "${PWD}\nPossible problem with ex55_sa.out, diffs above\n=========================================\n"; \
        ${RM} -f ex.tmp
runex55_Classical:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type classical -mg_levels_ksp_max_it 5 -ksp_converged_reason -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1; \
         ${DIFF} output/ex55_classical.out ex.tmp || printf "${PWD}\nPossible problem with ex55_classical.out, diffs above\n=========================================\n"; \
        ${RM} -f ex.tmp
runex55_NC:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -ksp_converged_reason -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1; \
         ${DIFF} output/ex55_NC.out ex.tmp || printf "${PWD}\nPossible problem with ex55_NC.out, diffs above\n======================================\n"; \
        ${RM} -f ex.tmp
runex56:
	-@${MPIEXEC} -n 8 ./ex56 -ne 11 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true -two_solves -ksp_converged_reason -use_mat_nearnullspace -mg_levels_esteig_ksp_type gmres -pc_gamg_square_graph 1 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type sor > ex.tmp 2>&1; \
         ${DIFF} output/ex56_0.out ex.tmp || printf "${PWD}\nPossible problem with ex56_0.out, diffs above \n=========================================\n"; \
         ${RM} -f ex.tmp
runex56_ml:
	-@${MPIEXEC} -n 8 ./ex56 -ne 9 -alpha 1.e-3 -ksp_type cg -pc_type ml -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type sor -ksp_monitor_short -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1;	\
         ${DIFF} output/ex56_ml.out ex.tmp || printf "${PWD}\nPossible problem with ex56_ml.out, diffs above\n=========================================\n"; \
        ${RM} -f ex.tmp
runex56_nns:
	-@${MPIEXEC} -n 1 ./ex56 -ne 9 -alpha 1.e-3 -ksp_converged_reason -ksp_type cg -ksp_max_it 50 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 1000 -mg_levels_ksp_type chebyshev -mg_levels_pc_type sor -pc_gamg_reuse_interpolation true -two_solves -use_mat_nearnullspace -mg_levels_esteig_ksp_type cg > ex.tmp 2>&1;	\
         ${DIFF} output/ex56_nns.out ex.tmp || printf "${PWD}\nPossible problem with ex56_nns.out, diffs above\n=========================================\n"; \
         ${RM} -f ex.tmp
runex58:
	-@${MPIEXEC} -n 1 ./ex58 -mat_type aij > ex58.tmp 2>&1;         \
	${DIFF} output/ex58.out ex58.tmp || printf "${PWD}\nPossible problem with ex58, diffs above\n=========================================\n"; \
	${RM} -f ex58.tmp
runex58_baij:
	-@${MPIEXEC} -n 1 ./ex58 -mat_type baij > ex58.tmp 2>&1;         \
	${DIFF} output/ex58.out ex58.tmp || printf "${PWD}\nPossible problem with ex58_baij, diffs above\n=========================================\n"; \
	${RM} -f ex58.tmp
runex58_sbaij:
	-@${MPIEXEC} -n 1 ./ex58 -mat_type sbaij > ex58.tmp 2>&1;         \
	${DIFF} output/ex58.out ex58.tmp || printf "${PWD}\nPossible problem with ex58_sbaij, diffs above\n=========================================\n"; \
	${RM} -f ex58.tmp
runex59:
	-@${MPIEXEC} -n 4 ./ex59 -nex 7 > ex59.tmp 2>&1;         \
	${DIFF} output/ex59_1.out ex59.tmp || printf "${PWD}\nPossible problem with ex59, diffs above\n=========================================\n"; \
	${RM} -f ex59.tmp
runex59_2:
	-@${MPIEXEC} -n 4 ./ex59 -npx 2 -npy 2 -nex 6 -ney 6 -ksp_max_it 3 > ex59_2.tmp 2>&1;         \
	${DIFF} output/ex59_2.out ex59_2.tmp || printf "${PWD}\nPossible problem with ex59_2, diffs above\n=========================================\n"; \
	${RM} -f ex59_2.tmp
runex59_3:
	-@${MPIEXEC} -n 4 ./ex59 -npx 2 -npy 2 -npz 1 -nex 6 -ney 6 -nez 1 -ksp_max_it 4 > ex59_3.tmp 2>&1;         \
	${DIFF} output/ex59_3.out ex59_3.tmp || printf "${PWD}\nPossible problem with ex59_3, diffs above\n=========================================\n"; \
	${RM} -f ex59_3.tmp
runex60:
	-@${MPIEXEC} -n 2 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 1 -ksp_type fcg -ksp_fcg_mmax 1 -eta 0.1 > ex60_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex60_1.out ex60_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_1.tmp
runex60_2:
	-@${MPIEXEC} -n 2 ./ex60 -ksp_monitor_short -diagfunc 3 -ksp_type fcg -ksp_fcg_mmax 10000 -eta 0.3333 > ex60_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex60_2.out ex60_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_2.tmp
runex60_3:
	-@${MPIEXEC} -n 3 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 2 -ksp_type fgmres -eta 0.1 > ex60_3.tmp 2>&1;	  \
	   if (${DIFF} output/ex60_3.out ex60_3.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_3.tmp
runex60_4:
	-@${MPIEXEC} -n 2 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 1 -ksp_type pipefcg -ksp_pipefcg_mmax 1 -eta 0.1 > ex60_4.tmp 2>&1;	  \
	   if (${DIFF} output/ex60_4.out ex60_4.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_4, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_4.tmp
runex60_5:
	-@${MPIEXEC} -n 2 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 3 -ksp_type pipefcg -ksp_pipefcg_mmax 10000 -eta 0.1 > ex60_5.tmp 2>&1;	  \
           if (${DIFF} output/ex60_5.out ex60_5.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_5, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_5.tmp
runex60_6 :
	-@${MPIEXEC} -n 4 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 3 -ksp_type fcg -ksp_fcg_mmax 10000 -eta 0 -pc_type ksp -ksp_ksp_type cg -ksp_pc_type none -ksp_ksp_rtol 1e-1 -ksp_ksp_max_it 5 -ksp_ksp_converged_reason > ex60_6.tmp 2>&1; \
           if (${DIFF} output/ex60_6.out ex60_6.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_6, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_6.tmp
runex60_7 :
	-@${MPIEXEC} -n 4 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 3 -ksp_type pipefcg -ksp_pipefcg_mmax 10000 -eta 0 -pc_type ksp -ksp_ksp_type cg -ksp_pc_type none -ksp_ksp_rtol 1e-1 -ksp_ksp_max_it 5 -ksp_ksp_converged_reason > ex60_7.tmp 2>&1; \
           if (${DIFF} output/ex60_7.out ex60_7.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_7, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_7.tmp
runex60_8 :
	-@${MPIEXEC} -n 2 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 1 -ksp_type pipefgmres -pc_type ksp -ksp_ksp_type cg -ksp_pc_type none -ksp_ksp_rtol 1e-2 -ksp_ksp_converged_reason > ex60_8.tmp 2>&1;	  \
	   if (${DIFF} output/ex60_8.out ex60_8.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_8, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_8.tmp
runex60_9 :
	-@${MPIEXEC} -n 2 ./ex60 -ksp_monitor_short -ksp_rtol 1e-6 -diagfunc 1 -ksp_type pipefgmres -pc_type ksp -ksp_ksp_type cg -ksp_pc_type none -ksp_ksp_rtol 1e-2 -ksp_ksp_converged_reason > ex60_9.tmp 2>&1;	  \
	   if (${DIFF} output/ex60_9.out ex60_9.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex60_9, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex60_9.tmp
NP = 1
M  = 4
N  = 5
MDOMAINS = 2
NDOMAINS = 1
OVERLAP=1
TSUBDOMAINS = 1
runex62_valgrind:
	-@${MPIEXEC} -n ${NP} valgrind ./ex62 -M $M -N $N -print_error ${ARGS}
runex62:
	-@${MPIEXEC} -n ${NP} ./ex62 -M $M -N $N -print_error ${ARGS}
runex62_hp:
	-@${MPIEXEC} -n 4 ./ex62  -M 7  -N 9  -pc_gasm_overlap  1  -sub_pc_type lu  -sub_pc_factor_mat_solver_package superlu_dist  -ksp_monitor -print_error  -pc_gasm_total_subdomains 2 -pc_gasm_use_hierachical_partitioning 1 > ex62.tmp 2>&1;	  \
	   if (${DIFF} output/ex62.out ex62.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex62, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex62.tmp
runex62_2D:
	-@${MPIEXEC} -n ${NP} ./ex62 -M $M -N $N -user_set_subdomains -Mdomains ${MDOMAINS} -Ndomains ${NDOMAINS} -overlap ${OVERLAP} -print_error ${ARGS}
TSUBDOMAINS=1
runex62_superlu_dist:
	-@${MPIEXEC} -n ${NP} ./ex62 -M $M -N $N -print_error -pc_gasm_total_subdomains ${TSUBDOMAINS} -sub_pc_type lu -sub_pc_factor_mat_solver_package superlu_dist ${ARGS}
runex62_2D_1:
	-@${MPIEXEC} -n 1 ./ex62 -M 7 -N 9 -user_set_subdomains -Mdomains 1 -Ndomains 3 -overlap 1 -print_error -pc_gasm_print_subdomains > ex62.tmp 2>&1; \
	    if (${DIFF} output/ex62_2D_1.out ex62.tmp) then true; \
	    else printf "${PWD}\nPossible problem with ex62_2D_1, diffs above\n=========================================\n"; fi; \
	    ${RM} -f ex62.tmp
runex62_2D_2:
	-@${MPIEXEC} -n 2 ./ex62 -M 7 -N 9 -user_set_subdomains -Mdomains 1 -Ndomains 3 -overlap 1 -print_error -pc_gasm_print_subdomains > ex62.tmp 2>&1; \
	   if (${DIFF} output/ex62_2D_2.out ex62.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex62_2D_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex62.tmp
runex62_2D_3:
	-@${MPIEXEC} -n 3 ./ex62 -M 7 -N 9 -user_set_subdomains -Mdomains 1 -Ndomains 3 -overlap 1 -print_error -pc_gasm_print_subdomains > ex62.tmp 2>&1; \
	   if (${DIFF} output/ex62_2D_3.out ex62.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex62_2D_3, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex62.tmp
runex62_superlu_dist_1:
	-@${MPIEXEC} -n 1 ./ex62 -M 7 -N 9 -print_error -pc_gasm_total_subdomains 1 -pc_gasm_print_subdomains -sub_pc_type lu -sub_pc_factor_mat_solver_package superlu_dist > ex62.tmp 2>&1; \
	    if (${DIFF} output/ex62_superlu_dist_1.out ex62.tmp) then true; \
	    else printf "${PWD}\nPossible problem with ex62_superlu_dist_1, diffs above\n=========================================\n"; fi; \
	    ${RM} -f ex62.tmp
runex62_superlu_dist_2:
	-@${MPIEXEC} -n 2 ./ex62 -M 7 -N 9 -print_error -pc_gasm_total_subdomains 1 -pc_gasm_print_subdomains -sub_pc_type lu -sub_pc_factor_mat_solver_package superlu_dist > ex62.tmp 2>&1; \
	    if (${DIFF} output/ex62_superlu_dist_2.out ex62.tmp) then true; \
	    else printf "${PWD}\nPossible problem with ex62_superlu_dist_2, diffs above\n=========================================\n"; fi; \
	    ${RM} -f ex62.tmp
runex62_superlu_dist_3:
	-@${MPIEXEC} -n 3 ./ex62 -M 7 -N 9 -print_error -pc_gasm_total_subdomains 2 -pc_gasm_print_subdomains -sub_pc_type lu -sub_pc_factor_mat_solver_package superlu_dist > ex62.tmp 2>&1; \
	    if (${DIFF} output/ex62_superlu_dist_3.out ex62.tmp) then true; \
	    else printf "${PWD}\nPossible problem with ex62_superlu_dist_3, diffs above\n=========================================\n"; fi; \
	    ${RM} -f ex62.tmp
runex62_superlu_dist_4:
	-@${MPIEXEC} -n 4 ./ex62 -M 7 -N 9 -print_error -pc_gasm_total_subdomains 2 -pc_gasm_print_subdomains -sub_pc_type lu -sub_pc_factor_mat_solver_package superlu_dist > ex62.tmp 2>&1; \
	    if (${DIFF} output/ex62_superlu_dist_4.out ex62.tmp) then true; \
	    else printf "${PWD}\nPossible problem with ex62_superlu_dist_4, diffs above\n=========================================\n"; fi; \
	    ${RM} -f ex62.tmp
runex63:
	-@${MPIEXEC} -n 1 ./ex63 --filedir=${PETSC_DIR}/share/petsc/datafiles/matrices/ --filename=amesos2_test_mat0.mtx --solver=SuperLU --print-residual=true -ksp_monitor -pc_type lu -pc_factor_mat_solver_package superlu -ksp_view -ksp_converged_reason  > ex63_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex63_1.out ex63_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex63_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex63_1.tmp
runex63_2:
	-@${MPIEXEC} -n 1 ./ex63 --filedir=${PETSC_DIR}/share/petsc/datafiles/matrices/ --filename=amesos2_test_mat0.mtx --solver=SuperLUDist --print-residual=true -ksp_monitor -pc_type lu -pc_factor_mat_solver_package superlu_dist -ksp_view -ksp_converged_reason  > ex63_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex63_2.out ex63_2.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex63_2, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex63_2.tmp
runex64:
	-@${MPIEXEC} -n 4 ./ex64  -ksp_monitor -pc_gasm_overlap  1  -sub_pc_type lu  -sub_pc_factor_mat_solver_package superlu_dist    -pc_gasm_total_subdomains 2 > ex64.tmp 2>&1;	  \
	   if (${DIFF} output/ex64.out ex64.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex64, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex64.tmp
runex65:
	-@${MPIEXEC} -n 4 ./ex65  -ksp_monitor -pc_type mg -da_refine 3 > ex65.tmp 2>&1;	  \
	   if (${DIFF} output/ex65.out ex65.tmp) then true; \
	   else printf "${PWD}\nPossible problem with with ex65, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex65.tmp
TESTEXAMPLES_C		       = ex1.PETSc runex1 runex1_2 runex1_3 ex1.rm ex2.PETSc runex2 runex2_2 runex2_3 \
                                 runex2_4 runex2_bjacobi runex2_bjacobi_2 runex2_bjacobi_3  \
                                 runex2_chebyest_1 runex2_chebyest_2 runex2_fbcgs runex2_fbcgs_2 runex2_telescope runex2_pipecg runex2_pipecr runex2_groppcg runex2_pipecgrr ex2.rm \
                                 ex7.PETSc runex7 runex7_2 ex7.rm ex4.PETSc ex4.rm ex5.PETSc runex5 runex5_2 \
                                 runex5_redundant_0 runex5_redundant_1 runex5_redundant_2 runex5_redundant_3 runex5_redundant_4 ex5.rm \
                                 ex6.PETSc runex6 runex6_1 runex6_2 ex6.rm \
                                 ex9.PETSc runex9 ex9.rm ex12.PETSc runex12 ex12.rm ex13.PETSc runex13 ex13.rm \
                                 ex15.PETSc runex15 ex15.rm ex16.PETSc runex16 ex16.rm \
                                 ex23.PETSc runex23 runex23_2 ex23.rm ex25.PETSc runex25 runex25_2 ex25.rm \
                                 ex18.PETSc runex18_3 ex18.rm \
                                 ex27.PETSc ex27.rm ex28.PETSc ex28.rm ex29.PETSc runex29_telescope ex29.rm \
                                 ex31.PETSc ex31.rm ex32.PETSc runex32 ex32.rm ex34.PETSc runex34 ex34.rm ex42.PETSc ex42.rm \
                                 ex43.PETSc runex43 runex43_2 runex43_bjacobi runex43_bjacobi_baij runex43_nested_gmg runex43_3 ex43.rm \
                                 ex45.PETSc runex45 runex45_2 runex45_telescope runex45_telescope_2 ex45.rm \
                                 ex49.PETSc runex49 runex49_2 runex49_3 runex49_5 ex49.rm \
                                 ex51.PETSc runex51 ex51.rm \
                                 ex53.PETSc runex53 ex53.rm \
                                 ex54.PETSc runex54 runex54_Classical ex54.rm ex55.PETSc runex55 runex55_Classical runex55_NC ex55.rm\
                                 ex56.PETSc runex56_nns runex56 ex56.rm ex59.PETSc runex59 runex59_2 runex59_3 ex59.rm \
                                 ex58.PETSc runex58 runex58_baij runex58_sbaij ex58.rm \
                                 ex60.PETSc runex60 runex60_2 runex60_3 ex60.rm \
                                 ex62.PETSc runex62_2D_1 runex62_2D_2 runex62_2D_3 ex62.rm ex65.PETSc runex65 ex65.rm
TESTEXAMPLES_C_NOTSINGLE       = ex43.PETSc runex43_3 ex43.rm
TESTEXAMPLES_C_NOCOMPLEX       = ex54.PETSc ex54.rm ex10.PETSc runex10 ex10.rm
TESTEXAMPLES_C_NOCOMPLEX_NOTSINGLE = ex23.PETSc runex23_3 ex23.rm \
                                 ex34.PETSc runex34 runex34_2 ex34.rm \
                                 ex43.PETSc runex43_4 runex43_5 ex43.rm \
                                 ex49.PETSc runex49_6 runex49_7 runex49_8 ex49.rm \
                                 ex50.PETSc runex50_3 ex50.rm \
                                 ex60.PETSc runex60_4 runex60_5 runex60_6 runex60_7 runex60_8 runex60_9 ex60.rm
TESTEXAMPLES_C_X	       = ex2.PETSc runex2_5 ex2.rm ex5.PETSc runex5_5 ex5.rm ex8.PETSc ex8.rm ex28.PETSc runex28 ex28.rm
TESTEXAMPLES_FORTRAN	       = ex1f.PETSc runex1f ex1f.rm ex2f.PETSc runex2f runex2f_2 ex2f.rm ex6f.PETSc ex6f.rm \
                                 ex15f.PETSc runex15f ex15f.rm \
                                  ex45f.PETSc runex45f ex45f.rm
TESTEXAMPLES_FORTRAN_NOTSINGLE  = ex14f.PETSc runex14f  ex14f.rm  ex22f.PETSc runex22f ex22f.rm ex21f.PETSc runex21f ex21f.rm
TESTEXAMPLES_FORTRAN_MPIUNI    = ex1f.PETSc runex1f ex1f.rm ex6f.PETSc runex6f ex6f.rm
TESTEXAMPLES_C_X_MPIUNI      = ex1.PETSc runex1 runex1_2 runex1_3 ex1.rm ex2.PETSc runex2 runex2_3 ex2.rm \
                                 ex7.PETSc ex7.rm ex5.PETSc ex5.rm  ex9.PETSc runex9 ex9.rm \
                                 ex23.PETSc runex23 ex23.rm
TESTEXAMPLES_C_COMPLEX	       = ex10.PETSc ex10.rm ex11.PETSc runex11 ex11.rm
TESTEXAMPLES_DATAFILESPATH     = ex10.PETSc runex10_2 runex10_3 runex10_4 runex10_5 runex10_6 runex10_7 runex10_8 \
                                 runex10_9 runex10_10 runex10_19  runex10_ILU runex10_ILUBAIJ runex10_cg \
                                 runex10_cg_singlereduction runex10_seqaijcrl runex10_mpiaijcrl runex10_seqaijperm runex10_mpiaijperm ex10.rm \
                                 ex27.PETSc runex27 ex27.rm
# even though ex10.c is -pc_mg_smoothdown na C example to run with -mat_type lusol requires a Fortran compiler, hence
# we list it with the fortran examples
TESTEXAMPLES_FORTRAN_NOCOMPLEX =
TESTEXAMPLES_FORTRAN_COMPLEX            = ex11f.PETSc runex11f ex11f.rm
TESTEXAMPLES_F90	                = ex13f90.PETSc runex13f90 ex13f90.rm
TESTEXAMPLES_13		                = ex3.PETSc ex3.rm ex14f.PETSc ex14f.rm
TESTEXAMPLES_MATLAB_ENGINE              = ex10.PETSc runex10_12  ex10.rm
TESTEXAMPLES_17		                = ex10.PETSc runex10_11 ex10.rm
TESTEXAMPLES_18		                = ex2.PETSc runex2_6 ex2.rm
TESTEXAMPLES_SPAI	                = ex10.PETSc runex10_14 ex10.rm
TESTEXAMPLES_HYPRE	                = ex49.PETSc runex49_hypre_nullspace ex49.rm
TESTEXAMPLES_HYPRE_DATAFILESPATH        = ex10.PETSc runex10_15 runex10_16 runex10_17 runex10_boomeramg_schwarz runex10_boomeramg_parasails runex10_boomeramg_pilut ex10.rm
TESTEXAMPLES_LUSOL	                = ex10.PETSc runex10_13 ex10.rm
TESTEXAMPLES_MUMPS                      = ex53.PETSc runex53 runex53_2 ex53.rm \
                                          ex52.PETSc runex52 runex52_mumps runex52_mumps_2 runex52_mumps_3 ex52.rm ex52f.PETSc runex52f_mumps ex52f.rm
TESTEXAMPLES_MUMPS_DATAFILESPATH        = ex10.PETSc runex10_mumps_lu_1 runex10_mumps_lu_2 runex10_mumps_lu_3 runex10_mumps_lu_4 \
                                          runex10_mumps_cholesky_1 runex10_mumps_cholesky_2 runex10_mumps_cholesky_3 runex10_mumps_cholesky_4 \
                                          runex10_mumps_redundant runex10_mumps_cholesky_spd_1 runex10_mumps_cholesky_spd_2 \
                                          runex10_zeropivot runex10_zeropivot_2 ex10.rm
TESTEXAMPLES_PASTIX_DATAFILESPATH       = ex10.PETSc runex10_pastix_lu_1 runex10_pastix_lu_2  \
			  	          runex10_pastix_cholesky_1 runex10_pastix_cholesky_2  runex10_pastix_redundant \
                                          ex10.rm
TESTEXAMPLES_SUPERLU                    = ex52.PETSc runex52_superlu_ilu runex52_superlu ex52.rm
TESTEXAMPLES_SUPERLU_DATAFILESPATH      = ex10.PETSc runex10_superlu_lu_1 ex10.rm
TESTEXAMPLES_SUPERLU_DIST               = ex52.PETSc runex52_superlu_dist ex52.rm ex64.PETSc runex64 ex64.rm \
	 			          ex62.PETSc runex62_superlu_dist_1 runex62_superlu_dist_2 runex62_superlu_dist_3 runex62_superlu_dist_4 ex62.rm
TESTEXAMPLES_SUPERLU_DIST_DATAFILESPATH = ex10.PETSc runex10_superlu_dist_lu_1 runex10_superlu_dist_lu_2 runex10_superlu_dist_redundant ex10.rm
TESTEXAMPLES_SUITESPARSE_DATAFILESPATH  = ex10.PETSc runex10_umfpack ex10.rm
TESTEXAMPLES_SUITESPARSE                = ex2.PETSc runex2_umfpack ex2.rm
TESTEXAMPLES_MKL_PARDISO                = ex2.PETSc runex2_mkl_pardiso_lu runex2_mkl_pardiso_cholesky ex2.rm
TESTEXAMPLES_CUDA_DATAFILESPATH         = ex10.PETSc runex10_aijcusparse ex10.rm
TESTEXAMPLES_CUDA                       = ex7.PETSc  runex7_mpiaijcusparse runex7_mpiaijcusparse_2 ex7.rm \
                                          ex46.PETSc runex46_aijcusp runex46_aijcusparse ex46.rm
TESTEXAMPLES_MOAB                       = ex35.PETSc runex35 ex35.rm
TESTEXAMPLES_MOAB_HDF5                  = ex35.PETSc runex35_2 ex35.rm
TESTEXAMPLES_TRILINOS                   = ex63.PETSc runex63 runex63_2 ex63.rm
include ${PETSC_DIR}/lib/petsc/conf/test
