[petsc-users] petsc-3.5 quadruple precision mixed with double
Jed Brown
jed at jedbrown.org
Thu Jun 29 20:29:50 CDT 2017
Hao Zhang <hbcbh1999 at gmail.com> writes:
> Thanks for the input. I was doing a few tests. I will put quadruple
> precision choice on hold for now. Since the condition number is big at the
> beginning, scale of 10^2,
That is not large and you don't need quad precision to solve it to
better accuracy than almost any measured physical quantity.
> I will try to smooth the input of the matrix by introducing heaviside
> function.
Not sure how that is smoothing.
> I do have another question. the incompressible simulation I'm
> simulating is using all reflection(free slip neumann) boundary
> condition, what will be a good preconditioner? Shall I start a new
> thread? so, when other users search, they could use it as a reference
The boundary condition has almost no effect on choice of preconditioner.
There are lots of methods for incompressible flow, many of which can be
implemented at run-time using PCFIELDSPLIT. Unfortunately, there are
not good black-box solvers, so you'll have to do some reading.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170629/15bf8673/attachment.pgp>
