[petsc-users] Is linear solver performance is worse in parallel?
Lucas Clemente Vella lvella at gmail.com
Thu Jun 29 17:17:05 CDT 2017
2017-06-29 17:58 GMT-03:00 Matthew Knepley <knepley at gmail.com>:
> 1) For figuring out convergence issues, I would start with a smaller
> problem, so you can run lots of them
 Hi! Yes, I did start, but since they are smaller, I run with fewer
processes, and with few processes they converge (as well as the big
problem). It won't converge with many processes, but that isn't needed for
many small problems. I can still try it and report back, anyway.
2) For any questions about convergence, we need to see the output of
>   -ksp_view -ksp_monitor_true_residual -fieldsplit_1_ksp_monitor_true_residual
> -ksp_converged_reason
Can't provide it now, but I'll report back, too.
> 4) It sounds like the strength of your Schur complement preconditioner is
> not uniform in the size of the problem. Why
>     do you think LSC would be a good idea? Also, 'self' preconditioning
> for many equations, like Stokes, is not uniform
>     in problem size.
I don't know what else I could solve the problem, but the size of the
problem is not the issue here (yet!), otherwise, the same problem would not
converge with 8 processes, but it does! The issue arises when I increase
the number of processes, maintaining the global problem size. So the real
question is, are the proconditiones not uniform w.r.t. the number of
process, as they aren't w.r.t the size of the problem?
By the way, if I can't use self+LSC, how should I build the matrix to be
used in the preconditioner? From my tests, it seems "a11" is a bad choice
(doesn't converge).
> 5) What are your equations?
The matrix is the jacobian for discrete form of the non-linear
incompressible Navier-Stokes equations, given in http://mathb.in/147865
About
> 3) Please start with -fieldsplit_0_pc_type lu so we can just look at the
> Schur complement system
and
> 6) I would start with -fieldsplit_1_pc_type lu, which will test your PC
> matrix, and after that works, change things one at a time.
It already works with low number of processes (same problem size)! If I
manage to install and run a LU provider package that works in parallel,
what new information can be obtained?
>   Thanks,
>     Matt
>> lvella at gmail.com
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
lvella at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170629/ef3824c9/attachment-0001.html>
