[petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
Hassan Raiesi Hassan.Raiesi at aero.bombardier.com
Thu Jun 29 09:52:57 CDT 2017
That would great if it allows elements with mixed faces,
Thank you
-Hassan
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Thursday, June 29, 2017 10:36 AM
To: Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
On Thu, Jun 29, 2017 at 9:32 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
Ok,
The problem is that the faceSizes varies for pyramids and prisms, they have faces with variable number of nodes (i.e for pyramids, four triangular faces and one quad face, this I don’t see how to specify?
What if I report all faces as quad faces, for triangular faces, there would be a repeated vertex, would it make any problem?
No, you are right, that will not work. The whole interpolation code would have to be rewritten to allow faces with
variable size. Its not hard, but it is time-consuming. Since I am moving this summer, this will not be done in a timely
manner unfortunately.
    Matt
Thank you
-Hassan
From: Matthew Knepley [mailto:knepley at gmail.com<mailto:knepley at gmail.com>]
Sent: Thursday, June 29, 2017 10:12 AM
To: Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Thu, Jun 29, 2017 at 8:59 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
Matthew,
Not sure if I understood completely, I have the ordering according to the CGNS standard for all cells in the mesh, or I can change it if needed, but I don’t understand what you mean by reporting all faces as ordered vertices? Do you mean I just define the face connectivity?Could you explain a bit more?
For a triangular prism, you would add the case in GetRawFaces() for dim 3, coneSize 6. Lets look at a triangle (dim 2, coneSize 3)
  https://bitbucket.org/petsc/petsc/src/5ebd2cd705b0ffa5a27aee8a08f86795d413b548/src/dm/impls/plex/plexinterpolate.c?at=master&fileviewer=file-view-default#plexinterpolate.c-63
You see that it returns 3 groups of 2 vertices, which are the edges. For a tetrahedron
  https://bitbucket.org/petsc/petsc/src/5ebd2cd705b0ffa5a27aee8a08f86795d413b548/src/dm/impls/plex/plexinterpolate.c?at=master&fileviewer=file-view-default#plexinterpolate.c-101
it returns 4 groups of 3 vertices, which are the faces. Note that all faces should be oriented such that the normal is outward.
    Matt
Thank you
-Hassan
Sent: Tuesday, June 27, 2017 1:54 PM
On Tue, Jun 27, 2017 at 11:30 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
I meant the interpolation,
DMPlex supports those element shapes, however, there are two problems, one, “DMPlexBuildFromCellList_Parallel” does not take mixed elements (numCorners must be constant for all elements in current implementation), that was easy to fix,
I already extended DMPlexBuildFromCellList_Parallel_Private to take elements with different shapes,  then I realized the interpolation does not work when the mesh has elements other than tets and hex.
Okay, here is what is needed. You need to
  a) prescribe an order for the vertices in a prism/pyramid (all input cells must have this order)
  b) report all faces as sets of ordered vertices
    - You have to order them matching the Plex vertex order for the lower dimensional shape
    - They should be oriented as to have outward facing normal
Regarding the interpolation, I also noticed that the memory requirement is huge if I load the whole mesh on one core and interpolate (I cannot interpolate a mesh with 9M tets on a machine with 128GB of memory, it ran out of memory, I’ll try to run with petsc memory logs and send).
I am not sure what the upper limit is, but in a 3D mesh you could have many times the number of cells in faces and edges. Note that
you would need --with-64-bit-indices to go beyond 4GB.
is there anyways to interpolate the mesh after  DMPlexdistribute? The code crashes if I move DMPlexInterpolate to after calling DMPlexdistribute., I guess what is needed is a DMPlexInterpolate on already distributed meshes.
This should work. Maybe try a small example? If that crashes, just send it.
    Matt
Thank you
-Hassan
Sent: Tuesday, June 27, 2017 11:53 AM
On Tue, Jun 27, 2017 at 10:08 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
Great, It’s clear now ☺,
One more question, any plan to support other element shapes (prism and pyramid) in 3D?,  DMPlexGetRawFaces_Internal only supports tets and hexs in 3D, can prisms and pyramids be used as degenerate hexahedrons?
It depends on what you mean "support". Right now, we can represent these shapes in Plex. However, if you
want mesh interpolation to work, then yes you need to extend GetRawFaces() to understand that shape. If
you want them read out of a file format, other than Gmsh, we would likely have to extend that as well. These
are straightforward once I understand what exactly you want to do.
    Matt
Thank you
-Hassan
Sent: Tuesday, June 27, 2017 10:17 AM
On Tue, Jun 27, 2017 at 9:12 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
Thanks for your reply,
Is there any example where each rank owns more than 1 element, i.e for the simple mesh here(attached png file), how should I pack and pass the coordinates of the vertices owned by rank0, rank1
Rank0:numcells = 2; num nodes=4, cells=[154 245] , nodes=[1 5 2 4]
nodes = 1245
vertex coords: in what node order ?
[coords_n1 coords_n2 coords_n4 coords_n5] or
[coords_n2 coords_n4 coords_n1 coords_n5] or …..?
rank1: numcells = 2; num nodes=2, cells=[532 635], nodes=[6 3]
vertexcoords [how to pack the nodes coords here?]
should it be  [x6y6 x3y3] or [x3y3 x6y6]? In what order?
I think there is a misunderstanding here.
There is NO connection between the cell order and the vertex order. Each process gets a contiguous
set of cells (in the global numbering) and a contiguous set of vertices (in the global numbering). These
two are NOT related. We then move the vertices to the correct processes. In this way, we can load
completely in parallel, without requiring any setup in the mesh file.
If you are worried, you can always arrange the order of vertices to "match" the order of cells.
    Matt
thanks
Sent: Sunday, June 25, 2017 1:04 PM
On Tue, Apr 11, 2017 at 9:21 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
Hello,
I’m trying to use DMPlexCreateFromCellListParallel to create a DM from an already partitioned mesh,
It requires an array of numVertices*spaceDim numbers, but how should one order the coordinates of the vertices?
Global order. Here is the idea. You must read the file in chunks so that each proc can read its own chunk in parallel
without talking to anyone else.
we only pass the global vertex numbers using ‘const int cells[]’ to define the cell-connectivity, so passing the vertex coordinates in local ordering wouldn’t make sense?
Yes.
If it needs to be in global ordering, should I sort the global index of the node numbers owned by each rank (as they wont be continuous).
Nope.
    Matt
Thank you
Hassan Raiesi,
Bombardier Aerospace
www.bombardier.com<http://www.bombardier.com>
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170629/42955744/attachment-0001.html>
