[petsc-users] petsc-3.5 quadruple precision mixed with double
Jed Brown jed at jedbrown.org
Wed Jun 28 20:00:22 CDT 2017
Hao Zhang <hbcbh1999 at gmail.com> writes:
> hi, all:
> I'm developing a CFD project, which all the matrix solver is PETSc based.
> It works fine with double precision until I need some more, like quadruple
> precision.
What sort of CFD problem do you need quad precision for?
> Ax = b is the system
> input are double precision
> shall I use PetscScalar instead of double?
Yes.
> Or is there a better way to pass double type to PETSc solver?
No, use PetscScalar in your code.
> Or shall I convert double type to quadruple type before passing into the
> solver?
That tends to be uglier and slower.  It also loses accuracy in the
input, which is important for extremely ill-conditioned problems.
> I'm using PETSc 3.5.4. GCC 5.2.0 comiple with float128. I think there
> should be no compiling error.
> I can provide more code part if necessary. Thanks!
> Hao
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170628/11c1f4ca/attachment.pgp>
