[petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
Tue Jun 27 12:53:34 CDT 2017
On Tue, Jun 27, 2017 at 11:30 AM, Hassan Raiesi <
Hassan.Raiesi at aero.bombardier.com> wrote:
> I meant the interpolation,
> DMPlex supports those element shapes, however, there are two problems,
> one, “DMPlexBuildFromCellList_Parallel” does not take mixed elements
> (numCorners must be constant for all elements in current implementation),
> that was easy to fix,
> I already extended DMPlexBuildFromCellList_Parallel_Private to take
> elements with different shapes,  then I realized the interpolation does not
> work when the mesh has elements other than tets and hex.
Okay, here is what is needed. You need to
  a) prescribe an order for the vertices in a prism/pyramid (all input
cells must have this order)
  b) report all faces as sets of ordered vertices
    - You have to order them matching the Plex vertex order for the lower
dimensional shape
    - They should be oriented as to have outward facing normal
> Regarding the interpolation, I also noticed that the memory requirement is
> huge if I load the whole mesh on one core and interpolate (I cannot
> interpolate a mesh with 9M tets on a machine with 128GB of memory, it ran
> out of memory, I’ll try to run with petsc memory logs and send).
I am not sure what the upper limit is, but in a 3D mesh you could have many
times the number of cells in faces and edges. Note that
you would need --with-64-bit-indices to go beyond 4GB.
> is there anyways to interpolate the mesh after  DMPlexdistribute? The code
> crashes if I move DMPlexInterpolate to after calling DMPlexdistribute., I
> guess what is needed is a DMPlexInterpolate on already distributed meshes.
This should work. Maybe try a small example? If that crashes, just send it.
    Matt
> Thank you
> -Hassan
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Tuesday, June 27, 2017 11:53 AM
> *To:* Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] specifying vertex coordinates using
> On Tue, Jun 27, 2017 at 10:08 AM, Hassan Raiesi <Hassan.Raiesi at aero.
> Great, It’s clear now J,
> One more question, any plan to support other element shapes (prism and
> pyramid) in 3D?,  DMPlexGetRawFaces_Internal only supports tets and hexs
> in 3D, can prisms and pyramids be used as degenerate hexahedrons?
> It depends on what you mean "support". Right now, we can represent these
> shapes in Plex. However, if you
> want mesh interpolation to work, then yes you need to extend GetRawFaces()
> to understand that shape. If
> you want them read out of a file format, other than Gmsh, we would likely
> have to extend that as well. These
> are straightforward once I understand what exactly you want to do.
>   Thanks,
>     Matt
> Thank you
> -Hassan
> *Sent:* Tuesday, June 27, 2017 10:17 AM
> On Tue, Jun 27, 2017 at 9:12 AM, Hassan Raiesi <Hassan.Raiesi at aero.
> Thanks for your reply,
> Is there any example where each rank owns more than 1 element, i.e for the
> simple mesh here(attached png file), how should I pack and pass the
> coordinates of the vertices owned by rank0, rank1
> Rank0:numcells = 2; num nodes=4, cells=[154 245] , nodes=[1 5 2 4]
> nodes = 1245
> vertex coords: in what node order ?
> [coords_n1 coords_n2 coords_n4 coords_n5] or
> [coords_n2 coords_n4 coords_n1 coords_n5] or …..?
> rank1: numcells = 2; num nodes=2, cells=[532 635], nodes=[6 3]
> vertexcoords [how to pack the nodes coords here?]
> should it be  [x6y6 x3y3] or [x3y3 x6y6]? In what order?
> I think there is a misunderstanding here.
> There is NO connection between the cell order and the vertex order. Each
> process gets a contiguous
> set of cells (in the global numbering) and a contiguous set of vertices
> (in the global numbering). These
> two are NOT related. We then move the vertices to the correct processes.
> In this way, we can load
> completely in parallel, without requiring any setup in the mesh file.
> If you are worried, you can always arrange the order of vertices to
> "match" the order of cells.
>   Thanks,
>     Matt
> thanks
> *Sent:* Sunday, June 25, 2017 1:04 PM
> On Tue, Apr 11, 2017 at 9:21 AM, Hassan Raiesi <Hassan.Raiesi at aero.
> Hello,
> I’m trying to use DMPlexCreateFromCellListParallel to create a DM from an
> already partitioned mesh,
> It requires an array of numVertices*spaceDim numbers, but how should one
> order the coordinates of the vertices?
> Global order. Here is the idea. You must read the file in chunks so that
> each proc can read its own chunk in parallel
> without talking to anyone else.
> we only pass the global vertex numbers using ‘const int cells[]’ to define
> the cell-connectivity, so passing the vertex coordinates in local ordering
> wouldn’t make sense?
> Yes.
> If it needs to be in global ordering, should I sort the global index of
> the node numbers owned by each rank (as they wont be continuous).
> Nope.
>   Thanks,
>     Matt
> Thank you
> Hassan Raiesi,
> Bombardier Aerospace
> www.bombardier.com
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170627/7f1639b2/attachment.html>
