[petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
Tue Jun 27 10:52:44 CDT 2017
On Tue, Jun 27, 2017 at 10:08 AM, Hassan Raiesi <
Hassan.Raiesi at aero.bombardier.com> wrote:
> Great, It’s clear now J,
> One more question, any plan to support other element shapes (prism and
> pyramid) in 3D?,  DMPlexGetRawFaces_Internal only supports tets and hexs
> in 3D, can prisms and pyramids be used as degenerate hexahedrons?
It depends on what you mean "support". Right now, we can represent these
shapes in Plex. However, if you
want mesh interpolation to work, then yes you need to extend GetRawFaces()
to understand that shape. If
you want them read out of a file format, other than Gmsh, we would likely
have to extend that as well. These
are straightforward once I understand what exactly you want to do.
    Matt
> Thank you
> -Hassan
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Tuesday, June 27, 2017 10:17 AM
> *To:* Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] specifying vertex coordinates using
> On Tue, Jun 27, 2017 at 9:12 AM, Hassan Raiesi <Hassan.Raiesi at aero.
> Thanks for your reply,
> Is there any example where each rank owns more than 1 element, i.e for the
> simple mesh here(attached png file), how should I pack and pass the
> coordinates of the vertices owned by rank0, rank1
> Rank0:numcells = 2; num nodes=4, cells=[154 245] , nodes=[1 5 2 4]
> nodes = 1245
> vertex coords: in what node order ?
> [coords_n1 coords_n2 coords_n4 coords_n5] or
> [coords_n2 coords_n4 coords_n1 coords_n5] or …..?
> rank1: numcells = 2; num nodes=2, cells=[532 635], nodes=[6 3]
> vertexcoords [how to pack the nodes coords here?]
> should it be  [x6y6 x3y3] or [x3y3 x6y6]? In what order?
> I think there is a misunderstanding here.
> There is NO connection between the cell order and the vertex order. Each
> process gets a contiguous
> set of cells (in the global numbering) and a contiguous set of vertices
> (in the global numbering). These
> two are NOT related. We then move the vertices to the correct processes.
> In this way, we can load
> completely in parallel, without requiring any setup in the mesh file.
> If you are worried, you can always arrange the order of vertices to
> "match" the order of cells.
>   Thanks,
>     Matt
> thanks
> *Sent:* Sunday, June 25, 2017 1:04 PM
> On Tue, Apr 11, 2017 at 9:21 AM, Hassan Raiesi <Hassan.Raiesi at aero.
> Hello,
> I’m trying to use DMPlexCreateFromCellListParallel to create a DM from an
> already partitioned mesh,
> It requires an array of numVertices*spaceDim numbers, but how should one
> order the coordinates of the vertices?
> Global order. Here is the idea. You must read the file in chunks so that
> each proc can read its own chunk in parallel
> without talking to anyone else.
> we only pass the global vertex numbers using ‘const int cells[]’ to define
> the cell-connectivity, so passing the vertex coordinates in local ordering
> wouldn’t make sense?
> Yes.
> If it needs to be in global ordering, should I sort the global index of
> the node numbers owned by each rank (as they wont be continuous).
> Nope.
>   Thanks,
>     Matt
> Thank you
> Hassan Raiesi,
> Bombardier Aerospace
> www.bombardier.com
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170627/154a731c/attachment-0001.html>
