[petsc-users] -ksp_pc_side for -pc_fieldsplit_schur_fact_type upper
Hoang Giang Bui
hgbk2008 at gmail.com
Fri Jun 23 11:48:18 CDT 2017
Hello
I just want to make sure that I understand the right thing, in the manual
page of PCFieldSplitSetSchurFactType:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetSchurFactType.html
The "upper" option uses DU from the full factorization. If I understand
correctly, the ksp must be used with right preconditioning, because A P^-1
= (LDU) * (DU)^(-1) = L. If that was the case, should the manual put this
information to be more clear?
Thanks
Giang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170623/3337c69a/attachment.html>
