[petsc-users] Issue using multi-grid as a pre-conditioner with KSP for a Poisson problem
Matthew Knepley
knepley at gmail.com
Thu Jun 22 19:35:52 CDT 2017
On Thu, Jun 22, 2017 at 3:20 PM, Jason Lefley <jason.lefley at aclectic.com>
wrote:
> Thanks for the prompt replies. I ran with gamg and the results look more
> promising. I tried the suggested -mg_* options and did not see improvement.
> The -ksp_view and -ksp_monitor_true_residual output from those tests and
> the solver_test source (modified ex34.c) follow:
Okay, the second step is to replicate the smoother for the GMG, which will
have a smaller and scalable setup time. The
smoother could be weak, or the restriction could be bad.
Matt
> $ mpirun -n 16 ./solver_test -da_grid_x 128 -da_grid_y 128 -da_grid_z 128
> -ksp_view -ksp_monitor_true_residual -pc_type gamg -ksp_type cg
> right hand side 2 norm: 512.
> right hand side infinity norm: 0.999097
> building operator with Dirichlet boundary conditions, global grid size:
> 128 x 128 x 128
> 0 KSP preconditioned resid norm 2.600515167901e+00 true resid norm
> 5.120000000000e+02 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 6.715532962879e-02 true resid norm
> 7.578946422553e+02 ||r(i)||/||b|| 1.480262973155e+00
> 2 KSP preconditioned resid norm 1.127682308441e-02 true resid norm
> 3.247852182315e+01 ||r(i)||/||b|| 6.343461293584e-02
> 3 KSP preconditioned resid norm 7.760468503025e-04 true resid norm
> 3.304142895659e+00 ||r(i)||/||b|| 6.453404093085e-03
> 4 KSP preconditioned resid norm 6.419777870067e-05 true resid norm
> 2.662993775521e-01 ||r(i)||/||b|| 5.201159717815e-04
> 5 KSP preconditioned resid norm 5.107540549482e-06 true resid norm
> 2.309528369351e-02 ||r(i)||/||b|| 4.510797596388e-05
> KSP Object: 16 MPI processes
> type: cg
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: 16 MPI processes
> type: gamg
> MG: type is MULTIPLICATIVE, levels=5 cycles=v
> Cycles per PCApply=1
> Using Galerkin computed coarse grid matrices
> GAMG specific options
> Threshold for dropping small values from graph 0.
> AGG specific options
> Symmetric graph false
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_coarse_) 16 MPI processes
> type: preonly
> using NONE norm type for convergence test
> PC Object: (mg_coarse_) 16 MPI processes
> type: bjacobi
> block Jacobi: number of blocks = 16
> Local solve is same for all blocks, in the following KSP and PC
> objects:
> KSP Object: (mg_coarse_sub_) 1 MPI processes
> type: preonly
> maximum iterations=1, initial guess is zero
> PC Object: (mg_coarse_sub_) 1 MPI processes
> type: lu
> LU: out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> matrix ordering: nd
> factor fill ratio given 5., needed 1.
> Factored matrix follows:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=13, cols=13
> package used to perform factorization: petsc
> total: nonzeros=169, allocated nonzeros=169
> total number of mallocs used during MatSetValues calls =0
> using I-node routines: found 3 nodes, limit used is 5
> linear system matrix = precond matrix:
> type: seqaij
> rows=13, cols=13
> Mat Object: 16 MPI processes
> type: mpiaij
> rows=13, cols=13
> using I-node (on process 0) routines: found 3 nodes, limit used
> is 5
> Down solver (pre-smoother) on level 1 -------------------------------
> KSP Object: (mg_levels_1_) 16 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0.136516, max = 1.50168
> Chebyshev: eigenvalues estimated using gmres with translations
> [0. 0.1; 0. 1.1]
> KSP Object: (mg_levels_1_esteig_) 16 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10, initial guess is zero
> tolerances: relative=1e-12, absolute=1e-50, divergence=10000.
> maximum iterations=2
> using nonzero initial guess
> PC Object: (mg_levels_1_) 16 MPI processes
> type: sor
> SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1.
> type: mpiaij
> rows=467, cols=467
> total: nonzeros=68689, allocated nonzeros=68689
> not using I-node (on process 0) routines
> Up solver (post-smoother) same as down solver (pre-smoother)
> Down solver (pre-smoother) on level 2 -------------------------------
> KSP Object: (mg_levels_2_) 16 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0.148872, max = 1.63759
> [0. 0.1; 0. 1.1]
> KSP Object: (mg_levels_2_esteig_) 16 MPI processes
> type: gmres
> PC Object: (mg_levels_2_) 16 MPI processes
> type: sor
> omega = 1.
> type: mpiaij
> rows=14893, cols=14893
> total: nonzeros=1856839, allocated nonzeros=1856839
> Down solver (pre-smoother) on level 3 -------------------------------
> KSP Object: (mg_levels_3_) 16 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0.135736, max = 1.49309
> [0. 0.1; 0. 1.1]
> KSP Object: (mg_levels_3_esteig_) 16 MPI processes
> type: gmres
> PC Object: (mg_levels_3_) 16 MPI processes
> type: sor
> omega = 1.
> type: mpiaij
> rows=190701, cols=190701
> total: nonzeros=6209261, allocated nonzeros=6209261
> Down solver (pre-smoother) on level 4 -------------------------------
> KSP Object: (mg_levels_4_) 16 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0.140039, max = 1.54043
> [0. 0.1; 0. 1.1]
> KSP Object: (mg_levels_4_esteig_) 16 MPI processes
> type: gmres
> PC Object: (mg_levels_4_) 16 MPI processes
> type: sor
> omega = 1.
> type: mpiaij
> rows=2097152, cols=2097152
> total: nonzeros=14581760, allocated nonzeros=14581760
> type: mpiaij
> Residual 2 norm 0.0230953
> Residual infinity norm 0.000240174
> -ksp_view -ksp_monitor_true_residual -pc_type mg -ksp_type cg -pc_mg_levels
> 5 -mg_levels_ksp_type richardson -mg_levels_ksp_richardson_self_scale
> -mg_levels_ksp_max_it 5
> 128 x 128 x 128
> building operator with Dirichlet boundary conditions, global grid size: 16
> x 16 x 16
> building operator with Dirichlet boundary conditions, global grid size: 32
> x 32 x 32
> building operator with Dirichlet boundary conditions, global grid size: 64
> x 64 x 64
> building operator with Dirichlet boundary conditions, global grid size: 8
> x 8 x 8
> 0 KSP preconditioned resid norm 1.957390963372e+03 true resid norm
> 1 KSP preconditioned resid norm 7.501162328351e+02 true resid norm
> 3.373318498950e+02 ||r(i)||/||b|| 6.588512693262e-01
> 2 KSP preconditioned resid norm 7.658993705113e+01 true resid norm
> 1.827365322620e+02 ||r(i)||/||b|| 3.569072895742e-01
> 3 KSP preconditioned resid norm 9.059824824329e+02 true resid norm
> 1.426474831278e+02 ||r(i)||/||b|| 2.786083654840e-01
> 4 KSP preconditioned resid norm 4.091168582134e+02 true resid norm
> 1.292495057977e+02 ||r(i)||/||b|| 2.524404410112e-01
> 5 KSP preconditioned resid norm 7.422110759274e+01 true resid norm
> 1.258028404461e+02 ||r(i)||/||b|| 2.457086727463e-01
> 6 KSP preconditioned resid norm 4.619015396949e+01 true resid norm
> 1.213792421102e+02 ||r(i)||/||b|| 2.370688322464e-01
> 7 KSP preconditioned resid norm 6.391009527793e+01 true resid norm
> 1.124510270422e+02 ||r(i)||/||b|| 2.196309121917e-01
> 8 KSP preconditioned resid norm 7.446926604265e+01 true resid norm
> 1.077567310933e+02 ||r(i)||/||b|| 2.104623654166e-01
> 9 KSP preconditioned resid norm 4.220904319642e+01 true resid norm
> 9.988181971539e+01 ||r(i)||/||b|| 1.950816791316e-01
> 10 KSP preconditioned resid norm 2.394387980018e+01 true resid norm
> 9.127579669592e+01 ||r(i)||/||b|| 1.782730404217e-01
> 11 KSP preconditioned resid norm 1.360843954226e+01 true resid norm
> 8.771762326371e+01 ||r(i)||/||b|| 1.713234829369e-01
> 12 KSP preconditioned resid norm 4.128223286694e+01 true resid norm
> 8.529182941649e+01 ||r(i)||/||b|| 1.665856043291e-01
> 13 KSP preconditioned resid norm 2.183532094447e+01 true resid norm
> 8.263211340769e+01 ||r(i)||/||b|| 1.613908464994e-01
> 14 KSP preconditioned resid norm 1.304178992338e+01 true resid norm
> 7.971822602122e+01 ||r(i)||/||b|| 1.556996601977e-01
> 15 KSP preconditioned resid norm 7.573349141411e+00 true resid norm
> 7.520975377445e+01 ||r(i)||/||b|| 1.468940503407e-01
> 16 KSP preconditioned resid norm 9.314890793459e+00 true resid norm
> 7.304954328407e+01 ||r(i)||/||b|| 1.426748892267e-01
> 17 KSP preconditioned resid norm 4.445933446231e+00 true resid norm
> 6.978356031428e+01 ||r(i)||/||b|| 1.362960162388e-01
> 18 KSP preconditioned resid norm 5.349719054065e+00 true resid norm
> 6.667516877214e+01 ||r(i)||/||b|| 1.302249390081e-01
> 19 KSP preconditioned resid norm 3.295861671942e+00 true resid norm
> 6.182140339659e+01 ||r(i)||/||b|| 1.207449285090e-01
> 20 KSP preconditioned resid norm 1.035616277789e+01 true resid norm
> 5.734720030036e+01 ||r(i)||/||b|| 1.120062505866e-01
> 21 KSP preconditioned resid norm 3.211186072853e+01 true resid norm
> 5.552393909940e+01 ||r(i)||/||b|| 1.084451935535e-01
> 22 KSP preconditioned resid norm 1.305589450595e+01 true resid norm
> 5.499062776214e+01 ||r(i)||/||b|| 1.074035698479e-01
> 23 KSP preconditioned resid norm 2.686432456763e+00 true resid norm
> 5.207613218582e+01 ||r(i)||/||b|| 1.017111956754e-01
> 24 KSP preconditioned resid norm 2.824784197849e+00 true resid norm
> 4.838619801451e+01 ||r(i)||/||b|| 9.450429299708e-02
> 25 KSP preconditioned resid norm 1.071690618667e+00 true resid norm
> 4.607851421273e+01 ||r(i)||/||b|| 8.999709807174e-02
> 26 KSP preconditioned resid norm 1.881879145107e+00 true resid norm
> 4.001593265961e+01 ||r(i)||/||b|| 7.815611847581e-02
> 27 KSP preconditioned resid norm 1.572862295402e+00 true resid norm
> 3.838282973517e+01 ||r(i)||/||b|| 7.496646432650e-02
> 28 KSP preconditioned resid norm 1.470751639074e+00 true resid norm
> 3.480847634691e+01 ||r(i)||/||b|| 6.798530536506e-02
> 29 KSP preconditioned resid norm 1.024975253805e+01 true resid norm
> 3.242161363347e+01 ||r(i)||/||b|| 6.332346412788e-02
> 30 KSP preconditioned resid norm 2.548780607710e+00 true resid norm
> 3.146609403253e+01 ||r(i)||/||b|| 6.145721490728e-02
> 31 KSP preconditioned resid norm 1.560691471465e+00 true resid norm
> 2.970265802267e+01 ||r(i)||/||b|| 5.801300395052e-02
> 32 KSP preconditioned resid norm 2.596714997356e+00 true resid norm
> 2.766969046763e+01 ||r(i)||/||b|| 5.404236419458e-02
> 33 KSP preconditioned resid norm 7.034818331385e+00 true resid norm
> 2.684572557056e+01 ||r(i)||/||b|| 5.243305775501e-02
> 34 KSP preconditioned resid norm 1.494072683898e+00 true resid norm
> 2.475430030960e+01 ||r(i)||/||b|| 4.834824279219e-02
> 35 KSP preconditioned resid norm 2.080781323538e+01 true resid norm
> 2.334859550417e+01 ||r(i)||/||b|| 4.560272559409e-02
> 36 KSP preconditioned resid norm 2.046655096031e+00 true resid norm
> 2.240354154839e+01 ||r(i)||/||b|| 4.375691708669e-02
> 37 KSP preconditioned resid norm 7.606846976760e-01 true resid norm
> 2.109556419574e+01 ||r(i)||/||b|| 4.120227381981e-02
> 38 KSP preconditioned resid norm 2.521301363193e+00 true resid norm
> 1.843497075964e+01 ||r(i)||/||b|| 3.600580226493e-02
> 39 KSP preconditioned resid norm 3.726976470079e+00 true resid norm
> 1.794209917279e+01 ||r(i)||/||b|| 3.504316244686e-02
> 40 KSP preconditioned resid norm 8.959884762705e-01 true resid norm
> 1.573137783532e+01 ||r(i)||/||b|| 3.072534733461e-02
> 41 KSP preconditioned resid norm 1.227682448888e+00 true resid norm
> 1.501346415860e+01 ||r(i)||/||b|| 2.932317218476e-02
> 42 KSP preconditioned resid norm 1.452770736534e+00 true resid norm
> 1.433942919922e+01 ||r(i)||/||b|| 2.800669765473e-02
> 43 KSP preconditioned resid norm 5.675352390898e-01 true resid norm
> 1.216437815936e+01 ||r(i)||/||b|| 2.375855109250e-02
> 44 KSP preconditioned resid norm 4.949409351772e-01 true resid norm
> 1.042812110399e+01 ||r(i)||/||b|| 2.036742403123e-02
> 45 KSP preconditioned resid norm 2.002853875915e+00 true resid norm
> 9.309183650084e+00 ||r(i)||/||b|| 1.818199931657e-02
> 46 KSP preconditioned resid norm 3.745525627399e-01 true resid norm
> 8.522457639380e+00 ||r(i)||/||b|| 1.664542507691e-02
> 47 KSP preconditioned resid norm 1.811694613170e-01 true resid norm
> 7.531206553361e+00 ||r(i)||/||b|| 1.470938779953e-02
> 48 KSP preconditioned resid norm 1.782171623447e+00 true resid norm
> 6.764441307706e+00 ||r(i)||/||b|| 1.321179942911e-02
> 49 KSP preconditioned resid norm 2.299828236176e+00 true resid norm
> 6.702407994976e+00 ||r(i)||/||b|| 1.309064061519e-02
> 50 KSP preconditioned resid norm 1.273834849543e+00 true resid norm
> 6.053797247633e+00 ||r(i)||/||b|| 1.182382274928e-02
> 51 KSP preconditioned resid norm 2.719578737249e-01 true resid norm
> 5.470925517497e+00 ||r(i)||/||b|| 1.068540140136e-02
> 52 KSP preconditioned resid norm 4.663757145206e-01 true resid norm
> 5.005785517882e+00 ||r(i)||/||b|| 9.776924839614e-03
> 53 KSP preconditioned resid norm 1.292565284376e+00 true resid norm
> 4.881780753946e+00 ||r(i)||/||b|| 9.534728035050e-03
> 54 KSP preconditioned resid norm 1.867369610632e-01 true resid norm
> 4.496564950399e+00 ||r(i)||/||b|| 8.782353418749e-03
> 55 KSP preconditioned resid norm 5.249392115789e-01 true resid norm
> 4.092757959067e+00 ||r(i)||/||b|| 7.993667888803e-03
> 56 KSP preconditioned resid norm 1.924525961621e-01 true resid norm
> 3.780501481010e+00 ||r(i)||/||b|| 7.383791955098e-03
> 57 KSP preconditioned resid norm 5.779420386829e-01 true resid norm
> 3.213189014725e+00 ||r(i)||/||b|| 6.275759794385e-03
> 58 KSP preconditioned resid norm 5.955339076981e-01 true resid norm
> 3.112032435949e+00 ||r(i)||/||b|| 6.078188351463e-03
> 59 KSP preconditioned resid norm 3.750139060970e-01 true resid norm
> 2.999193364090e+00 ||r(i)||/||b|| 5.857799539239e-03
> 60 KSP preconditioned resid norm 1.384679712935e-01 true resid norm
> 2.745891157615e+00 ||r(i)||/||b|| 5.363068667216e-03
> 61 KSP preconditioned resid norm 7.632834890339e-02 true resid norm
> 2.176299405671e+00 ||r(i)||/||b|| 4.250584776702e-03
> 62 KSP preconditioned resid norm 3.147491994853e-01 true resid norm
> 1.832893972188e+00 ||r(i)||/||b|| 3.579871039430e-03
> 63 KSP preconditioned resid norm 5.052243308649e-01 true resid norm
> 1.775115122392e+00 ||r(i)||/||b|| 3.467021723421e-03
> 64 KSP preconditioned resid norm 8.956523831283e-01 true resid norm
> 1.731441975933e+00 ||r(i)||/||b|| 3.381722609244e-03
> 65 KSP preconditioned resid norm 7.897527588669e-01 true resid norm
> 1.682654829619e+00 ||r(i)||/||b|| 3.286435214100e-03
> 66 KSP preconditioned resid norm 5.770941160165e-02 true resid norm
> 1.560734518349e+00 ||r(i)||/||b|| 3.048309606150e-03
> 67 KSP preconditioned resid norm 3.553024960194e-02 true resid norm
> 1.389699750667e+00 ||r(i)||/||b|| 2.714257325521e-03
> 68 KSP preconditioned resid norm 4.316233667769e-02 true resid norm
> 1.147051776028e+00 ||r(i)||/||b|| 2.240335500054e-03
> 69 KSP preconditioned resid norm 3.793691994632e-02 true resid norm
> 1.012385825627e+00 ||r(i)||/||b|| 1.977316065678e-03
> 70 KSP preconditioned resid norm 2.383460701011e-02 true resid norm
> 8.696480161436e-01 ||r(i)||/||b|| 1.698531281530e-03
> 71 KSP preconditioned resid norm 6.376655007996e-02 true resid norm
> 7.779779636534e-01 ||r(i)||/||b|| 1.519488210261e-03
> 72 KSP preconditioned resid norm 5.714768085413e-02 true resid norm
> 7.153671793501e-01 ||r(i)||/||b|| 1.397201522168e-03
> 73 KSP preconditioned resid norm 1.708395350387e-01 true resid norm
> 6.312992319936e-01 ||r(i)||/||b|| 1.233006312487e-03
> 74 KSP preconditioned resid norm 1.498516783452e-01 true resid norm
> 6.006527781743e-01 ||r(i)||/||b|| 1.173149957372e-03
> 75 KSP preconditioned resid norm 1.218071938641e-01 true resid norm
> 5.769463903876e-01 ||r(i)||/||b|| 1.126848418726e-03
> 76 KSP preconditioned resid norm 2.682030144251e-02 true resid norm
> 5.214035118381e-01 ||r(i)||/||b|| 1.018366234059e-03
> 77 KSP preconditioned resid norm 9.794744927328e-02 true resid norm
> 4.660318995939e-01 ||r(i)||/||b|| 9.102185538943e-04
> 78 KSP preconditioned resid norm 3.311394355245e-01 true resid norm
> 4.581129176231e-01 ||r(i)||/||b|| 8.947517922325e-04
> 79 KSP preconditioned resid norm 7.771705063438e-02 true resid norm
> 4.103510898511e-01 ||r(i)||/||b|| 8.014669723654e-04
> 80 KSP preconditioned resid norm 3.078123608908e-02 true resid norm
> 3.918493012988e-01 ||r(i)||/||b|| 7.653306665991e-04
> 81 KSP preconditioned resid norm 2.759088686744e-02 true resid norm
> 3.289360804743e-01 ||r(i)||/||b|| 6.424532821763e-04
> 82 KSP preconditioned resid norm 1.147671489846e-01 true resid norm
> 3.190902200515e-01 ||r(i)||/||b|| 6.232230860381e-04
> 83 KSP preconditioned resid norm 1.101306468440e-02 true resid norm
> 2.900815313985e-01 ||r(i)||/||b|| 5.665654910126e-04
> type: cg
> type: mg
> Not using Galerkin computed coarse grid matrices
> type: preonly
> type: redundant
> Redundant preconditioner: First (color=0) of 16 PCs follows
> KSP Object: (mg_coarse_redundant_) 1 MPI processes
> type: preonly
> PC Object: (mg_coarse_redundant_) 1 MPI processes
> type: lu
> matrix ordering: nd
> factor fill ratio given 5., needed 7.56438
> type: seqaij
> rows=512, cols=512
> total: nonzeros=24206, allocated nonzeros=24206
> not using I-node routines
> type: seqaij
> rows=512, cols=512
> total: nonzeros=3200, allocated nonzeros=3200
> type: mpiaij
> rows=512, cols=512
> type: richardson
> Richardson: using self-scale best computed damping factor
> maximum iterations=5
> type: sor
> omega = 1.
> type: mpiaij
> rows=4096, cols=4096
> total: nonzeros=27136, allocated nonzeros=27136
> type: richardson
> type: sor
> omega = 1.
> type: mpiaij
> rows=32768, cols=32768
> total: nonzeros=223232, allocated nonzeros=223232
> type: richardson
> type: sor
> omega = 1.
> type: mpiaij
> rows=262144, cols=262144
> total: nonzeros=1810432, allocated nonzeros=1810432
> type: richardson
> type: sor
> omega = 1.
> type: mpiaij
> type: mpiaij
> Residual 2 norm 0.290082
> Residual infinity norm 0.00192869
> solver_test.c:
> // modified version of ksp/ksp/examples/tutorials/ex34.c
> // related: ksp/ksp/examples/tutorials/ex29.c
> // ksp/ksp/examples/tutorials/ex32.c
> // ksp/ksp/examples/tutorials/ex50.c
> #include <petscdm.h>
> #include <petscdmda.h>
> #include <petscksp.h>
> extern PetscErrorCode ComputeMatrix(KSP,Mat,Mat,void*);
> extern PetscErrorCode ComputeRHS(KSP,Vec,void*);
> typedef enum
> DIRICHLET,
> NEUMANN
> } BCType;
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **argv)
> KSP ksp;
> DM da;
> PetscReal norm;
> PetscErrorCode ierr;
> PetscInt i,j,k,mx,my,mz,xm,ym,zm,xs,ys,zs;
> PetscScalar Hx,Hy,Hz;
> PetscScalar ***array;
> Vec x,b,r;
> Mat J;
> const char* bcTypes[2] = { "dirichlet", "neumann" };
> PetscInt bcType = (PetscInt)DIRICHLET;
> PetscInitialize(&argc,&argv,(char*)0,0);
> ierr = PetscOptionsBegin(PETSC_COMM_WORLD, "", "", "");CHKERRQ(ierr);
> ierr = PetscOptionsEList("-bc_type", "Type of boundary condition", "",
> bcTypes, 2, bcTypes[0], &bcType, NULL);CHKERRQ(ierr);
> ierr = PetscOptionsEnd();CHKERRQ(ierr);
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
> ierr = DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_
> NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,-12,-12,-12,
> PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,0,&da);CHKERRQ(ierr);
> ierr = DMDASetInterpolationType(da, DMDA_Q0);CHKERRQ(ierr);
> ierr = KSPSetDM(ksp,da);CHKERRQ(ierr);
> ierr = KSPSetComputeRHS(ksp,ComputeRHS,&bcType);CHKERRQ(ierr);
> ierr = KSPSetComputeOperators(ksp,ComputeMatrix,&bcType);
> CHKERRQ(ierr);
> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
> ierr = KSPGetSolution(ksp,&x);CHKERRQ(ierr);
> ierr = KSPGetRhs(ksp,&b);CHKERRQ(ierr);
> ierr = KSPGetOperators(ksp,NULL,&J);CHKERRQ(ierr);
> ierr = VecDuplicate(b,&r);CHKERRQ(ierr);
> ierr = MatMult(J,x,r);CHKERRQ(ierr);
> ierr = VecAYPX(r,-1.0,b);CHKERRQ(ierr);
> ierr = VecNorm(r,NORM_2,&norm);CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_WORLD,"Residual 2 norm
> %g\n",(double)norm);CHKERRQ(ierr);
> ierr = VecNorm(r,NORM_INFINITY,&norm);CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_WORLD,"Residual infinity norm
> ierr = VecDestroy(&r);CHKERRQ(ierr);
> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> ierr = DMDestroy(&da);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return 0;
> #undef __FUNCT__
> #define __FUNCT__ "ComputeRHS"
> PetscErrorCode ComputeRHS(KSP ksp,Vec b,void *ctx)
> DM da;
> BCType bcType = *(BCType*)ctx;
> PetscFunctionBeginUser;
> ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
> ierr = DMDAGetInfo(da, 0, &mx, &my, &mz, 0,0,0,0,0,0,0,0,0);CHKERRQ(
> ierr);
> Hx = 1.0 / (PetscReal)(mx);
> Hy = 1.0 / (PetscReal)(my);
> Hz = 1.0 / (PetscReal)(mz);
> ierr = DMDAGetCorners(da,&xs,&ys,&zs,&xm,&ym,&zm);CHKERRQ(ierr);
> ierr = DMDAVecGetArray(da, b, &array);CHKERRQ(ierr);
> for (k = zs; k < zs + zm; k++)
> for (j = ys; j < ys + ym; j++)
> for (i = xs; i < xs + xm; i++)
> PetscReal x = ((PetscReal)i + 0.5) * Hx;
> PetscReal y = ((PetscReal)j + 0.5) * Hy;
> PetscReal z = ((PetscReal)k + 0.5) * Hz;
> array[k][j][i] = PetscSinReal(x * 2.0 * PETSC_PI) *
> PetscCosReal(y * 2.0 * PETSC_PI) * PetscSinReal(z * 2.0 * PETSC_PI);
> ierr = DMDAVecRestoreArray(da, b, &array);CHKERRQ(ierr);
> ierr = VecAssemblyBegin(b);CHKERRQ(ierr);
> ierr = VecAssemblyEnd(b);CHKERRQ(ierr);
> PetscReal norm;
> VecNorm(b, NORM_2, &norm);
> PetscPrintf(PETSC_COMM_WORLD, "right hand side 2 norm: %g\n",
> (double)norm);
> VecNorm(b, NORM_INFINITY, &norm);
> PetscPrintf(PETSC_COMM_WORLD, "right hand side infinity norm: %g\n",
> (double)norm);
> /* force right hand side to be consistent for singular matrix */
> /* note this is really a hack, normally the model would provide you
> with a consistent right handside */
> if (bcType == NEUMANN)
> MatNullSpace nullspace;
> ierr = MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,0,&
> nullspace);CHKERRQ(ierr);
> ierr = MatNullSpaceRemove(nullspace,b);CHKERRQ(ierr);
> ierr = MatNullSpaceDestroy(&nullspace);CHKERRQ(ierr);
> PetscFunctionReturn(0);
> #undef __FUNCT__
> #define __FUNCT__ "ComputeMatrix"
> PetscErrorCode ComputeMatrix(KSP ksp, Mat J,Mat jac, void *ctx)
> PetscInt i,j,k,mx,my,mz,xm,ym,zm,xs,ys,zs,num, numi, numj, numk;
> PetscScalar v[7],Hx,Hy,Hz;
> MatStencil row, col[7];
> DM da;
> if (bcType == DIRICHLET)
> PetscPrintf(PETSC_COMM_WORLD, "building operator with Dirichlet
> boundary conditions, ");
> else if (bcType == NEUMANN)
> PetscPrintf(PETSC_COMM_WORLD, "building operator with Neumann
> else
> SETERRQ(PETSC_COMM_WORLD, PETSC_ERR_SUP, "unrecognized boundary
> condition type\n");
> ierr = DMDAGetInfo(da,0,&mx,&my,&mz,0,0,0,0,0,0,0,0,0);CHKERRQ(
> ierr);
> PetscPrintf(PETSC_COMM_WORLD, "global grid size: %d x %d x %d\n", mx,
> my, mz);
> PetscReal Hx2 = Hx * Hx;
> PetscReal Hy2 = Hy * Hy;
> PetscReal Hz2 = Hz * Hz;
> PetscReal scaleX = 1.0 / Hx2;
> PetscReal scaleY = 1.0 / Hy2;
> PetscReal scaleZ = 1.0 / Hz2;
> row.i = i;
> row.j = j;
> row.k = k;
> if (i == 0 || j == 0 || k == 0 || i == mx - 1 || j == my -
> 1 || k == mz - 1)
> num = 0;
> numi = 0;
> numj = 0;
> numk = 0;
> if (k != 0)
> v[num] = -scaleZ;
> col[num].i = i;
> col[num].j = j;
> col[num].k = k - 1;
> num++;
> numk++;
> if (j != 0)
> v[num] = -scaleY;
> col[num].i = i;
> col[num].j = j - 1;
> col[num].k = k;
> num++;
> numj++;
> if (i != 0)
> v[num] = -scaleX;
> col[num].i = i - 1;
> col[num].j = j;
> col[num].k = k;
> num++;
> numi++;
> if (i != mx - 1)
> v[num] = -scaleX;
> col[num].i = i + 1;
> col[num].j = j;
> col[num].k = k;
> num++;
> numi++;
> if (j != my - 1)
> v[num] = -scaleY;
> col[num].i = i;
> col[num].j = j + 1;
> col[num].k = k;
> num++;
> numj++;
> if (k != mz - 1)
> v[num] = -scaleZ;
> col[num].i = i;
> col[num].j = j;
> col[num].k = k + 1;
> num++;
> numk++;
> v[num] = (PetscReal) (numk) * scaleZ + (PetscReal)
> (numj) * scaleY + (PetscReal) (numi) * scaleX;
> else if (bcType == DIRICHLET)
> v[num] = 2.0 * (scaleX + scaleY + scaleZ);
> col[num].i = i;
> col[num].j = j;
> col[num].k = k;
> num++;
> ierr = MatSetValuesStencil(jac, 1, &row, num, col, v,
> INSERT_VALUES);
> CHKERRQ(ierr);
> else
> v[0] = -scaleZ;
> col[0].i = i;
> col[0].j = j;
> col[0].k = k - 1;
> v[1] = -scaleY;
> col[1].i = i;
> col[1].j = j - 1;
> col[1].k = k;
> v[2] = -scaleX;
> col[2].i = i - 1;
> col[2].j = j;
> col[2].k = k;
> v[3] = 2.0 * (scaleX + scaleY + scaleZ);
> col[3].i = i;
> col[3].j = j;
> col[3].k = k;
> v[4] = -scaleX;
> col[4].i = i + 1;
> col[4].j = j;
> col[4].k = k;
> v[5] = -scaleY;
> col[5].i = i;
> col[5].j = j + 1;
> col[5].k = k;
> v[6] = -scaleZ;
> col[6].i = i;
> col[6].j = j;
> col[6].k = k + 1;
> ierr = MatSetValuesStencil(jac, 1, &row, 7, col, v,
> INSERT_VALUES);
> CHKERRQ(ierr);
> ierr = MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatSetNullSpace(J,nullspace);CHKERRQ(ierr);
> On Jun 22, 2017, at 9:23 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jun 21, 2017 at 8:12 PM, Jason Lefley <jason.lefley at aclectic.com>
> wrote:
>> Hello,
>> We are attempting to use the PETSc KSP solver framework in a fluid
>> dynamics simulation we developed. The solution is part of a pressure
>> projection and solves a Poisson problem. We use a cell-centered layout with
>> a regular grid in 3d. We started with ex34.c from the KSP tutorials since
>> it has the correct calls for the 3d DMDA, uses a cell-centered layout, and
>> states that it works with multi-grid. We modified the operator construction
>> function to match the coefficients and Dirichlet boundary conditions used
>> in our problem (we’d also like to support Neumann but left those out for
>> now to keep things simple). As a result of the modified boundary
>> conditions, our version does not perform a null space removal on the right
>> hand side or operator as the original did. We also modified the right hand
>> side to contain a sinusoidal pattern for testing. Other than these changes,
>> our code is the same as the original ex34.c
>> With the default KSP options and using CG with the default
>> pre-conditioner and without a pre-conditioner, we see good convergence.
>> However, we’d like to accelerate the time to solution further and target
>> larger problem sizes (>= 1024^3) if possible. Given these objectives,
>> multi-grid as a pre-conditioner interests us. To understand the improvement
>> that multi-grid provides, we ran ex45 from the KSP tutorials. ex34 with CG
>> and no pre-conditioner appears to converge in a single iteration and we
>> wanted to compare against a problem that has similar convergence patterns
>> to our problem. Here’s the tests we ran with ex45:
>> mpirun -n 16 ./ex45 -da_grid_x 129 -da_grid_y 129 -da_grid_z 129
>> time in KSPSolve(): 7.0178e+00
>> solver iterations: 157
>> KSP final norm of residual: 3.16874e-05
>> -ksp_type cg -pc_type none
>> time in KSPSolve(): 4.1072e+00
>> solver iterations: 213
>> KSP final norm of residual: 0.000138866
>> -ksp_type cg
>> time in KSPSolve(): 3.3962e+00
>> solver iterations: 88
>> KSP final norm of residual: 6.46242e-05
>> mpirun -n 16 ./ex45 -da_grid_x 129 -da_grid_y 129 -da_grid_z 129 -pc_type
>> mg -pc_mg_levels 5 -mg_levels_ksp_type richardson -mg_levels_ksp_max_it 1
>> -mg_levels_pc_type bjacobi
>> time in KSPSolve(): 1.3201e+00
>> solver iterations: 4
>> KSP final norm of residual: 8.13339e-05
>> -mg_levels_pc_type bjacobi -ksp_type cg
>> time in KSPSolve(): 1.3008e+00
>> KSP final norm of residual: 2.21474e-05
>> We found the multi-grid pre-conditioner options in the KSP tutorials
>> makefile. These results make sense; both the default GMRES and CG solvers
>> converge and CG without a pre-conditioner takes more iterations. The
>> multi-grid pre-conditioned runs are pretty dramatically accelerated and
>> require only a handful of iterations.
>> We ran our code (modified ex34.c as described above) with the same
>> parameters:
>> time in KSPSolve(): 5.3729e+00
>> solver iterations: 123
>> KSP final norm of residual: 0.00595066
>> time in KSPSolve(): 3.6154e+00
>> solver iterations: 188
>> KSP final norm of residual: 0.00505943
>> -ksp_type cg
>> time in KSPSolve(): 3.5661e+00
>> solver iterations: 98
>> KSP final norm of residual: 0.00967462
>> -pc_type mg -pc_mg_levels 5 -mg_levels_ksp_type richardson
>> -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi
>> time in KSPSolve(): 4.5606e+00
>> solver iterations: 44
>> KSP final norm of residual: 949.553
> 1) Dave is right
> 2) In order to see how many iterates to expect, first try using algebraic
> multigrid
> -pc_type gamg
> This should work out of the box for Poisson
> 3) For questions like this, we really need to see
> 4) It sounds like you smoother is not strong enough. You could try
> or maybe GMRES until it works.
> Thanks,
> Matt
>> -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi -ksp_type cg
>> time in KSPSolve(): 1.5481e+01
>> solver iterations: 198
>> KSP final norm of residual: 0.916558
>> We performed all tests with petsc-3.7.6.
>> The trends with CG and GMRES seem consistent with the results from ex45.
>> However, with multi-grid, something doesn’t seem right. Convergence seems
>> poor and the solves run for many more iterations than ex45 with multi-grid
>> as a pre-conditioner. I extensively validated the code that builds the
>> matrix and also confirmed that the solution produced by CG, when evaluated
>> with the system of equations elsewhere in our simulation, produces the same
>> residual as indicated by PETSc. Given that we only made minimal
>> modifications to the original example code, it seems likely that the
>> operators constructed for the multi-grid levels are ok.
>> We also tried a variety of other suggested parameters for the multi-grid
>> pre-conditioner as suggested in related mailing list posts but we didn’t
>> observe any significant improvements over the results above.
>> Is there anything we can do to check the validity of the coefficient
>> matrices built for the different multi-grid levels? Does it look like there
>> could be problems there? Or any other suggestions to achieve better results
>> with multi-grid? I have the -log_view, -ksp_view, and convergence monitor
>> output from the above tests and can post any of it if it would assist.
>> Thanks
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170622/72a512ef/attachment-0001.html>
